11-06-2010, 09:25 | #2551 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Nokia 2690 USB Flash Done!!! Processing file: rm635__10.10.mcusw as MCU [BB5,BB5 ALGORITHM] size: 17.99 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2D05289F RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM0 ID: 00000296 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 1B400202F083005695E78879CF7B6A741EB49123 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x49480 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x57AC0 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 8B7225F [ADL] Verifying communication to device OK. Erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.641 s CMT NOR area [000006C0-0001FFFF] erased in 0.672 s CMT NOR area [00040000-000BFFFF] erased in 2.187 s CMT NOR area [000C0000-0013FFFF] erased in 2.297 s CMT NOR area [00140000-0137FFFF] erased in 1 min 26.953 s CMT NOR area [01380000-0151FFFF] erased in 7.718 s Flash programming ... CMT PAPUBKEYS: C6B9354E81AC464DED33FC7B90295086150F4539 (RAP Certificate v1 246) written. Programming completed in 1 min 2.547 s Processing file: rm635__10.10.ppm_m_c as PPM [BB5,BB5 ALGORITHM] size: 3.09 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 39.500 s Flash programming ... Programming completed in 10.469 s Processing file: rm635__10.10.image_m_c_blue as CNT [BB5,BB5 ALGORITHM] page size: 128 K size: 6.38 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 34.00 MB CMT NOR area [01DC0000-0215FFFF] erased in 22.890 s CMT NOR area [02160000-03FBFFFF] erased in 3 min 14.360 s Flash programming ... Programming completed in 21.016 s [ADL] Restarting phone ... [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. [ADL] Phone flashing completed, but failed to verify communication to product! [ADL] Retrying in finalize phase... [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia 2690 USB Generic, ID: 2C8C9085 [ADL] Verifying communication to device OK. Flashing completed in 8 min 46.234 s Phone Type: RM-635 (Nokia 2690) SW Version: V 10.10 22-04-10 RM-635 (c) Nokia Imei plain: 35341004056643-6 Product Code: 0592535 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353410040566436 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 8 min 49.953 s |
11-06-2010, 10:26 | #2552 (permalink) |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C64E05:2984DA60 ASIC type: 2 UEM Imei: 35481901860599 Flash Imei: 35481901860599 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35481901860599_BA CK.rpl" Processing file: rm189_06.520 as MCU [DCT4,DCT4 ALGORITHM] size: 1.90 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C64E05:2984DA60 Area [01000000-0100FFFF] erased in 0.485 s Area [01010000-013BFFFF] erased in 27.031 s Area [013C0000-013EFFFF] erased in 1.640 s Area [017C0000-017EFFFF] erased in 0.156 s Area [01FC0000-01FEFFFF] erased in 0.156 s Flash programming ... Programming completed in 14.579 s File Processed in 53.610 s Processing file: rm1890_nai6.52ic as CNT [DCT4,DCT4 ALGORITHM] size: 184.62 KB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C64E05:2984DA60 Area [01380000-013BFFFF] erased in 1.891 s Flash programming ... Programming completed in 1.437 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.312 s File Processed in 17.797 s Processing file: rm189_06.52ic as PPM [DCT4,DCT4 ALGORITHM] size: 1.27 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C64E05:2984DA60 Area [011E0000-011EFFFF] erased in 0.469 s Area [011F0000-0137FFFF] erased in 11.360 s Flash programming ... Programming completed in 10.375 s File Processed in 34.156 s Flashing completed in 2 min 8.469 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RM-189 SW Version: V 6.52 11-12-07 RM-189 (c) NMP Imei plain: 35481901860599-3 Product Code: 0534953 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: IC Language Pack: English,Arabic,French,Swahili Imei net: 35481901860599 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.CORRUPTED (00) 4.CORRUPTED (00) 5.CORRUPTED (00) BLOCK 7: 1.CORRUPTED (00) 2.CORRUPTED (00) 3.CORRUPTED (00) 4.CORRUPTED (00) 5.CORRUPTED (00) Total time to process is 2 min 19.469 s Saqib-Ghazi |
