11-16-2010, 23:50 | #2611 (permalink) |
No Life Poster Join Date: Oct 2010
Member: 1423200 Status: Offline Thanks Meter: 53 | Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C927A6A3BDA66 ASIC type: 11 UEM Imei: 35810001069799 Processing MCU file: rh105_06.000 [DCT4,DCT4 ALGORITHM] size: 2.27 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C927A6:2984DA60 Area [01000000-0100FFFF] erased in 0.450 s Area [01010000-013AFFFF] erased in 26.347 s Area [013B0000-013EFFFF] erased in 1.690 s Area [017C0000-017EFFFF] erased in 0.057 s Area [01FC0000-01FEFFFF] erased in 0.060 s Flash programming ... Programming completed in 16.317 s File Processed in 1 min 1.220 s Processing CNT file: rh1050_nai6.00ej [DCT4,DCT4 ALGORITHM] size: 114.90 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C927A6:2984DA60 Area [01380000-013AFFFF] erased in 1.374 s Flash programming ... Programming completed in 0.848 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 20.132 s File Processed in 53.541 s Processing PPM file: rh105_06.00ej [DCT4,DCT4 ALGORITHM] size: 1.15 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C927A6:2984DA60 Area [01240000-0124FFFF] erased in 0.511 s Area [01250000-0137FFFF] erased in 8.943 s Flash programming ... Programming completed in 8.267 s File Processed in 33.984 s Flashing completed in 3 min 20.718 s Phone Type: RH-105 SW Version: V 6.00 30-09-09 RH-105 (c) NMP Imei plain: ********************8 Product Code: 0553782 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: EJ Language Pack: - not available. Imei net: ****************** Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
11-17-2010, 04:35 | #2612 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 189487 Status: Offline Thanks Meter: 30 | RM-625 5233 by USB Flashing CMT Update Server Data, XSR: 0x282683 bytes Update Server code succesfully sent to phone. Pooling for ADL device ... Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: F22DBA6 Verifying communication to device OK. Partitioning.... Partitioning complete Erase size: 154.19 MB Flash programming ... CMT PAPUBKEYS: 7DC72D3FDC552426A4479BC820097D304CFB6C15 (RAP Certificate version) written. Programming completed in 1 min 24.813 s Processing PPM file: RM-625_21.1.004_prd.rofs2.V20 [BB5,XSR 1.6] size: 17.54 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 36.50 MB Flash programming ... Programming completed in 16.406 s Processing CNT file: RM-625_21.1.004_001_000_U001.uda.fpsx [BB5,XSR 1.6] size: 5.52 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 86.12 MB Flash programming ... Programming completed in 5.093 s Total time for flashing process(boot+erase+write) was 2 min 4.672 s Pooling for ADL device ... Device found: nmwcdc\Nokia 5800 XpressMusic USB Generic, ID: 343C614E Verifying communication to device OK. Flashing completed in 2 min 27.016 s Phone Type: RM-625 (Nokia 5233) SW Version: V ICPR72_10w21 26-05-10 RM-625 (c) Nokia Imei plain: 35200004257059-2 Product Code: 0597963 ApeCoreSw: V 21.1.004 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352000042570592 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Market items is empty, please select the correct products path ! |
11-17-2010, 05:14 | #2613 (permalink) |
Member: 189487 Status: Offline Thanks Meter: 30 | 6300 by usb Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Processing MCU file: rm217__07.21.mcusw [BB5,BB5 ALGORITHM] size: 14.50 MB Supported Ids: 0103192101001101, 010C192101001101 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3 CMT SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] CMT EM0 ID: 00000232 CMT EM1 ID: 00000353 CMT PUBLIC ID: 0A2002078B417E569ADA4BBA5B85271E3C3D722B CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID: 191EC665DFAAF68F Flashing CMT Update Server Data, ULO: 0x3880 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x3CA00 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x4A9C0 bytes Update Server code succesfully sent to phone. Pooling for ADL device ... Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 1E9BD87B Verifying communication to device OK. Erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.422 s CMT NOR area [000006C0-0001FFFF] erased in 0.032 s CMT NOR area [00020000-0007FFFF] erased in 1.390 s CMT NOR area [00080000-000DFFFF] erased in 0.250 s CMT NOR area [00100000-001FFFFF] erased in 0.390 s CMT NOR area [00200000-0031FFFF] erased in 3.938 s CMT NOR area [00320000-0105FFFF] erased in 42.484 s CMT NOR area [01060000-01067FFF] erased in 0.390 s CMT NOR area [01068000-0107FFFF] erased in 0.016 s Flash programming ... CMT PAPUBKEYS: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 (RAP Certificate 52 v1) written. Programming completed in 1 min 40.265 s Processing PPM file: rm217__07.21.ppm_v [BB5,BB5 ALGORITHM] size: 5.13 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 5.50 MB CMT NOR area [01080000-015FFFFF] erased in 16.922 s Flash programming ... Programming completed in 37.031 s Processing CNT file: rm217__07.21.image_v [BB5,BB5 ALGORITHM] page size: 64 K size: 6.19 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 9.87 MB CMT NOR area [01600000-01FDFFFF] erased in 31.641 s Flash programming ... Programming completed in 42.938 s Total time for flashing process(boot+erase+write) was 5 min 20.828 s Pooling for ADL device ... Device found: nmwcdc\Nokia 6300 USB Generic, ID: 2A332B01 Verifying communication to device OK. Flashing completed in 6 min 4.500 s Phone Type: RM-217 (Nokia 6300) SW Version: V 07.21 05-11-08 RM-217 (c) Nokia. Imei plain: 35319103411877-8 Product Code: 0563812 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353191034118778 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
