![]() | #1936 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | N70 Sim rejected sucessfully repaired Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 4D15349C067690DCCA4EF431F62A49CDD1A89A98 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 RAP Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0CE0010D199E5D5189066208BF834B38EF942D80 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 0098 0036 - 00A5 00C0 [Toshiba 512 DDP NAND,512 Mbits] type: NAND,APE ALG [35]: OMAP1610 GBBM-1.8.1 ALG ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000 Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Original Imei: 35863701760283 Original Product code: 0539240 Bluetooth ID: 001D6ED04ABB Phone Type: RM-84 (Nokia N70) SW Version: V 05wk07v47 30-01-07 RM-84 (c) Nokia. Imei plain: 35863701760283-7 Product Code: 0539240 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358637017602837 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 05wk07v47 30-01-07 RM-84 (c) Nokia. ApeCoreSw: V 5.0705.3.0.1 30-01-07 RM-84 (C)Nokia SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1 Completed in 11.500 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-84_358637017602837_SD.RPL" Updating SUPERDONGLE_KEY ...OK Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 05wk07v47 30-01-07 RM-84 (c) Nokia. ApeCoreSw: V 5.0705.3.0.1 30-01-07 RM-84 (C)Nokia Using cached productData[0CE0010D199E5D5189066208BF834B38EF942D80] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ![]() Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 86 bytes written. - Key: 4, size 110 bytes written. - Key: 5, size 4 bytes written. - Key: 6, size 86 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 86 bytes written. - Key: 15, size 4 bytes written. - Key: 16, size 86 bytes written. - Key: 18, size 86 bytes written. - Key: 20, size 86 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 16 bytes written. - Key: 29, size 6 bytes written. - 308 skipped Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. Completed in 1.484 s Imei net: 358637017602837 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 05wk07v47 30-01-07 RM-84 (c) Nokia. Using cached productData[0CE0010D199E5D5189066208BF834B38EF942D80] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1 Completed in 2.469 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-84_358637017602837_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: 358637017602837 Version: SIMLOCK SERVER VERSION 58 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 4D15349C067690DCCA4EF431F62A49CDD1A89A98 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 RAP Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0CE0010D199E5D5189066208BF834B38EF942D80 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 0098 0036 - 00A5 00C0 [Toshiba 512 DDP NAND,512 Mbits] type: NAND,APE ALG [35]: OMAP1610 GBBM-1.8.1 ALG ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000 Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Original Imei: 35863701760283 Original Product code: 0539240 Bluetooth ID: 001D6ED04ABB Phone Type: RM-84 (Nokia N70) SW Version: V 05wk07v47 30-01-07 RM-84 (c) Nokia. Imei plain: 35863701760283-7 Product Code: 0539240 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358637017602837 Version: SIMLOCK SERVER VERSION 58 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
![]() | #1937 (permalink) |
Registered User ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Code: Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm561__09.80.mcusw as MCU [BB5,BB5 ALGORITHM] size: 19.41 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Polling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 77D2F6C RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM0 ID: 00000296 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 1D00011208F58A5600BA7EEE0BB1407B5E8F3B3A RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Polling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 1DA1AC45 [ADL] Verifying communication to device OK. Erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.922 s CMT NOR area [000006C0-0001FFFF] erased in 0.766 s CMT NOR area [00040000-000BFFFF] erased in 2.906 s CMT NOR area [000C0000-0013FFFF] erased in 2.469 s CMT NOR area [00140000-0137FFFF] erased in 1 min 40.594 s CMT NOR area [01380000-0151FFFF] erased in 9.328 s Flash programming ... CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100000000 (RAP Certificate 202 v.1) written. Programming completed in 1 min 7.766 s Processing file: rm561__09.80.ppm_mena_b as PPM [BB5,BB5 ALGORITHM] size: 5.52 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 46.250 s Flash programming ... Programming completed in 19.156 s Processing file: rm561__09.80.image_mena_b_gray as CNT [BB5,BB5 ALGORITHM] page size: 128 K size: 8.26 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 34.00 MB CMT NOR area [01DC0000-0215FFFF] erased in 22.953 s CMT NOR area [02160000-03FBFFFF] erased in 3 min 23.922 s Flash programming ... Programming completed in 28.063 s [ADL] Restarting phone ... [ADL] Polling for ADL device [ADL] Timeout, no usb device found. [ADL] Phone flashing completed, but failed to verify communication to product! [ADL] Retrying in finalize phase... [ADL] Polling for ADL device [ADL] Device found: nmwcdc\Nokia 2700 classic USB Generic, ID: 52488A9 [ADL] Verifying communication to device OK. Flashing completed in 9 min 41.531 s Phone Type: RM-561 (Nokia 2700 classic) SW Version: V 09.80 02-12-09 RM-561 (c) Nokia Imei plain: 35691203496171-0 Product Code: 0581967 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356912034961710 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 9 min 44.156 s |
