11-08-2010, 18:15 | #2566 (permalink) |
Insane Poster Join Date: Mar 2007 Location: my house
Member: 468581 Status: Offline Thanks Meter: 4,294,967,293 | 5000d revive Code: Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.8986(19-10-2010), 1.0.0.14852(19-10-2010) RPL saved to "C:\mobileEx\3.4\data\backup\35679702672166_BACK.rpl" Processing MCU file: rm362__05.45.mcusw [DCT4,DCT4 ALGORITHM] size: 11.83 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 005EFB38:3B8ADA60 Area [01000000-0101FFFF] erased in 0.578 s Area [01020000-01BFFFFF] erased in 57.125 s Flash programming ... Programming completed in 4 min 15.312 s File Processed in 5 min 29.578 s Processing CNT file: rm362__04.89_ISM_002.image_ad_blu_de_ctv_de_nblue [DCT4,DCT4 ALGORITHM] page size: 128 K size: 5.75 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 005EFB38:C5A4DA78 Area [02180000-02E7FFFF] erased in 1 min 9.391 s Area [02E80000-02FBFFFF] erased in 7.250 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 2 min 5.297 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.094 s File Processed in 4 min 11.375 s Processing PPM file: rm362__05.45.ppm_ad [DCT4,DCT4 ALGORITHM] size: 4.01 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 005EFB38:2984DA60 Area [01C00000-0217FFFF] erased in 27.203 s Flash programming ... Programming completed in 1 min 31.015 s File Processed in 2 min 14.656 s Flashing completed in 11 min 58.938 s Phone Type: RM-362 (Nokia 5000d-2) SW Version: V 05.45 11-12-08 RM-362 (c) Nokia Imei plain: 35679702672166-3 Imei OTP: 35679702672166 Product Code: 0568255 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: AD Language Pack: - not available. Imei net: 35679702672166 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
11-08-2010, 18:49 | #2567 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Mongolia
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | C5-00 USB flashing OK. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Processing MCU file: rm645_032.010_prd.core.fpsx [BB5,XSR 1.6] size: 90.95 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 39550E9E CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 18A0010691BF0D4914FEE3506AD877911DA8EA8F CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Pooling for ADL device OK. Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 39550E9E Verifying communication to device OK. CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Storing certificate [NPC, CCC, HWC, R&D] ... Partitioning.... Partitioning complete Erase size: 170.06 MB Flash programming ... CMT PAPUBKEYS: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 (RAP Certificate v1 249) written. Programming completed in 17.891 s Processing PPM file: rm645_032.010_05.01_Russian_prd.rofs2.fpsx [BB5,XSR 1.6] size: 48.07 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 51.00 MB Flash programming ... Programming completed in 8.500 s Processing PPM file: rm645_032.010_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 7.94 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 14.00 MB Flash programming ... Programming completed in 0.016 s Processing CNT file: rm645_032.010_U000.000_prd.uda.fpsx [BB5,XSR 1.6] size: 1.76 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 72.00 MB Flash programming ... Programming completed in 0.719 s Processing CNT file: rm645_ENO_v_0.NCP17_APEONLY.fpsx [BB5,XSR 1.6] size: 2.35 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 4.00 MB Flash programming ... Programming completed in 0.422 s Total time for flashing process(boot+erase+write) was 1 min 10.281 s Pooling for ADL device ... Device found: nmwcdc\Nokia C5-00 USB Generic, ID: FCCC88A Verifying communication to device OK. Flashing completed in 1 min 50.250 s Phone Type: RM-645 (Nokia C5-00) SW Version: V ICPR82_10w18.5.2 16-07-10 RM-645 (c) Nokia Imei plain: 35934503287551-6 Product Code: 059C568 ApeCoreSw: 032.010 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359345032875516 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