11-17-2010, 18:11 | #2614 (permalink) |
Member: 1423200 Status: Offline Thanks Meter: 53 | NOKIA 6280 UNLOCKED AND FULL FACTORY RESET Imei net: ********************** Version: SIMLOCK SERVER VERSION 62 Provider: Virgin, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000006 BLOCK 1: 1=LOCKED (MCC+MNC): 23430F, DATA=23430F Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V 03.60 10-02-06 RM-78 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.4 Completed in 11.349 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-78_359382001145977_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: **************** Version: SIMLOCK SERVER VERSION 62 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000006 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
11-18-2010, 12:58 | #2616 (permalink) |
Member: 1423200 Status: Offline Thanks Meter: 53 | NOKIA 3109C UNLOCKED AND FULL FACTORY RESET Imei net: ****************************** Version: SIMLOCK SERVER VERSION 63 Provider: Virgin, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23430F, DATA=23430F Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V 05.50 14-08-07 RM-274 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.4 Completed in 10.976 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-274_359540012439750_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: ********************* Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
11-18-2010, 21:26 | #2617 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Slovakia Age: 40
Member: 17405 Status: Offline Thanks Meter: 345 | N97 RM-507 to RM-505 succesfully converted MXKEY 3.4 rev 1.3 1. Backup Rpl /All section/ 2. Erase Flash 3. Flash with 22.0.110 RM-505 firmware 4. Restore Imei Quote:
11-19-2010, 08:00 | #2618 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Processing MCU file: rh112_003.100 [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00603239:2984DA60 Area [01000000-0100FFFF] erased in 1.328 s Area [01010000-013AFFFF] erased in 1 min 16.203 s Area [013B0000-013EFFFF] erased in 5.281 s Area [017C0000-017EFFFF] erased in 0.453 s Area [01FC0000-01FEFFFF] erased in 0.141 s Flash programming ... Programming completed in 17.921 s File Processed in 1 min 51.562 s Processing CNT file: rh1120_nai03.10aa [DCT4,DCT4 ALGORITHM] size: 132.75 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00603239:2984DA60 Area [01380000-013AFFFF] erased in 4.032 s Flash programming ... Programming completed in 1.109 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.594 s File Processed in 21.438 s Processing PPM file: rh112_003.10aa [DCT4,DCT4 ALGORITHM] size: 1.05 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00603239:2984DA60 Area [01240000-0124FFFF] erased in 1.500 s Area [01250000-0137FFFF] erased in 25.188 s Flash programming ... Programming completed in 8.047 s File Processed in 45.141 s Flashing completed in 2 min 58.203 s Phone Type: RH-112 SW Version: V 03.10 21-01-09 RH-112 (c) NMP Imei plain: 35828503980844-4 Product Code: 0562273 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: AA Language Pack: - not available. Imei net: 35828503980844 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN FULL FACTORY... Failed! Completed in 0.609 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 4.531 s |
11-19-2010, 09:07 | #2619 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | Nokia 5130c repair done!! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1FF001089F717D56AAF29E7392BAF2179C4511B0 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Processing MCU file: rm495__07.95.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21.00 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00040000-000BFFFF] CMT NOR area [000C0000-0013FFFF] CMT NOR area [00140000-0137FFFF] CMT NOR area [01380000-0151FFFF] erased in 1 min 42.422 s Flash programming ... CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written. Programming completed in 1 min 58.110 s Processing PPM file: rm495__07.95.ppm_mena_b [BB5,BB5 ALGORITHM] size: 6.31 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 35.844 s Flash programming ... Programming completed in 41.125 s Processing CNT file: rm495__07.95.image_mena_b_red [BB5,BB5 ALGORITHM] page size: 128 K size: 8.26 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34.00 MB CMT NOR area [01DC0000-0215FFFF] CMT NOR area [02160000-03FBFFFF] erased in 4 min 22.843 s Flash programming ... Programming completed in 51.985 s Total time for flashing process(boot+erase+write) was 10 min 20.046 s Flashing completed in 10 min 20.141 s Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 35932902847302-3 Product Code: 0572166 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359329028473023 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