11-06-2010, 11:18 | #2553 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Another 3110c flashed by usb Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010) Processing file: rm237__07.30.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.49 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3 RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] RAP EM0 ID: 00000232 RAP EM1 ID: 00000353 RAP PUBLIC ID: 2730010EFF126B56D268819439A7156F03427339 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP ROM ID: 191EC665DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x38C0 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: B8C892C [ADL] Verifying communication to device OK. Erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.546 s CMT NOR area [000006C0-0001FFFF] erased in 0.563 s CMT NOR area [00020000-0007FFFF] erased in 1.437 s CMT NOR area [00080000-000DFFFF] erased in 1.672 s CMT NOR area [00100000-001FFFFF] erased in 4.438 s CMT NOR area [00200000-0031FFFF] erased in 4.672 s CMT NOR area [00320000-0105FFFF] erased in 58.157 s CMT NOR area [01060000-01067FFF] erased in 0.562 s CMT NOR area [01068000-0107FFFF] erased in 0.563 s Flash programming ... CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written. Programming completed in 1 min 13.156 s Processing file: rm237__07.30.ppm_c as PPM [BB5,BB5 ALGORITHM] size: 3.75 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Erase size: 4.62 MB CMT NOR area [01080000-0151FFFF] erased in 19.468 s Flash programming ... Programming completed in 19.141 s Processing file: rm237__07.30.image_c_tr as CNT [BB5,BB5 ALGORITHM] page size: 64 K size: 3.69 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Erase size: 10.75 MB CMT NOR area [01520000-01FDFFFF] erased in 47.969 s Flash programming ... Programming completed in 18.563 s [ADL] Restarting phone ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia 3110 classic USB Generic, ID: 35B14E44 [ADL] Verifying communication to device OK. Flashing completed in 4 min 47.375 s Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35553501373455-9 Product Code: 0514951 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355535013734559 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 4 min 50.875 s |
11-06-2010, 11:51 | #2554 (permalink) |
No Life Poster Join Date: Nov 2007 Location: UK
Member: 629391 Status: Offline Thanks Meter: 397 | Nokia 5800 success unlock by Mxkey Imei net: 35933903403xxxx Version: SIMLOCK SERVER Provider: Orange, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23433F, DATA=23433F BLOCK 2: 1=LOCKED (MCC+MNC): 23486F, DATA=23486F Backup saved to "BB5_3593390340xxxx_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8986(19-10-2010), 1.0.0.14852(19-10-2010) Product: V ICPR72_09w20.12 10-09-09 RM-356 (c) Nokia ApeCoreSw: V 31.0.101 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Calculating NCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3 #pw+ 791212787173662 +1 # #pw+ 920642044092016 +2 # #pw+ 549167185396405 +3 # #pw+ 631895600778709 +4 # #pw+ 650153308609399 +5 # #pw+ 407503222864936 +6 # #pw+ 163829222050330 +7 # Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Completed in 29.015 s Restarting phone ... Reading Simlock info ... Imei net: 35933903403xxxx Version: SIMLOCK SERVER Provider: Orange, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=23433F BLOCK 2: 1=OPEN, DATA=23486F |
11-06-2010, 13:35 | #2555 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | Nokia 1616 Flash Done!!! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK Boot mode: CC EBL version: 10.19, Default_RAM_Bootloader Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] Processing CODE:hw_f11_rh125_r04.650.fls from file rh125_004.650 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 32.844 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 31.094 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.031 s Checksum OK (0xF21F) Processing CUST:hw_f11_rh125_004.65ia.fls from file rh125_004.65ia Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 30.937 s Checksum OK (0xE00E) Processing CUST:hw_f11_rh1250_nai04.65ia.fls from file rh1250_nai04.65ia Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 5.313 s Checksum OK (0xCBB5) Flashing completed in 2 min 36.079 s Phone Type: RH-125 SW Version: V 04.65 24-04-10 RH-125 (c) Nokia Imei plain: 35823403679537-8 Product Code: 0588625 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35823403679537 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 2 min 48.407 s |