11-08-2010, 20:48 | #2568 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Venezuela Age: 37
Member: 1165060 Status: Offline Sonork: 100.1615792 Thanks Meter: 75 | Imei net: 359348024121337 Version: SIMLOCK SERVER Counter: 2/3, 0/10 CONFIG_DATA: 7340600082413968 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 73406F, DATA=73406F BLOCK 2: 1=LOCKED (MCC+MNC): 73406F, DATA=73406F Backup saved to "BB5_35934802412133_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V ICPR72_10w21.4 19-07-10 RM-428 (c) Nokia ApeCoreSw: V 51.2.007 Using cached productData[0CD00006D1D98A52A540C381FDAA70F7DD27AED3] ... Calculating NCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3 #pw+ 079948982718722 +1 # #pw+ 747230442814632 +2 # #pw+ 933908217985983 +3 # #pw+ 774623613382779 +4 # #pw+ 043283224687352 +5 # #pw+ 360163730870361 +6 # #pw+ 493245264350524 +7 # Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Completed in 18.625 s Restarting phone ... Reading Simlock info ... Imei net: 359348024121337 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 7340600082413968 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN, DATA=73406F BLOCK 2: 1=OPEN, DATA=73406F |
11-08-2010, 20:56 | #2569 (permalink) |
Member: 1165060 Status: Offline Sonork: 100.1615792 Thanks Meter: 75 | Imei net: 359348024121808 Version: SIMLOCK SERVER Provider: Movilnet, Country: Venezuela Counter: 1/3, 0/10 CONFIG_DATA: 7340600082413968 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 73406F, DATA=73406F BLOCK 2: 1=LOCKED (MCC+MNC): 73406F, DATA=73406F Backup saved to "BB5_35934802412180_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V ICPR72_09w06.2 03-03-09 RM-428 (c) Nokia ApeCoreSw: V 21.2.025 Using cached productData[0A600014D1D98A524323FCABDE5454E10601F700] ... Calculating NCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3 #pw+ 347208335418878 +1 # #pw+ 906981544852740 +2 # #pw+ 612006099175765 +3 # #pw+ 265928539271218 +4 # #pw+ 126470044106398 +5 # #pw+ 116059795865920 +6 # #pw+ 701760310342432 +7 # Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Completed in 13.531 s Restarting phone ... Reading Simlock info ... Imei net: 359348024121808 Version: SIMLOCK SERVER Provider: Movilnet, Country: Venezuela Counter: 0/3, 0/10 CONFIG_DATA: 7340600082413968 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN, DATA=73406F BLOCK 2: 1=OPEN, DATA=73406F |
11-09-2010, 03:46 | #2570 (permalink) |
Freak Poster Join Date: Dec 2009 Location: asia's latin zamboanga city
Member: 1184999 Status: Offline Thanks Meter: 63 | 7210c succesfully flash with fbus.. mxkey version 3.4 rev 1.5 heres the logs.. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Processing MCU file: rm436__07.23.mcusw [BB5,BB5 ALGORITHM] size: 18.06 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 14300206B27D5750AD028DF1743AB017D1542451 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 19.12 MB CMT NOR area [00000000-000006BF] erased in 0.593 s CMT NOR area [000006C0-0001FFFF] erased in 0.157 s CMT NOR area [00040000-000BFFFF] erased in 2.203 s CMT NOR area [000C0000-0013FFFF] erased in 0.219 s CMT NOR area [00140000-0119FFFF] erased in 1 min 6.125 s CMT NOR area [011A0000-0133FFFF] erased in 6.875 s Flash programming ... CMT PAPUBKEYS: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 (RAP Certificate 142 v.1) written. Programming completed in 2 min 25.719 s Processing PPM file: rm436__07.23.ppm_i [BB5,BB5 ALGORITHM] size: 7.40 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 14300206B27D5750AD028DF1743AB017D1542451 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Erase size: 8.62 MB CMT NOR area [01340000-01BDFFFF] erased in 25.922 s Flash programming ... Programming completed in 57.344 s Processing CNT file: rm436__07.23.image_i [BB5,BB5 ALGORITHM] page size: 128 K size: 22.15 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 14300206B27D5750AD028DF1743AB017D1542451 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Erase size: 35.87 MB CMT NOR area [01BE0000-01F7FFFF] erased in 21.375 s CMT NOR area [01F80000-03FBFFFF] erased in 2 min 50.359 s Flash programming ... Programming completed in 2 min 50.922 s Total time for flashing process(boot+erase+write) was 11 min 55.110 s Flashing completed in 12 min 17.344 s Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35574302428012-1 Product Code: 0566807 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355743024280121 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