11-19-2010, 13:13 | #2620 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | Succsessfully unlock done nokia e63 with mx-key Here is log: Phone Type: RM-450 (Nokia E63) SW Version: V ICPR71_08w44.1 30-10-08 RM-450 (c) Nokia Imei plain: 35931802075877-0 Product Code: 0583677 ApeCoreSw: 100.21.110 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359318020758770 Version: SIMLOCK SERVER Provider: Hutchinson 3G, Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050600042465540 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 50506F, DATA=50506F BLOCK 2: 1=LOCKED (MCC+MNC): 50599F, DATA=50599F BLOCK 3: 1=LOCKED (MCC+MNC): 50506F, DATA=50506F BLOCK 4: 1=LOCKED (MCC+MNC): 50599F, DATA=50599F BLOCK 5: 1=LOCKED (MCC+MNC): 00101F, DATA=00101F BLOCK 6: 1=LOCKED (MCC+MNC): 00101F, DATA=00101F Imei net: 359318020758770 Version: SIMLOCK SERVER Provider: Hutchinson 3G, Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050600042465540 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 50506F, DATA=50506F BLOCK 2: 1=LOCKED (MCC+MNC): 50599F, DATA=50599F BLOCK 3: 1=LOCKED (MCC+MNC): 50506F, DATA=50506F BLOCK 4: 1=LOCKED (MCC+MNC): 50599F, DATA=50599F BLOCK 5: 1=LOCKED (MCC+MNC): 00101F, DATA=00101F BLOCK 6: 1=LOCKED (MCC+MNC): 00101F, DATA=00101F Backup saved to "BB5_35931802075877_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V ICPR71_08w44.1 30-10-08 RM-450 (c) Nokia ApeCoreSw: 100.21.110 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 Calculating NCK using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.4 #pw+ 313486602562555 +1 # #pw+ 810805835183879 +2 # #pw+ 676001571680344 +3 # #pw+ 433794889862813 +4 # #pw+ 037431223016023 +5 # #pw+ 369912435480561 +6 # #pw+ 884697700791029 +7 # Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Completed in 32.344 s Restarting phone ... Reading Simlock info ... Imei net: 359318020758770 Version: SIMLOCK SERVER Provider: Hutchinson 3G, Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050600042465540 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN, DATA=50506F BLOCK 2: 1=OPEN, DATA=50599F BLOCK 3: 1=OPEN, DATA=50506F BLOCK 4: 1=OPEN, DATA=50599F BLOCK 5: 1=OPEN, DATA=00101F BLOCK 6: 1=OPEN, DATA=00101F Br: Harkishan |
The Following 3 Users Say Thank You to Harkishan singh For This Useful Post: |
11-20-2010, 07:30 | #2621 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | 3110c CS repair done Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35934302050711-8 Product Code: 0566963 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359343020507118 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[1470011483BD7D5632A768C81BA23931FDA1458D] ... Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.4 Completed in 3.562 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-237_359343020507118_SD.RPL" Updating SUPERDONGLE_KEY ...OK Imei net: 359343020507118 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[1470011483BD7D5632A768C81BA23931FDA1458D] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.4 Completed in 3.656 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-237_359343020507118_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: 359343020507118 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.4 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[1470011483BD7D5632A768C81BA23931FDA1458D] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 86 bytes written. - Key: 18, size 86 bytes written. - Key: 20, size 86 bytes written. - Key: 25, size 4 bytes written. - Key: 29, size 6 bytes written. - Key: 34, size 80 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 2.922 s Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35934302050711-8 Product Code: 0566963 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359343020507118 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
11-20-2010, 07:32 | #2622 (permalink) |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | 7210 CS repair done Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 122001046AC27D564F6B67761E0C5E1F2246CB73 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Original Imei: 35523103361711 Original Product code: 0581686 Bluetooth ID: 002668894F0C Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35523103361711-1 Product Code: 0572571 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.4 Using device: AdvanceBox Turbo Flasher Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[122001046AC27D564F6B67761E0C5E1F2246CB73] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 12 bytes written. - Key: 2, size 70 bytes written. - Key: 3, size 70 bytes written. - Key: 4, size 70 bytes written. - Key: 6, size 276 bytes written. - Key: 7, size 256 bytes written. - Key: 10, size 384 bytes written. - Key: 11, size 384 bytes written. - Key: 14, size 384 bytes written. - Key: 17, size 32 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 2.062 s |