![]() | #1938 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: INDIA Age: 39
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Code: Imei net: 35290102517720 Version: SIMLOCK SERVER Provider: Virgin - SPECIAL CODE, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2340000100000000 PROFILE_BITS: 8000000000010002 BLOCK 1: 1.LOCKED (MCC+MNC): 23430F 2.LOCKED (GID1): 2800 Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-99_35290102517720_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35290102517720 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN WBR sahil2000ind |
![]() | #1939 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2009 Location: Poland
Member: 1031096 Status: Offline Thanks Meter: 77 | Nokia N97 mini RM-555 flash ok: Code: Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Processing file: RM-555_12.0.110_prd.core.C00 as MCU [BB5,XSR 1.6] size: 105.95 MB Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1F8FD5AC RAP SYSTEM ASIC ID: 000000010000022600010006400C192101051103 RAP EM0 ID: 00000296 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 14F000045E970052ED0E20E9ADBCE6C74492B271 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 RAP ROM ID: 4B9B75103E691FF8 [ADL] Flashing CMT Update Server Data, ULO: 0x3B80 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, XSR: 0x2C0545 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 37032C99 [ADL] Verifying communication to device OK. Partitioning.... Partitioning complete Erase size: 207.44 MB Flash programming ... CMT PAPUBKEYS: C49131EB98702B6A39D7F285B1FF2D9BE1D6F863 (RAP Certificate 199 v.1) written. Programming completed in 1 min 35.020 s Processing file: RM-555_12.0.110_prd.rofs2.V38 as PPM [BB5,XSR 1.6] size: 24.71 MB Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 48.00 MB Flash programming ... Programming completed in 22.222 s Processing file: RM-555_12.0.110_C01_prd.rofs3.fpsx as PPM [BB5,XSR 1.6] size: 10.06 KB Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 15.00 MB Flash programming ... Programming completed in 0.291 s Processing file: rm555ENOA09w24v0.050.fpsx as CNT [BB5,XSR 1.6] size: 2.71 MB Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 4.00 MB Flash programming ... Programming completed in 2.944 s Processing file: RM555_12.0.110_uda_5_001.uda.fpsx as CNT [BB5,XSR 1.6] size: 4.75 MB Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 283.87 MB Flash programming ... Programming completed in 4.599 s [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia N97 mini USB Generic, ID: 30E330B8 [ADL] Verifying communication to device OK. Flashing completed in 2 min 42.511 s Phone Type: RM-555 (Nokia N97 mini) SW Version: V ICPR72_09w44.18 28-05-10 RM-555 (c) Nokia Imei plain: 3533910415xxxx-x Product Code: 05999V7 ApeCoreSw: v 12.0.110 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3533910415xxxxx Version: SIMLOCK SERVER Provider: IDEA Centertel, Country: Poland Counter: 0/3, 0/10 CONFIG_DATA: 2600300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 26003F, DATA=26003F Total time to process is 2 min 43.941 s |
![]() | #1941 (permalink) |
Member: 1031096 Status: Offline Thanks Meter: 77 | Nokia 6230i unlock done: Code: Imei net: 358368002xxxxx Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Provider: IDEA Centertel, Country: Poland Counter: 0/3, 0/10 CONFIG_DATA: 2600300000000000 PROFILE_BITS: 0000000000000006 BLOCK 1: 1.LOCKED (MCC+MNC): 26003F BLOCK 2: 1.LOCKED (MCC+MNC): 26003F Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 358368002xxxxx Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000006 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
![]() | #1942 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | E71 Unlocked Imei net: 356059032563203 Version: SIMLOCK SERVER Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 2: 1=LOCKED (MCC+MNC): 23595F, DATA=23595F Backup saved to "BB5_35605903256320_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 100.71.821.4 06-06-08 RM-346 (c) Nokia ApeCoreSw: 100.07.76 Using cached productData[03E0000676AB8A5255FDDE851499A2E5BB1F48F0] ... Calculating NCK using security server ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.1 #pw+ 929259065089698 +1 # #pw+ 134226978320640 +2 # #pw+ 090991374177677 +3 # #pw+ 404122299802155 +4 # #pw+ 088101051883409 +5 # #pw+ 649819131709251 +6 # #pw+ 301404837570758 +7 # Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Completed in 23.875 s Restarting phone ... Reading Simlock info ... Imei net: 356059032563203 Version: SIMLOCK SERVER Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=23420F BLOCK 2: 1=OPEN, DATA=23595F |
![]() | #1943 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2010 Location: india (telangana state) Age: 46