11-09-2010, 08:34 | #2571 (permalink) |
Freak Poster Join Date: Sep 2009 Location: Sri Lanka
Member: 1109931 Status: Offline Sonork: Bongo Thanks Meter: 44 | Successfully Flashed 2730... Version from phone: 10.40 Version from file: 10.45 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010) Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35339604274531_BA CK.rpl). Processing MCU file: rm578__10.45.mcusw [BB5,BB5 ALGORITHM] size: 21.65 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101023000 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0130010EC5CA0056BBFE2EE5C37C1D70715B3AB6 ASIC MODE ID: 00 ROOT KEY HASH:XXXXXXXX6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1 TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 23.25 MB CMT NOR area [00000000-000006BF] erased in 0.687 s CMT NOR area [000006C0-0001FFFF] erased in 0.218 s CMT NOR area [00040000-000BFFFF] erased in 2.359 s CMT NOR area [000C0000-0013FFFF] erased in 0.234 s CMT NOR area [00140000-0155FFFF] erased in 1 min 31.031 s CMT NOR area [01560000-0175FFFF] erased in 9.812 s Flash programming ... CMT PAPUBKEYS: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1 (RAP Certificate 215 v1) written. Programming completed in 3 min 4.094 s Processing PPM file: rm578__10.45.ppm_m_a [BB5,BB5 ALGORITHM] size: 5.29 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101023000 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0130010EC5CA0056BBFE2EE5C37C1D70715B3AB6 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1 TransmissionMode: DDR&TX2 Erase size: 8.62 MB CMT NOR area [01760000-01FFFFFF] erased in 25.266 s Flash programming ... Programming completed in 44.235 s Processing CNT file: rm578__10.45.image_m_a_red [BB5,BB5 ALGORITHM] page size: 128 K size: 12.14 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101023000 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0130010EC5CA0056BBFE2EE5C37C1D70715B3AB6 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1 TransmissionMode: DDR&TX2 Erase size: 31.75 MB CMT NOR area [02000000-0245FFFF] erased in 26.968 s CMT NOR area [02460000-03FBFFFF] erased in 2 min 51.890 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 1 min 43.360 s Total time for flashing process(boot+erase+write) was 11 min 26.250 s Flashing completed in 11 min 29.563 s Phone Type: RM-578 (Nokia 2730 classic) SW Version: V 10.45 05-07-10 RM-578 (c) Nokia Imei plain: 35339XXXXXXXXX-X Product Code: 058XXXX Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35339XXXXXXXXXX Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
11-09-2010, 11:54 | #2572 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Processing MCU file: rm240__09.60.mcusw [BB5,BB5 ALGORITHM] size: 20.36 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1E727ECF CMT SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 15D00103F85D025411B44400E6084DEB758ECA5F CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x46F40 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x55500 bytes Update Server code succesfully sent to phone. Pooling for ADL device ... Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 6AC5CE2 Verifying communication to device OK. Erase size: 21.87 MB CMT NOR area [00000000-0001FFFF] erased in 0.578 s CMT NOR area [00040000-000BFFFF] erased in 2.438 s CMT NOR area [000C0000-0013FFFF] erased in 0.187 s CMT NOR area [01480000-015FFFFF] erased in 7.766 s CMT NOR area [00140000-0147FFFF] erased in 1 min 30.969 s Flash programming ... CMT PAPUBKEYS: A69838E8C5F20150E64E2E6E06DE6E50B26B593F (RAP Certificate 84 v1) written. Programming completed in 2 min 12.125 s Processing PPM file: rm240__09.60.ppm_m4 [BB5,BB5 ALGORITHM] size: 4.96 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 6.75 MB CMT NOR area [01600000-01CBFFFF] erased in 26.828 s Flash programming ... Programming completed in 34.750 s Processing CNT file: rm240__09.60_ISM_004.image_4_brown [BB5,BB5 ALGORITHM] page size: 128 K size: 10.39 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 34.87 MB CMT NOR area [01FC0000-03F9FFFF] erased in 2 min 39.719 s CMT NOR area [01CC0000-01FBFFFF] erased in 16.906 s Flash programming ... Programming completed in 1 min 8.375 s Total time for flashing process(boot+erase+write) was 9 min 24.985 s Pooling for ADL device ... Device found: nmwcdc\Nokia 6500 slide USB Generic, ID: 39793454 Verifying communication to device OK. Flashing completed in 10 min 4.609 s Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 09.60 21-11-08 RM-240 (c) Nokia Imei plain: 35202702337422-3 Product Code: 0549726 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352027023374223 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000002 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Nokia USB ROM detached. |
11-09-2010, 12:12 | #2573 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | 1650 imei chang done with mx PhoneType:RM-305 SwVersion: V 4.11 10-11-07 RM-305 (c) NMP MCU file: rm305_04.110 Trying to find patch position ...OK, case id: 3 New Imei: 359563001016226 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0094BD65:2984DA60 Area [01000000-0101FFFF] erased in 0.563 s Area [01160000-0117FFFF] erased in 0.484 s Area [011E0000-011FFFFF] erased in 0.547 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 38.078 s Phone Type: RM-305 SW Version: V 4.11 10-11-07 RM-305 (c) NMP Imei plain: 35956300101622-3 Product Code: 0549965 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35956300101622 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
11-09-2010, 14:48 | #2574 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | 5130 flashing done Programming completed in 1 min 5.984 s Processing PPM file: rm495__07.95.ppm_mena_b [BB5,BB5 ALGORITHM] size: 6.31 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 46.469 s Flash programming ... Programming completed in 22.906 s Processing CNT file: rm495__07.95.image_mena_b_red [BB5,BB5 ALGORITHM] page size: 128 K size: 8.26 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34.00 MB CMT NOR area [01DC0000-0215FFFF] erased in 24.579 s CMT NOR area [02160000-03FBFFFF] erased in 3 min 26.781 s Flash programming ... Programming completed in 29.375 s Total time for flashing process(boot+erase+write) was 8 min 49.047 s Pooling for ADL device ... Device found: nmwcdc\Nokia 5130 XPressMusic USB Generic, ID: 7685E08 Verifying communication to device OK. Flashing completed in 9 min 40.078 s Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 3593%%%%%%%%% Product Code: 0576616 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3593%%%%%%%%% Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Nokia USB ROM detached. |
11-09-2010, 16:23 | #2575 (permalink) |
No Life Poster Join Date: Oct 2004 Location: AL-SATWA DUBAI U.A.E Age: 45
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | Nokia 5610d unlocked successfully Imei net: 358952018560961 Version: SIMLOCK SERVER Provider: Orange + France Telecom Itineris, Country: France Counter: 0/3, 0/10 CONFIG_DATA: 2080100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 20801F, DATA=20801F Backup saved to "BB5_35895201856096_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010) Product: V 07.12 28-05-08 RM-242 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Calculating NCK using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 #pw+ 835559314489483 +1 # #pw+ 597995685421415 +2 # #pw+ 747624906252879 +3 # #pw+ 102461460950678 +4 # #pw+ 991127155787280 +5 # #pw+ 213733432619039 +6 # #pw+ 451349862370042 +7 # Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Completed in 28.234 s Restarting phone ... Reading Simlock info ... Imei net: 358952018560961 Version: SIMLOCK SERVER Provider: Orange + France Telecom Itineris, Country: France Counter: 0/3, 0/10 CONFIG_DATA: 2080100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=20801F |
