11-27-2012, 08:46 | #3766 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | C1-01 Flashing Done Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000F264 Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.37 EBL version: Quantum_Bootloader_10.37_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35698404328408 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35698404328408_ back.RPL" Processing file: rm607__06.15.mcusw Downloading item CODE:rm607__06.15.mcusw_ebl_psi.fls, num block: 5, size: 25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.359 s Erasing area 0x40040000-0x4007FFFE ...OK Programming completed in 0.547 s Erasing area 0x40080000-0x4009FFFE ...OK Programming completed in 0.375 s Erasing area 0x400A0000-0x4019FFFE ...OK Programming completed in 1.562 s Erasing area 0x40400000-0x41B7FFFE ...OK Programming completed in 34.406 s Checksum verified (0x49A2) Processing file: rm607__06.15.ppm_i Downloading item CUSTackage_i.ppm_ebl_psi.fls, num block: 1, size: 3.56 MB Erasing area 0x41C00000-0x41F8E876 ...OK Programming completed in 5.172 s Checksum verified (0x84A6) Processing file: rm607__06.15.image_i_0596673 Downloading item CUSTackage_i_0596673.image.fls, num block: 1, size: 11.63 MB Erasing area 0x42200000-0x43E5FFFE ...OK Programming completed in 19.875 s Checksum verified (0x692B) Total time for flashing process(boot+erase+write) was 8 min 53.328 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C1-01 USB Phonet, PORT_ID: 1FEAA70 Verifying communication to device OK. Phone type: RM-607 (C1-01) SW version: V 06.15 25-11-11 RM-607 (c) Nokia Imei plain: 35698404328408-7 Product code: 0596379 Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00CS00000401022E05, ver: 001.004 Imei net: 35698404328408 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
The Following User Says Thank You to qasir_amz For This Useful Post: |
11-28-2012, 06:22 | #3767 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | C5-03 (rm-697) music palayer+camera not working done by usb flashing C5-03 (RM-697) MUSIC PALAYER+CAMERA NOT WORKING DONE BY FLASHING (USB MODE) BUS CHACK FLASH MX KEY IS THE BEST SPL FOR (NOKIA TOOL) |
11-29-2012, 11:56 | #3768 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Nokia 200 hangs and auto shutdown solved . Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 3xxxxxxxxxxxxxxxxxx RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_xxxxxxxxxxxxxxx _back.RPL) Processing file: B9CBC02F_rm761__10.61.mcusw Downloading item CODE:rm761__10.61.mcusw_ebl_psi.fls, num block: 4, size: 25.25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.390 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.391 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.750 s Erasing area 0x40280000-0x41A7FFFE ...OK Programming completed in 35.781 s Checksum verified (0x9ED2) Processing file: F34E6D1F_rm761__10.61.ppm_ma3 Downloading item CUSTackage_ma3.ppm_ebl_psi.fls, num block: 1, size: 5.06 MB Erasing area 0x41A80000-0x41F8E86A ...OK Programming completed in 8.016 s Checksum verified (0xE44D) Processing file: 755FE306_rm761__10.61_002.image_mea7_ctv_pk_9n799 Downloading item CUSTackage_ma3_ctv_pk.image.fls, num block: 1, size: 14 MB Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 21.718 s Checksum verified (0xBFD4) Total time for flashing process(boot+erase+write) was 7 min 28.672 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 19680595 Verifying communication to device OK. After Flash Processing ... Reseting Warranty And LifeTimer OK. Reseting Factory Values OK. Phone type: RM-761 (Nokia 200) SW version: V 10.61 02-03-12 RM-761 (c) Nokia Imei plain: xxxxxxxxxxxxxxxxx-6 Product code: 059J4L0 Battery voltage: 3765 mV, current: 41 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: MA3 Language Pack: - not available. Master code: 2417272275 Camera config: 06150123008027, ver: Imei net: 35934504106446 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
11-30-2012, 05:37 | #3769 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | 5220 Flash done MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085DEC5 Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000F264 Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Processing MCU file: rm411__07.23.mcusw [BB5,BB5 ALGORITHM] size: 19.92 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 18E0001110397F56093DE91FB3D51C9B74A38BD5 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4AF40 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 82334AD Verifying communication to device OK. Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] erased in 0.687 s CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.703 s CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.984 s CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.735 s CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 43.187 s CMT FLASH,NOR area [01380000-0151FFFF] erased in 9.031 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: D93826B2 [RAP Certificate 130 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 18.078 s Processing PPM file: rm411__07.23.ppm_i [BB5,BB5 ALGORITHM] size: 7.51 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 47.782 s Flash programming ... Programming completed in 29.984 s Processing CNT file: rm411__07.23.image_i_ru_red_128 [BB5,BB5 ALGORITHM] page size: 128 K size: 10.83 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 24.578 s CMT FLASH,NOR area [02160000-03FBFFFF] erased in 3 min 46.234 s UCP page size is 128 K. Flash programming ... Programming completed in 42.609 s Total time for flashing process(boot+erase+write) was 10 min 5.594 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 5220 XpressMusic USB Phonet, PORT_ID: 2261507 Verifying communication to device OK. Phone type: RM-411 (Nokia 5220 XpressMusic) SW version: V 07.23 17-07-09 RM-411 (c) Nokia Imei plain: 35684002834907-3 Product code: 0570217 Battery voltage: 3876 mV, current: 83 mA Language Pack: - not available. SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK) Camera config: NIMMIIIIRRFF094B2F01, ver: 002.014 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356840028349073 Version: SIMLOCK SERVER Provider: O2 UK Ltd. , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=OPEN |
11-30-2012, 11:39 | #3770 (permalink) |
No Life Poster Join Date: Oct 2011 Location: milano.itlay Age: 34
Member: 1680962 Status: Offline Thanks Meter: 334 | NOKIA ASHA 305 FULL FLASH DONE MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: C086E8A5 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 01000A8F Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012) Battery voltage: 4067 mV Setting TEST MODE ... Nokia USB Phonet detached. Device connected: nmwcdc\Nokia USB Phonet Connection status: UHCI:HUB:USB 2.00 Full-speed Nokia USB Phonet ready. Waiting for USB device removal ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.49 EBL version: Quantum_Bootloader_10.49_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 00EC 3012 - 23280002 [Samsung ] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35367305973094 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK LOCK120_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35367305973094_ back.RPL" Processing file: rm766__03.60.mcusw Downloading item CODE:rm766__03.60.mcusw_ebl_psi.fls, num block: 4, size: 27.77 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.359 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.360 s Erasing area 0x40060000-0x4011FFFE ...OK Programming completed in 1.266 s Erasing area 0x40120000-0x41BE3FFE ...OK Programming completed in 36.172 s Checksum verified (0x99D5) Processing file: rm766__03.60.ppm_maa Downloading item CUSTackage_maa.ppm_ebl_psi.fls, num block: 1, size: 5.80 MB Erasing area 0x41C00000-0x421CC5A6 ...OK Programming completed in 8.000 s Checksum verified (0xB71F) Total time for flashing process(boot+erase+write) was 2 min 58.422 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 2970280F Verifying communication to device OK. After Flash Processing ... Phone type: RM-766 (Nokia 305) SW version: V 03.60 06-06-12 RM-766 (c) Nokia Imei plain: 35367305973094-2 Product code: 059P7W6 Language Pack: - not available. Imei net: 35367305973094 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
11-30-2012, 11:39 | #3771 (permalink) |
11-30-2012, 11:51 | #3772 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | 6300 Blinking Screen done in Flashing MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085DEC5 Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000F264 Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Processing MCU file: rm217__07.30.mcusw [BB5,BB5 ALGORITHM] size: 14.50 MB Supported Ids: 0103192101001101, 010C192101001101 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 472EEA3 CMT SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x] CMT EM0 ID: 00000232 CMT EM1 ID: 00000353 CMT PUBLIC ID: 2E1002179EF47E5665CC64FA339A4DAB89B7A49B CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID: 191EC665DFAAF68F Flashing CMT Update Server Data, ULO: 0x38C0 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x3CA00 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x4A9C0 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 3252BC99 Verifying communication to device OK. Erase size: 16.37 MB CMT FLASH,NOR area [00000000-000006BF] erased in 0.391 s CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.016 s CMT FLASH,NOR area [00020000-0007FFFF] erased in 1.171 s CMT FLASH,NOR area [00080000-000DFFFF] erased in 0.078 s CMT FLASH,NOR area [00100000-001FFFFF] erased in 0.172 s CMT FLASH,NOR area [00200000-0031FFFF] erased in 3.578 s CMT FLASH,NOR area [00320000-0105FFFF] erased in 41.891 s CMT FLASH,NOR area [01060000-01067FFF] erased in 0.391 s CMT FLASH,NOR area [01068000-0107FFFF] erased in 0.015 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 7F7E6491 [RAP Certificate 52 v1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT PMM_CONF block sent CMT SBIF_CONF block sent Programming completed in 2 min 3.438 s Processing PPM file: rm217__07.30.ppm_b [BB5,BB5 ALGORITHM] size: 4.22 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 5.50 MB CMT FLASH,NOR area [01080000-015FFFFF] erased in 14.766 s Flash programming ... Programming completed in 36.688 s Processing CNT file: rm217__07.30.image_ctv_cn_black_128k [BB5,BB5 ALGORITHM] page size: 128 K size: 4.63 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 9.87 MB CMT FLASH,NOR area [01600000-01FDFFFF] erased in 31.156 s Flash programming ... Programming completed in 38.203 s Total time for flashing process(boot+erase+write) was 6 min 0.796 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia 6300 USB Phonet, PORT_ID: 167C46E3 Verifying communication to device OK. Phone type: RM-217 (Nokia 6300) SW version: V 07.30 07-05-09 RM-217 (c) Nokia. Imei plain: 35523403238013-7 Product code: 0521830 Battery voltage: 3815 mV, current: 97 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355234032380137 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