11-06-2010, 17:58 | #2556 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 898963 Status: Offline Thanks Meter: 69 | succes flashing x3 with mx key Library version: 1.0.0.8986(19-10-2010), 1.0.0.14639(29-09-2010) Processing file: rm540__08.40.mcusw as MCU [BB5,XSR 1.6] size: 26.07 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 193352DF RAP SYSTEM ASIC ID: 000000010000022600000001020C192102054100 [RAPS2 ver: PA 4.x] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 0C600102D0320049294376413EC61FD19A1C4D3C RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D RAP ROM ID: 67E82268F29CEA60 [ADL] Loading CMT secondary boot code SecondaryBoot: rap3gv40_2nd.fg [BB5] version: 9.48.0 revision: 2.1 size: 0x3BC0 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP [ADL] Loading CMT update server data Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6] version: 9.48.0 revision: 2.1 size: 0x7E232 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Update server code loaded. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 193352DF [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 37.69 MB Flash programming ... CMT PAPUBKEYS: CEFA9C4100686F9FC9B1B3778774A19500706163 (RAP Certificate 193 v.1) written. Programming completed in 47.906 s Processing file: rm540__08.40.ppm_x as PPM [BB5,XSR 1.6] size: 6.85 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 8.87 MB Flash programming ... Programming completed in 12.390 s Processing file: rm540__08.40.image_x_0581106_003 as CNT [BB5,XSR 1.6] size: 13.10 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 75.06 MB Flash programming ... Programming completed in 23.734 s [ADL] Restarting phone ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia X3 USB Generic, ID: 1199C40E [ADL] Verifying communication to device OK. Flashing completed in 2 min 3.515 s Phone Type: RM-540 (Nokia X3-00) SW Version: V 08.40 25-05-10 RM-540 (c) Nokia Imei plain: 35379604408607-8 Product Code: 0581106 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353796044086078 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 2 min 6.547 s Nokia USB ROM detached. thank's mx key team br; |
11-07-2010, 06:31 | #2557 (permalink) |
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | 3110c USB FLASH Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010) Processing file: rm237__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3 Device IO error: The device is not connected (code: 1167) [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3 RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] RAP EM0 ID: 00000232 RAP EM1 ID: 00000353 RAP PUBLIC ID: 0DC00115F3187F56BC005A949C23B87FBB94C431 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP ROM ID: 191EC665DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3880 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 82334AD [ADL] Verifying communication to device OK. Erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.781 s CMT NOR area [000006C0-0001FFFF] erased in 0.766 s CMT NOR area [00020000-0007FFFF] erased in 2.469 s CMT NOR area [00080000-000DFFFF] erased in 2.016 s CMT NOR area [00100000-001FFFFF] erased in 5.531 s CMT NOR area [00200000-0031FFFF] erased in 6.657 s CMT NOR area [00320000-0105FFFF] erased in 1 min 18.547 s CMT NOR area [01060000-01067FFF] erased in 0.750 s CMT NOR area [01068000-0107FFFF] erased in 0.765 s Flash programming ... CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written. Programming completed in 48.579 s Processing file: rm237__07.21.ppm_mea4 as PPM [BB5,BB5 ALGORITHM] size: 2.77 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Erase size: 4.62 MB CMT NOR area [01080000-0151FFFF] erased in 27.469 s Flash programming ... Programming completed in 9.359 s Processing file: rm237__07.21.image_mea4 as CNT [BB5,BB5 ALGORITHM] page size: 64 K size: 3.25 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Erase size: 10.75 MB CMT NOR area [01520000-01FDFFFF] erased in 1 min 19.922 s Flash programming ... Programming completed in 10.844 s [ADL] Restarting phone ... [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. [ADL] Phone flashing completed, but failed to verify communication to product! [ADL] Retrying in finalize phase... [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia 3110 classic USB Generic, ID: 2802744 [ADL] Verifying communication to device OK. Flashing completed in 6 min 13.485 s Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35602903751036-8 Product Code: 0544325 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356029037510368 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 6 min 15.625 Saqib.Ghazi |
11-07-2010, 07:24 | #2558 (permalink) | |
Cheater -Don't Deal with him- Join Date: Feb 2007 Location: Palestine