The Following User Says Thank You to Ramzan For This Useful Post: |
11-10-2010, 06:07 | #2576 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2010 Age: 36
Member: 1216626 Status: Offline Sonork: 100.1605357 Thanks Meter: 196 | N5000 unlock done[smart provider TOOLS MXKEY EASY CABLE UFS AS INTERFACE PROCEDURE BUS CHECK FIRST [IMG]http://www.****************/images/statusicon/wol_error.gif[/IMG]This image has been resized. Click this bar to view the full image. The original image is sized 800x574. LOGS Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004120A4A3BDA66 ASIC type: 11 UEM Imei: 35484002381513 Phone Type: RM-362 (Nokia 5000d-2) SW Version: V 04.89 13-08-08 RM-362 (c) Nokia Imei plain: 35484002381513-8 Imei OTP: 35484002381513 Product Code: 0566560 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: T Language Pack: - not available. Imei net: 35484002381513 Version: SIMLOCK SERVER Provider: Smart Communications, Country: Philippines Counter: 0/3, 0/10 CONFIG_DATA: 5150300000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 51503F UNLOCKING PROCEDURE SEE PICTURE [IMG]http://www.****************/images/statusicon/wol_error.gif[/IMG]This image has been resized. Click this bar to view the full image. The original image is sized 800x574. LOGS Code: Imei net: 35484002381513 Version: SIMLOCK SERVER Provider: Smart Communications, Country: Philippines Counter: 0/3, 0/10 CONFIG_DATA: 5150300000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 51503F Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-362_35484002381513_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35484002381513 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN FINISH PRODUCT NOTE:FOR REFERENCE SA NEW USER NG MXKEY |
11-10-2010, 10:06 | #2577 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Nokia 1650 repair done!! Phone Type: RM-305 SW Version: V 5.06 12-01-08 RM-305 (c) NMP Imei plain: 35291102035785-3 Product Code: 0547568 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. TimeStamp: 2008-11-20T10:10:20Z SW Version: 5.80 Variant Version: 001 ProductProfile: RM305_0547568_5.80_001.spr Simlock: 0547568_SimLockDataVerifier_vDCT4.sim Imei net: 35291102035785 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! Imei net: 35291102035785 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-305_35291102035785_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35291102035785 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
11-10-2010, 20:32 | #2578 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algeria
Member: 574410 Status: Offline Thanks Meter: 93 | 6670 rh-67 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0200 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 00C0B7AF:2984DA7E ASIC type: 5 UEM Imei: 35433000066619 Flash Imei: 35433000066619 RPL saved to "D:\mobileEx\3.4\data\backup\RPL\35433000066619_BA CK.rpl" Processing MCU file: RH51_52_67_68PE605220.C1 [WD2 BT2,WD2 ALGORITHM] size: 24.51 MB Supported Ids: 0082, 1081 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0200 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 00C0B7AF:2984DA7E Area [00000000-0000FFFF] erased in 0.734 s Area [00010000-00FFFFFF] erased in 2 min 59.235 s Area [02000000-0287FFFF] erased in 1 min 19.140 s Area [02FC0000-02FEFFFF] erased in 1.906 s Flash programming ... Programming completed in 7 min 41.219 s File Processed in 12 min 22.579 s Processing PPM file: RH67PE605220.03 [WD2 BT2,WD2 ALGORITHM] size: 3.05 MB Supported Ids: 0082, 1081 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 00C0B7AF:2984DA7E Area [00000000-0000FFFF] erased in 0.687 s Area [02A00000-02CFFFFF] erased in 28.015 s Flash programming ... Programming completed in 50.109 s File Processed in 1 min 38.875 s Flashing completed in 14 min 42.297 s Phone Type: RH-67 (Nokia 6670) SW Version: V 2005_wk21 27-05-05 RH-67 (c) Nokia. Imei plain: 35433000066619-1 Product Code: 0520209 Cellular System: GSM ASIC ID: 0x1081, type: 5 Ppm Id: 03 Language Pack: English,French,Arabic Imei net: 35433000066619 Version: SIMLOCKLIB VERSION 2.29 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000005 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