Member: 1230663 Status: Offline Sonork: 100.1593487 Thanks Meter: 174 | e 71 unlocked successful Imei net: 354208038307345 Version: SIMLOCK SERVER Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 2: 1=LOCKED (MCC+MNC): 23595F, DATA=23595F Backup saved to "BB5_35420803830734_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 100.71.821.4 06-06-08 RM-346 (c) Nokia ApeCoreSw: 100.07.76 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Calculating NCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 #pw+ 200256768917338 +1 # #pw+ 237590389417409 +2 # #pw+ 043003462965282 +3 # #pw+ 842491159785186 +4 # #pw+ 338423553836573 +5 # #pw+ 900365156027133 +6 # #pw+ 987941992628150 +7 # Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Completed in 22.937 s Restarting phone ... Reading Simlock info ... Imei net: 354208038307345 Version: SIMLOCK SERVER Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=23420F BLOCK 2: 1=OPEN, DATA=23595F |
![]() | #1944 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | ![]() nokia 7510s usb flashing done!!! Code: Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Processing file: rm398__06.65.mcusw as MCU [BB5,BB5 ALGORITHM] size: 22.91 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 32B18053 RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM0 ID: 00000295 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 14F00119CAB67E56B91C9EE4D23647C41A22E776 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x67840 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x76280 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 1B3E2966 [ADL] Verifying communication to device OK. Erase size: 28.00 MB CMT NOR area [00000000-0001FFFF] erased in 0.656 s CMT NOR area [00040000-0013FFFF] erased in 6.657 s CMT NOR area [00140000-0023FFFF] erased in 5.688 s CMT NOR area [015A0000-0177FFFF] erased in 10.266 s CMT NOR area [00240000-0159FFFF] erased in 1 min 54.422 s CMT NOR area [02140000-025DFFFF] erased in 27.328 s Flash programming ... CMT PAPUBKEYS: 34F71CF6D1FC422794671654A7A95308F55F71E6 (RAP Certificate 132 v.1) written. Programming completed in 3 min 10.265 s Processing file: rm398__06.65.ppm_i as PPM [BB5,BB5 ALGORITHM] size: 7.40 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 9.75 MB CMT NOR area [01780000-0213FFFF] erased in 57.578 s Flash programming ... Programming completed in 1 min 0.656 s Processing file: rm398__06.65.image_i as CNT [BB5,BB5 ALGORITHM] page size: 128 K size: 9.76 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 25.87 MB CMT NOR area [025E0000-0297FFFF] erased in 27.531 s CMT NOR area [02980000-03FBFFFF] erased in 2 min 39.984 s Flash programming ... Programming completed in 1 min 22.031 s [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. [ADL] Phone flashing completed, but failed to verify communication to product! [ADL] Retrying in finalize phase... [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia 7510 USB Generic, ID: 35D59ADA [ADL] Verifying communication to device OK. Flashing completed in 14 min 16.312 s Phone Type: RM-398 (Nokia 7510 Supernova) SW Version: V 06.65 04-06-09 RM-398 (c) Nokia Imei plain: 35639402364148-0 Product Code: 0567994 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356394023641480 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 14 min 27.062 s Nokia USB ROM detached. |
![]() | #1945 (permalink) |
Major Poster ![]() ![]() Join Date: Dec 2007
Member: 646671 Status: Offline Thanks Meter: 2 | Unlock 5030 RM-524 Imei net: 35319xxxxxx8689 Version: SIMLOCK SERVER Provider: diAx Mobile, Country: Switzerland Counter: 0/3, 0/10 CONFIG_DATA: 2280200000000000 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 22802F Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-524_3531xxxxxxx8689_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 3531xxxxxxx8689 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
![]() | #1946 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | 1661 done Imei net: 35523603503230 Version: SIMLOCK SERVER Provider: Movistar (DCT4), Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140700000000000 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 21407F BLOCK 2: 1.LOCKED (MCC+MNC): 21402F Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-122_35523603503230_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35523603503230 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
![]() | #1947 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | 1661 done Imei net: 35799803219094 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-122_35799803219094_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35799803219094 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
![]() | #1949 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: India
Member: 1152038 Status: Offline Thanks Meter: 257 | >>>>2330c unlock ok mxkey>>>> Imei net: 3582490355xxxx Version: SIMLOCK SERVER Provider: Tesco Mobile, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341000000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 23410F Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Rpl backup saved to "C:\Program Files\mobileEx\3.4\data\backup\RM-512_3582490355xxxx_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 3582490355xxxx Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