11-20-2010, 07:33 | #2623 (permalink) |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | another 7210 cs done Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 06.51 23-03-09 RM-436 (c) Nokia Imei plain: 35523103320666-7 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V 06.51 23-03-09 RM-436 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.4 Completed in 11.594 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_355231033206667_SD.RPL" Updating SUPERDONGLE_KEY ...OK SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V 06.51 23-03-09 RM-436 (c) Nokia Using cached productData[1230010FAD7B7D5609435A7C7689927795F6483C] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.4 Completed in 3.547 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_355231033206667_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: 355231033206667 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.4 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V 06.51 23-03-09 RM-436 (c) Nokia Using cached productData[1230010FAD7B7D5609435A7C7689927795F6483C] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 12 bytes written. - Key: 2, size 70 bytes written. - Key: 3, size 70 bytes written. - Key: 4, size 70 bytes written. - Key: 6, size 276 bytes written. - Key: 7, size 256 bytes written. - Key: 10, size 384 bytes written. - Key: 11, size 384 bytes written. - Key: 14, size 384 bytes written. - Key: 17, size 32 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 1.672 s Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 06.51 23-03-09 RM-436 (c) Nokia Imei plain: 35523103320666-7 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355231033206667 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
11-20-2010, 10:01 | #2624 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | 7210s Flash Done with Dead USB Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Processing MCU file: rm436__07.23.mcusw [BB5,BB5 ALGORITHM] size: 18.06 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 884E308 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 16F00102719A7C5600C9A3147ADC668F97FF967D CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4AD00 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59700 bytes Update Server code succesfully sent to phone. Pooling for ADL device ... Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 3095A942 Verifying communication to device OK. Erase size: 19.12 MB CMT NOR area [00000000-000006BF] erased in 0.625 s CMT NOR area [000006C0-0001FFFF] erased in 0.609 s CMT NOR area [00040000-000BFFFF] erased in 2.516 s CMT NOR area [000C0000-0013FFFF] erased in 2.078 s CMT NOR area [00140000-0119FFFF] erased in 1 min 22.797 s CMT NOR area [011A0000-0133FFFF] erased in 7.937 s Flash programming ... CMT PAPUBKEYS: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 (RAP Certificate 142 v.1) written. Programming completed in 1 min 7.140 s Processing PPM file: rm436__07.23.ppm_me [BB5,BB5 ALGORITHM] size: 6.14 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01340000-01BDFFFF] erased in 40.391 s Flash programming ... Programming completed in 22.938 s Processing CNT file: rm436__07.23.image_me [BB5,BB5 ALGORITHM] page size: 128 K size: 20.52 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 35.87 MB CMT NOR area [01BE0000-01F7FFFF] erased in 23.765 s CMT NOR area [01F80000-03FBFFFF] erased in 3 min 48.312 s Flash programming ... Programming completed in 1 min 18.328 s Total time for flashing process(boot+erase+write) was 9 min 35.109 s Pooling for ADL device ... Device found: nmwcdc\Nokia 7210 Supernova USB Generic, ID: 166D4186 Verifying communication to device OK. Flashing completed in 10 min 23.578 s Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35931002899951-4 Product Code: 0566913 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359310028999514 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Nokia USB ROM detached. |
11-20-2010, 10:21 | #2625 (permalink) |
No Life Poster Join Date: May 2008 Location: saqi mobiles pirmahal pakistan Age: 37
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | 1661 unlock done Imei net: 35691603****** Version: SIMLOCK SERVER Provider: Vodafone, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341500000000000 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 23415F Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.4 [CR1]DCT4PLUS remaining credit: 32 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-122_35691603******_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35691603****** Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to saqi160 For This Useful Post: |