12-02-2012, 07:14 | #3773 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | C1-01 Flashing Done MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085DEC5 Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000F264 Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.37 EBL version: Quantum_Bootloader_10.37_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35934404223555 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35934404223555_ back.RPL" Processing file: rm607__06.15.mcusw Downloading item CODE:rm607__06.15.mcusw_ebl_psi.fls, num block: 5, size: 25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.641 s Erasing area 0x40040000-0x4007FFFE ...OK Programming completed in 0.937 s Erasing area 0x40080000-0x4009FFFE ...OK Programming completed in 0.579 s Erasing area 0x400A0000-0x4019FFFE ...OK Programming completed in 3.468 s Erasing area 0x40400000-0x41B7FFFE ...OK Programming completed in 1 min 5.766 s Checksum verified (0x49A2) Processing file: rm607__06.15.ppm_i Downloading item CUSTackage_i.ppm_ebl_psi.fls, num block: 1, size: 3.56 MB Erasing area 0x41C00000-0x41F8E876 ...OK Programming completed in 10.015 s Checksum verified (0x84A6) Processing file: rm607__06.15.image_i_0596673 Downloading item CUSTackage_i_0596673.image.fls, num block: 1, size: 11.63 MB Erasing area 0x42200000-0x43E5FFFE ...OK Programming completed in 30.500 s Checksum verified (0x692B) Total time for flashing process(boot+erase+write) was 8 min 29.938 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C1-01 USB Phonet, PORT_ID: 14B85B15 Verifying communication to device OK. Phone type: RM-607 (C1-01) SW version: V 06.15 25-11-11 RM-607 (c) Nokia Imei plain: 35934404223555-5 Product code: 059F3T8 Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00CS00000401022E05, ver: 001.004 Imei net: 35934404223555 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
12-02-2012, 10:20 | #3774 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | C5 Rm645 Flashing MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085DEC5 Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000F264 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Processing MCU file: rm645_071.005_prd.core.fpsx [BB5,XSR 1.6] size: 96.64 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3629087C CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 293001125CA20344AAAC2BAA48FE6B46A7E642D7 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3629087C FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35484704075214_CE RT.rpl" CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 170.06 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 30.765 s Processing PPM file: rm645_071.005_05.01_Russian_prd.rofs2.fpsx [BB5,XSR 1.6] size: 44.62 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 51 MB CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 13.859 s Processing CNT file: rm645_071.005_U000.000_prd.uda.fpsx [BB5,XSR 1.6] size: 1.32 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 72 MB CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF] Flash programming ... Programming completed in 0.859 s Total time for flashing process(boot+erase+write) was 1 min 26.047 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia C5-00 USB Phonet, PORT_ID: 28A1FB5B Verifying communication to device OK. Phone type: RM-645 (Nokia C5-00) SW version: V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia ApeCoreSw: 071.005 Imei plain: 35484704075214-5 Product code: 0593753 Battery voltage: 3627 mV, current: 212 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354847040752145 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
12-09-2012, 09:28 | #3776 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | 6600s Flashing MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085DEC5 Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000F264 Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Processing MCU file: rm414__06.55.mcusw [BB5,XSR 1.5] size: 23.30 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1BAD387A CMT SYSTEM ASIC ID: 000000010000022600010006030C192101023000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 06F00102BAEA585073DF859432F744D1C59748CB CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x49CC0 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x58700 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 82334AD Verifying communication to device OK. Erase size: 25.37 MB CMT FLASH,NOR area [00000000-0001FFFF] erased in 0.844 s CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.765 s CMT FLASH,NOR