Member: 452256 Status: Offline Sonork: 100.1651051 Thanks Meter: 587 | c1 rm-689 Succesfully flashing c1 rm-689 Succesfully flashing Quote:
11-07-2010, 13:06 | #2559 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,283 | 2710c successfully flash reset code with mx keyl here log great speed 1 mint 21 sen Library version: 1.0.0.8986(19-10-2010), 1.0.0.14852(19-10-2010) Processing MCU file: rm586__06.22.mcusw [BB5,XSR 1.6] size: 24.50 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 120F7A38 CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: -] CMT EM0 ID: 00005361 CMT PUBLIC ID: 4B01DC8406330876F73DD38ECE4358834E4592DE CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: bcm21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: bcm21351_xsr16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Pooling for ADL device OK. Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 120F7A38 Verifying communication to device OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.4\data\backup\BB5_35829403064759_CE RT.rpl). CMT PAPUBKEYS HASH: 84CDC75F79F52BBAE46EA3A70C9240861412C480 Storing certificate [NPC, CCC, HWC, RND, R&D] ... Partitioning.... Partitioning complete Erase size: 31.88 MB Flash programming ... CMT PAPUBKEYS: 84CDC75F79F52BBAE46EA3A70C9240861412C480 (RAP Certificate 195 v.1) written. Programming completed in 8.906 s Processing PPM file: rm586__06.22.ppm_v [BB5,XSR 1.6] size: 5.98 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 6.50 MB Flash programming ... Programming completed in 2.063 s Processing CNT file: rm586__06.22.image_meap_black [BB5,XSR 1.6] size: 11.26 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 77.31 MB Flash programming ... Programming completed in 3.797 s Total time for flashing process(boot+erase+write) was 24.484 s Pooling for ADL device ... Device found: nmwcdc\Nokia 2710 Navigation Edition USB Generic, ID: 10E7E853 Verifying communication to device OK. Flashing completed in 44.750 s Phone Type: RM-586 (Nokia 2710c-2) SW Version: V 06.22 25-05-10 RM-586 (c) Nokia Imei plain: 35829403064759-5 Product Code: 0589857 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358294030647595 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000002 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Completed in 1.218 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.360 s |
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
11-08-2010, 06:52 | #2561 (permalink) |
No Life Poster Join Date: May 2006 Location: punjab
Member: 271008 Status: Offline Thanks Meter: 280 | 2220s unlock done Imei net: 35434704294699 Version: SIMLOCK SERVER Provider: Vodafone D2 (DCT4), Country: Germany Counter: 0/3, 0/10 CONFIG_DATA: 2620200000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 26202402262024122620242226202432262024422620245226 20246226202472262024822620249226202502262025122620 25222620253226202542262025522620256226202572262025 82262025922620260226202612262026222620263226202642 26202652262026622620267226202682262026922620270226 20271226202722262027322620274226202752262027622620 27722620278226202792262028022620281226202822262028 32262028422620285226202862262028722620288226202892 BLOCK 2: 1.LOCKED (MCC+MNC): 26202153262021632620217326202183262021932620230326 20231326202323262023332620234326202353262023632620 23732620238326202393262025032620251326202523262025 33262025432620255326202563262025732620258326202593 26202603262026132620262326202633262026432620265326 20266326202673262026832620269326202703262027132620 27232620273326202743262027532620276326202773262027 83262027932620280326202813262028232620283326202843 2620285326202863262028732620288326202893 BLOCK 3: 1.LOCKED (MCC+MNC): 26202104262021142620212426202134262021442620221426 20222426202234262022442620225426202264262022742620 22842620229426202304262023142620232426202334262023 44262023542620236426202374262023842620239426202404 26202414262024242620243426202444262024542620246426 2024742620248426202494 BLOCK 4: 1.LOCKED (MCC+MNC): 26202504262025142620252426202534262025442620255426 20256426202574262025842620259426202604262026142620 26242620263426202644262027042620271426202724262027 34262027442620275426202764262027742620278426202794 26202804262028142620282426202834262028442620295426 202964262029742620298426202994 BLOCK 5: 1.LOCKED (MCC+MNC): 26202105262021152620212526202135262021452620220526 20221526202225262022352620224526202305262023152620 23252620233526202345262023552620236526202375262023 85262023952620240526202415262024252620243526202445 26202455262024652620247526202485262024952620250526 20251526202525262025352620254526202555262025652620 25752620258526202595262026052620261526202625262026 35262026452620265526202665262026752620268526202695 26202705262027152620272526202735262027452620275526 202765262027752620278526202795 BLOCK 6: 1.LOCKED (MCC+MNC): 26202906262029162620292626202936262029462620295626 202966262029762620298626202996 Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-590_35434704294699_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35434704294699 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
