11-02-2013, 08:57 | #3886 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Nokia 110 restart problame solve Code: Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.49 EBL version: Quantum_Bootloader_10.49_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35327405354198 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35327405354198_back.RPL" Processing file: rm827__03.04.mcusw Downloading item CODE:rm827__03.04.mcusw_ebl_psi.fls, num block: 4, size: 26 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.390 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.452 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.684 s Erasing area 0x40280000-0x41B3FFFE ...OK Programming completed in 37.752 s Checksum verified (0x74A0) Processing file: rm827__03.04.ppm_mh1 Downloading item CUST:package_mh1.ppm_ebl_psi.fls, num block: 1, size: 3.12 MB Erasing area 0x41BC0000-0x41EDE1A2 ...OK Programming completed in 5.101 s Checksum verified (0xD976) Processing file: rm827__03.04.image_mh1_059N0N5 Downloading item CUST:package_mh1_059N0N5.image.fls, num block: 1, size: 14.88 MB Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 23.821 s Checksum verified (0xF4C0) Total time for flashing process(boot+erase+write) was 7 min 45.639 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-00 USB Phonet, PORT_ID: 218E9049 Verifying communication to device OK. Phone type: RM-827 (Nokia 110) SW version: V 03.04 20-04-12 RM-827 (c) Nokia Imei plain: 35327405354198-7 Product code: 059P8F5 Battery voltage: 4988 mV, current: 147 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: MH1 Language Pack: - not available. Camera config: NI00CS0000040C21AC67, ver: 004.032 Imei net: 35327405354198 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000004000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.109 s Nokia USB ROM disconnected. |
11-07-2013, 08:43 | #3888 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Nokia x2-02 flashing NOKIA X2-02 FLASHING Code: Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35169505550314 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35169505550314_back.RPL" Processing file: rm694__11.84.mcusw Downloading item CODE:rm694__11.84.mcusw_ebl_psi.fls, num block: 4, size: 26.25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.374 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.375 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.575 s Erasing area 0x40280000-0x41B7FFFE ...OK Programming completed in 34.542 s Checksum verified (0xB615) Processing file: rm694__11.84.ppm_m_f Downloading item CUST:package_m_f.ppm_ebl_psi.fls, num block: 1, size: 4.22 MB Erasing area 0x41C00000-0x4203822A ...OK Programming completed in 6.334 s Checksum verified (0x6D2D) Processing file: rm694__11.84.image_m_f_059J6X2 Downloading item CUST:package_m_f_059J6X2.image.fls, num block: 1, size: 13.88 MB Erasing area 0x42300000-0x43E1FFFE ...OK Programming completed in 21.575 s Checksum verified (0xBC89) Total time for flashing process(boot+erase+write) was 8 min 5.331 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia X2-02 USB Phonet, PORT_ID: 351695055503140 Verifying communication to device OK. Phone type: RM-694 (X2-02) SW version: V 11.84 13-09-12 RM-694 (c) Nokia Imei plain: 35169505550314-0 Product code: 059N1T6 Language Pack: - not available. Imei net: 35169505550314 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.110 s |
12-20-2013, 08:26 | #3890 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Kushtia,Bangladesh
Member: 597569 Status: Offline Sonork: 100.1593870 Thanks Meter: 271 | nokia 6555b unlock done Code: Imei net: 356271010177027 Version: SIMLOCK SERVER Provider: Cingular Wireless , Country: United States Counter: 0/3, 0/10 CONFIG_DATA: 3101700000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=310150 [United States-Cingular Wireless ] BLOCK2: 1=CLOSED(MCCMNC), DATA=310170 [United States-Cingular Wireless ] BLOCK3: 1=CLOSED(MCCMNC), DATA=311180 [United States-Cingular Wireless, Licensee Pacific Telesis Mobile Services, LLC ] BLOCK4: 1=CLOSED(MCCMNC), DATA=310410 [United States-Cingular Wireless ] BLOCK5: 1=CLOSED(MCCMNC), DATA=310980 [United States-Texas RSA 7B3 dba Peoples Wireless Services ] MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: C0871C68 Using device: HTI, FW ver: 00.50, SN: 01008E6B Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Phone type: RM-289 (Nokia 6555b) SW version: V 03.31 01-08-07 RM-289 (c) Nokia CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1F600119D4D16750C1CC3333A3FF94E8403AB28F ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Algorithm: RAP3Gv30_XSR14_alg.fg [BB5 ALGORITHM] version: 11.34.0 revision: 3.0 size: 0x81324 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: A32E417B72C365977BB436843861AB6E35608542 PUBLIC ID: 1F600119D4D16750C1CC3333A3FF94E8403AB28F PRIVATE ID: C8BE02A26C593B8F9CDB2C6485B2D6264F8BF640 E-FUSE: 719402F7 SEC ROM CRC: DFAAF68F Restarting phone ... Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 356271010177027 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
04-03-2014, 15:45 | #3892 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Nokia 1220 phone lock reset mx key I AM TRAI UFS BUT BOOTING PROBLEM (I THINK F BUS CABEL PINUT MIRSING) TRAI MX BOX PERFECT FORK |
09-06-2014, 09:57 | #3897 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,346 | Quote:
regard | |