area [000C0000-0013FFFF] erased in 0.094 s CMT FLASH,NOR area [01780000-0197FFFF] erased in 10.156 s CMT FLASH,NOR area [00140000-0177FFFF] erased in 1 min 41.203 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: A4B03CEB [RAP Certificate 134 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 2 min 4.078 s Processing PPM file: rm414__06.55.ppm_i [BB5,XSR 1.5] size: 7.30 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 8.25 MB CMT FLASH,NOR area [01980000-021BFFFF] erased in 39.907 s Flash programming ... Programming completed in 40.906 s Processing CNT file: rm414__06.55_ISM_025.image_i_ru_black [BB5,BB5 ALGORITHM] page size: 128 K size: 9.38 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 29.87 MB CMT FLASH,NOR area [02620000-03F9FFFF] erased in 2 min 20.422 s CMT FLASH,NOR area [021C0000-0261FFFF] erased in 26.421 s Flash programming ... Programming completed in 49.922 s Total time for flashing process(boot+erase+write) was 9 min 59.235 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 6600 slide USB Phonet, PORT_ID: 2EEC51B8 Verifying communication to device OK. Phone type: RM-414 (Nokia 6600 slide) SW version: V 06.55 26-10-09 RM-414 (c) Nokia Imei plain: 35195403116466-1 Product code: 0572228 Battery voltage: 2713 mV, current: 93 mA Language Pack: - not available. SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 351954031164661 Version: SIMLOCK SERVER Provider: T-Mobile UK , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=OPEN |
12-11-2012, 05:35 | #3777 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | E63 Flashing Done MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C085DEC5 Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000F264 Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Processing MCU file: rm437_510.21.010_prd.c0r [BB5,XSR 1.5] size: 63.43 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 178000196296005285E185B14DDEFC5AEC97FC2D CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5 CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CERT backup skipped. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 122.56 MB CMT FLASH,MuxOneNAND area [00040000-007FFFFF] CMT FLASH,MuxOneNAND area [00A00000-0759FFFF] CMT FLASH,MuxOneNAND area [0F1C0000-0F8BFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: D9C25399 [RAP Certificate 137 v.1] sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS*CORE block sent CMT SOS+ROFS block sent Programming completed in 18 min 1.594 s Processing PPM file: rm437_510.21.010_prd.v14 [BB5,XSR 1.5] size: 26.02 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 33.56 MB CMT FLASH,MuxOneNAND area [05420000-0759FFFF] Formating partition ... Flash programming ... CMT SOS+ROFX block sent Programming completed in 7 min 40.359 s Processing CNT file: rm437_510.21.010.43U [BB5,XSR 1.5] size: 22.57 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 64 KB Formating partition ... Flash programming ... Programming completed in 6 min 39.281 s Total time for flashing process(boot+erase+write) was 32 min 45.860 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1BAD387A Waiting for USB device removal ... Device connected: nmwcdc\Nokia E63 USB Phonet, PORT_ID: 68D9227 Verifying communication to device OK. Phone type: RM-437 (Nokia E63) SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia ApeCoreSw: 510.21.010 Imei plain: 35339704355109-5 Product code: 0585258 Battery voltage: 3913 mV, current: 126 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353397043551095 Version: SIMLOCK SERVER Provider: Hutchison 3G UK Ltd. , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN BLOCK2: 1=OPEN BLOCK3: 1=OPEN BLOCK4: 1=OPEN |
12-11-2012, 11:15 | #3778 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | 5310 Flashing Imei net: 352044029969195 Version: SIMLOCK SERVER Provider: T-Mobile UK , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=23430F [United Kingdom-T-Mobile UK ] MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085DEC5 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0000F264 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Phone type: RM-303 (Nokia 5310 XpressMusic) SW version: V 10.10 23-03-09 RM-303 (c) Nokia Battery voltage: 3814 mV Phone type: RM-303 (Nokia 5310 XpressMusic) Product code: 0558774 SW version: V 10.10 - 23-03-09 - RM-303 - (c) Nokia LanguagePkg version: 0 - 23-03-09 - RM-303 - (c) Nokia - I Waiting for USB device removal ... Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Reading Simlock info ... Imei net: 352044029969195 Version: SIMLOCK SERVER Provider: T-Mobile UK , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=23430F [United Kingdom-T-Mobile UK ] |
12-14-2012, 12:13 | #3779 (permalink) |
Member: 1680962 Status: Offline Thanks Meter: 334 | NOKIA x2-00 FULL FLASH DONE Phone type: RM-618 (Nokia X2-00) SW version: V 08.25 19-05-11 RM-618 (c) Nokia Imei plain: 35269904581257-8 Product code: 0595291 Battery voltage: 3888 mV, current: 1 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00BC0000040A4E2000, ver: 003.005 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352699045812578 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.796 s |
12-14-2012, 12:14 | #3780 (permalink) |