11-08-2010, 13:41 | #2562 (permalink) |
Freak Poster Join Date: May 2007
Member: 511801 Status: Offline Sonork: 100.1590673 Thanks Meter: 46 | nokia 5310 rm303 dead usb flashing 100% done Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Processing MCU file: rm303__10.10.mcusw [BB5,BB5 ALGORITHM] size: 17.07 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 6370F4 CMT SYSTEM ASIC ID: 000000010000022600010006010C192101013000 CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1DD000186454025406DFF6CD8D6842A0E2DDAB4F CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x48480 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x56F40 bytes Update Server code succesfully sent to phone. Pooling for ADL device ... Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 13ED74C1 Verifying communication to device OK. Erase size: 18.00 MB CMT NOR area [00000000-000006BF] erased in 0.344 s CMT NOR area [000006C0-0001FFFF] erased in 0.031 s CMT NOR area [00040000-000BFFFF] erased in 1.704 s CMT NOR area [000C0000-0013FFFF] erased in 1.015 s CMT NOR area [00140000-010DFFFF] erased in 44.656 s CMT NOR area [010E0000-0121FFFF] erased in 3.437 s Flash programming ... CMT PAPUBKEYS: 3E96DE4212587183E5E16BB2C79692A53C19875D (RAP Certificate 90 v1) written. Programming completed in 2 min 37.406 s Processing PPM file: rm303__10.10.ppm_m4 [BB5,BB5 ALGORITHM] size: 4.91 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 6.50 MB CMT NOR area [01220000-0189FFFF] erased in 15.046 s Flash programming ... Programming completed in 46.828 s Processing CNT file: rm303__10.10.image_m4_whitemica_silver [BB5,BB5 ALGORITHM] page size: 128 K size: 8.01 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 39.12 MB CMT NOR area [018A0000-01B1FFFF] erased in 7.703 s CMT NOR area [01B20000-03FBFFFF] erased in 1 min 47.172 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 1 min 11.953 s Total time for flashing process(boot+erase+write) was 8 min 4.000 s Pooling for ADL device ... Device found: nmwcdc\Nokia 5310 XpressMusic USB Generic, ID: 3270C126 Verifying communication to device OK. Flashing completed in 8 min 27.110 s Phone Type: RM-303 (Nokia 5310 XpressMusic) SW Version: V 10.10 23-03-09 RM-303 (c) Nokia Imei plain: 35956201997546-1 Product Code: 0557200 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359562019975461 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 2.188 s Nokia USB ROM detached. |
11-08-2010, 13:50 | #2563 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | 2220 unlock with mxkey don hear is log Imei net: 35269000000000 Version: SIMLOCK SERVER Provider: Vodafone / Airtel Movil, Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 21401F Calculating SIMLOCK RPL using security server ... Socket error (11001): Host not found SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-590_35269000000000_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35269000000000 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
11-08-2010, 13:51 | #2564 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | 2220 unlock don in mxkey new 3.4 1.5 hear is log Imei net: 35269000000000 Version: SIMLOCK SERVER Provider: Vodafone / Airtel Movil, Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 21401F Calculating SIMLOCK RPL using security server ... Socket error (11001): Host not found SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-590_35269000000000_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35269000000000 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