11-11-2010, 09:13 | #2579 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Code: Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Processing MCU file: rm249__05.21.mcusw [BB5,BB5 ALGORITHM] size: 15.87 MB Supported Ids: 0103192101001101, 010C192101001101 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 135D3B48 CMT SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 0CE00104E3826C5674CC3F0F0CFFF623B3B30470 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID: 191EC665DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x466C0 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x545C0 bytes Update Server code succesfully sent to phone. Pooling for ADL device ... Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 4161BA5 Verifying communication to device OK. Erase size: 17.00 MB CMT NOR area [00000000-000006BF] erased in 0.344 s CMT NOR area [000006C0-0001FFFF] erased in 0.015 s CMT NOR area [00040000-000BFFFF] erased in 1.375 s CMT NOR area [000C0000-0013FFFF] erased in 0.094 s CMT NOR area [01000000-0111FFFF] erased in 3.187 s CMT NOR area [00140000-00FFFFFF] erased in 39.516 s Flash programming ... CMT PAPUBKEYS: 3D744C60D026865F8B384F71E83AA7A06FC12277 (RAP Certificate 72 v1) written. Programming completed in 1 min 46.969 s Processing PPM file: rm249__05.21.ppm_w [BB5,BB5 ALGORITHM] size: 5.71 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 6.37 MB CMT NOR area [01120000-0177FFFF] erased in 13.672 s Flash programming ... Programming completed in 40.719 s Processing CNT file: rm249__05.21.image_w_ny [BB5,BB5 ALGORITHM] page size: 64 K size: 8.82 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 40.25 MB CMT NOR area [01780000-018FFFFF] erased in 4.031 s CMT NOR area [01900000-03FBFFFF] erased in 1 min 43.844 s Flash programming ... Programming completed in 54.625 s Total time for flashing process(boot+erase+write) was 6 min 24.031 s Pooling for ADL device ... Device found: nmwcdc\Nokia 7500 Prism USB Generic, ID: 307D7143 Verifying communication to device OK. Flashing completed in 7 min 9.266 s Phone Type: RM-249 (Nokia 7500) SW Version: V 05.21 19-03-08 RM-249 (c) Nokia Imei plain: 35644001302829-3 Product Code: 0551735 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356440013028293 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Nokia USB ROM detached. WBR sahil2000ind |
11-11-2010, 12:29 | #2580 (permalink) |
Freak Poster Join Date: Feb 2008 Location: royal mobiles kotla
Member: 714116 Status: Offline Thanks Meter: 48 | 6103 unlocked Imei net: 35226901097017 Version: SIMLOCK SERVER VERSION 58 Provider: T-Mobile, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 8000000000000002 BLOCK 1: 1.LOCKED (MCC+MNC): 20416F BLOCK 2: 1.LOCKED (MCC+MNC): 21630F BLOCK 3: 1.LOCKED (MCC+MNC): 21901F BLOCK 4: 1.LOCKED (MCC+MNC): 23001F BLOCK 5: 1.LOCKED (MCC+MNC): 23102F BLOCK 6: 1.LOCKED (MCC+MNC): 23203F BLOCK 7: 1.LOCKED (MCC+MNC): 23430F BLOCK 8: 1.LOCKED (MCC+MNC): 25001F BLOCK 9: 1.LOCKED (MCC+MNC): 25502F BLOCK 10: 1.LOCKED (MCC+MNC): 26002F BLOCK 11: 1.LOCKED (MCC+MNC): 26201F BLOCK 12: 1.LOCKED (MCC+MNC): 310160 BLOCK 13: 1.LOCKED (MCC+MNC): 310200 BLOCK 14: 1.LOCKED (MCC+MNC): 310210 BLOCK 15: 1.LOCKED (MCC+MNC): 310220 BLOCK 16: 1.LOCKED (MCC+MNC): 310230 BLOCK 17: 1.LOCKED (MCC+MNC): 310240 BLOCK 18: 1.LOCKED (MCC+MNC): 310250 BLOCK 19: 1.LOCKED (MCC+MNC): 310260 BLOCK 20: 1.LOCKED (MCC+MNC): 310270 BLOCK 21: 1.LOCKED (MCC+MNC): 310280 BLOCK 22: 1.LOCKED (MCC+MNC): 310300 BLOCK 23: 1.LOCKED (MCC+MNC): 310310 BLOCK 24: 1.LOCKED (MCC+MNC): 310580 BLOCK 25: 1.LOCKED (MCC+MNC): 310660 BLOCK 26: 1.LOCKED (MCC+MNC): 310800 Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35226901097017 Version: SIMLOCK SERVER VERSION 58 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