11-08-2010, 17:09 | #2565 (permalink) |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | -= nokia 2690 RM_635 SL3 dead usb flashing 100% done =- usb Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35270504501852_BA CK.rpl). Processing MCU file: rm635__10.10.mcusw [BB5,BB5 ALGORITHM] size: 17.99 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Battery voltage: 4109 mV Phone type: RM-635 Product code: 0592076 SW version: V 10.10 22-04-10 RM-635 (c) Nokia LanguagePkg version: V 10.10 22-04-10 RM-635 (c) nokia M_A Version from phone: 10.10 Version from file: 10.10 CMT BOOT ID: 0803000302010000 CMT PUBLIC ID: 14E0000A9A584E503C2ADD326269D42C3543861C CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT PAPUBKEYS HASH: C6B9354E81AC464DED33FC7B90295086150F4539 FlashID0: 0089 8982 - 0000 FFFF [Intel NU48F512,512 Mbits] type: NOR,CMT FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NAND,APE Flashing CMT Update Server Data, UPDAPP: 0x49480 bytes Update Server code succesfully sent to phone. Pooling for ADL device ... Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 1041CF8D Verifying communication to device OK. Erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.016 s CMT NOR area [000006C0-0001FFFF] erased in 0.000 s CMT NOR area [00040000-000BFFFF] erased in 0.047 s CMT NOR area [000C0000-0013FFFF] erased in 0.046 s CMT NOR area [00140000-0137FFFF] erased in 1 min 41.719 s CMT NOR area [01380000-0151FFFF] erased in 8.922 s Flash programming ... CMT PAPUBKEYS: C6B9354E81AC464DED33FC7B90295086150F4539 (RAP Certificate v1 246) written. Programming completed in 1 min 0.219 s Processing PPM file: rm635__10.10.ppm_m_a [BB5,BB5 ALGORITHM] size: 3.14 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 46.766 s Flash programming ... Programming completed in 10.625 s Processing CNT file: rm635__10.10.image_m_a_black [BB5,BB5 ALGORITHM] page size: 128 K size: 6.51 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 34.00 MB CMT NOR area [01DC0000-0215FFFF] erased in 21.125 s CMT NOR area [02160000-03FBFFFF] erased in 3 min 3.219 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 21.484 s Total time for flashing process(boot+erase+write) was 7 min 45.610 s Pooling for ADL device ... Device found: nmwcdc\Nokia 2690 USB Generic, ID: 282DBE94 Verifying communication to device OK. Flashing completed in 8 min 18.204 s After Flash Processing ... Updating Product Code OK. Phone Type: RM-635 (Nokia 2690) SW Version: V 10.10 22-04-10 RM-635 (c) nokia Imei plain: 35270------------- Product Code: 0592076 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352---------------- Version: SIMLOCK SERVER Provider: nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF RJ Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Processing MCU file: rm635__10.10.mcusw [BB5,BB5 ALGORITHM] size: 17.99 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 14E0000A9A584E503C2ADD326269D42C3543861C ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.078 s CMT NOR area [000006C0-0001FFFF] erased in 0.156 s CMT NOR area [00040000-000BFFFF] erased in 0.218 s CMT NOR area [000C0000-0013FFFF] erased in 0.219 s CMT NOR area [00140000-0137FFFF] erased in 4.281 s CMT NOR area [01380000-0151FFFF] erased in 0.468 s Flash programming ... CMT PAPUBKEYS: C6B9354E81AC464DED33FC7B90295086150F4539 (RAP Certificate v1 246) written. Programming completed in 2 min 26.188 s Processing PPM file: rm635__10.10.ppm_m_a [BB5,BB5 ALGORITHM] size: 3.14 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 14E0000A9A584E503C2ADD326269D42C3543861C ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C6B9354E81AC464DED33FC7B90295086150F4539 TransmissionMode: DDR&TX2 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 2.032 s Flash programming ... Programming completed in 24.438 s Processing CNT file: rm635__10.10.image_m_a_black [BB5,BB5 ALGORITHM] page size: 128 K size: 6.51 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 NOR page size in the phone is 128 K. CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 14E0000A9A584E503C2ADD326269D42C3543861C ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C6B9354E81AC464DED33FC7B90295086150F4539 TransmissionMode: DDR&TX2 Erase size: 34.00 MB CMT NOR area [01DC0000-0215FFFF] erased in 21.203 s CMT NOR area [02160000-03FBFFFF] erased in 7.063 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 50.515 s Total time for flashing process(boot+erase+write) was 4 min 54.578 s Flashing completed in 5 min 15.719 s After Flash Processing ... Updating Product Code OK. Phone Type: RM-635 (Nokia 2690) SW Version: V 10.10 22-04-10 RM-635 (c) nokia Imei plain: 35270--------- Product Code: 0592076 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3527---------- Version: SIMLOCK SERVER Provider: nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF M R / KEMO |
