06-13-2010, 10:18 | #1817 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | In the info IT say SL3 but unlock successfully Imei net: 35************* Version: SIMLOCK SERVER Provider: Vodafone, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341500000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23415F, DATA=23415F BLOCK 2: 1=LOCKED (MCC+MNC): 23415F, DATA=23415F Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V ICPR72_09w20.12 10-09-09 RM-356 (c) Nokia ApeCoreSw: V 31.0.101 Using cached productData[09700106F38C00525B3E6195784C8ADDE72CB8B0] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 [CR2]BB5 remaining credit: 24 Completed in 2.828 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-356_351531040421702_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: 35************ Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF UFS2 SarasSoft disconnected. Please FIX this ..... |
06-14-2010, 13:49 | #1820 (permalink) |
Freak Poster Join Date: Aug 2009 Location: PAKSSD BHUBNESWAR,ODISHA,INDIA
Member: 1098599 Status: Offline Sonork: 100.1596720 Thanks Meter: 152 | 3110c SUPERDONGLE_KEY invalid repir Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 356815xxxx Product Code: 0550573 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35681xxxx Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF AFTER REPIR SD Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 356815024xxxxx Product Code: 0550573 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35681502xxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF THEN PMFILE SUPER SD Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.21 05-11-08 RM-237 (c) Nokia. Using cached productData[2FE0010744927C56CAE3854D14ADD28F9AED9C58] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 86 bytes written. - Key: 18, size 86 bytes written. - Key: 20, size 86 bytes written. - Key: 25, size 4 bytes written. - Key: 29, size 6 bytes written. - Key: 34, size 80 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 2.344 s Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35681502xxxxxx Product Code: 0550573 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3568150243xxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF THANKS MXKEY TEAM |
06-15-2010, 07:53 | #1821 (permalink) |
Freak Poster Join Date: Dec 2007 Location: kotli
Member: 643478 Status: Offline Sonork: 100.161898 Thanks Meter: 159 | nokia 3500 repair successfully Imei net: 35xxxxxxxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Backup saved to "BB5_35203302563059_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.21 05-11-08 RM-272 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK Sending CustomLoader(0x50B0 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x3B0 bytes) ...OK Calculating LOCK data ...OK Receiving Unlocked PM, please WAIT ... OK Unlocked PM saved to "C:\mobileEx\3.4\data\backup\352033025630596_UNLOC KED_308.1.PM" Writing Unlocked PM ... OK Completed in 31.172 s Restarting phone ... Reading Simlock info ... Imei net: 35xxxxxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Last edited by moon955; 06-15-2010 at 07:57. Reason: imie |
06-15-2010, 12:51 | #1822 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 49
Member: 1275418 Status: Offline Thanks Meter: 432 | ckup saved to "BB5_35606603924906_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 10.10 23-03-09 RM-303 (c) Nokia Using cached productData[15A00101CC408C56429CB20CF596CB07F4AAFF4A] ... Calculating NCK using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1 #pw+ 711612531106382 +1 # #pw+ 822788432777623 +2 # #pw+ 499744658210728 +3 # #pw+ 833446511473412 +4 # #pw+ 548320615276366 +5 # #pw+ 011983460384467 +6 # #pw+ 347739737403646 +7 # Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Completed in 16.875 s Restarting phone ... Reading Simlock info ... Imei net: 356066039249066 Version: SIMLOCK SERVER Provider: Movistar (DCT4), Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=21407F BLOCK 2: 1=OPEN, DATA=21402F |
06-15-2010, 13:58 | #1823 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | 2600c unlock done Elapsed: 147 secs. Imei net: 35521903640453 Version: SIMLOCK SERVER Provider: Retevision Movil Amena, Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140300000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.LOCKED (MCC+MNC): 21403F Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-298_35521903640453_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35521903640453 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
06-16-2010, 06:33 | #1824 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Nokia 5800 unlocking done Imei net: 355225033xxxxxx Version: SIMLOCK SERVER Provider: Virgin, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23430F, DATA=23430F Backup saved to "BB5_355225033xxxxxx_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia ApeCoreSw: V 21.0.025 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Calculating NCK using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1 #pw+ 682650123594275 +1 # #pw+ 332435287834980 +2 # #pw+ 499919253405485 +3 # #pw+ 066195864919207 +4 # #pw+ 345160186974429 +5 # #pw+ 233625560359906 +6 # #pw+ 302005551152842 +7 # Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Completed in 20.969 s Restarting phone ... Reading Simlock info ... Imei net: 355225033xxxxxx Version: SIMLOCK SERVER Provider: Virgin, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=23430F |
06-16-2010, 12:44 | #1825 (permalink) |
Junior Member Join Date: Jun 2010 Location: azad kashmir
Member: 1321161 Status: Offline Sonork: [email protected] Thanks Meter: 0 | thankssss thankssssssssssssss |
06-16-2010, 13:52 | #1826 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Bangadesh.Dhaka
Member: 694638 Status: Offline Sonork: no Thanks Meter: 164 | Successfully 3110c usb flashing by mxkey Successfully 3110c usb flashing by mxkey Here is the log....... Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Processing file: rm237__07.21.mcusw_cal as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3 RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] RAP EM0 ID: 00000232 RAP EM1 ID: 00000353 RAP PUBLIC ID: 0E70021154DE7E56FE6C2C0D359E40EAAF1020FD RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP ROM ID: 191EC665DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3880 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: B45DD6 [ADL] Verifying communication to device OK. Erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.578 s CMT NOR area [000006C0-0001FFFF] erased in 0.563 s CMT NOR area [00020000-0007FFFF] erased in 1.593 s CMT NOR area [00080000-000DFFFF] erased in 1.594 s CMT NOR area [00100000-001FFFFF] erased in 4.375 s CMT NOR area [00200000-0031FFFF] erased in 5.359 s CMT NOR area [00320000-0105FFFF] erased in 1 min 1.812 s CMT NOR area [01060000-01067FFF] erased in 0.609 s CMT NOR area [01068000-0107FFFF] erased in 0.578 s Flash programming ... CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written. Programming completed in 55.594 s Processing file: rm237__07.21.ppm_cal as PPM [BB5,BB5 ALGORITHM] size: 3.25 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Erase size: 4.62 MB CMT NOR area [01080000-0151FFFF] erased in 22.765 s Flash programming ... Programming completed in 12.422 s Processing file: rm237__07.21.image_cal as CNT [BB5,BB5 ALGORITHM] page size: 128 K size: 3.88 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Erase size: 10.75 MB CMT NOR area [01520000-01FDFFFF] erased in 1 min 17.578 s Flash programming ... Programming completed in 15.312 s [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia 3110 classic USB Generic, ID: 36AC1A74 [ADL] Verifying communication to device OK. Flashing completed in 5 min 4.563 s Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35318303713858-0 Product Code: 0550542 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353183037138580 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 5 min 7.813 s USB Pooling failed, phone not found ! Nokia USB ROM detached. |
06-16-2010, 16:07 | #1827 (permalink) |
No Life Poster Join Date: Sep 2007 Location: ATF Earth Age: 36
Member: 598395 Status: Offline Thanks Meter: 664 | Nokia 5800XM Unlocking Done. Imei net: 353184036485071 Version: SIMLOCK SERVER Provider: hello, Country: Norway Counter: 0/3, 0/10 CONFIG_DATA: 2420100000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 24201F 2=LOCKED (GID1): FFFFF01FFFFFFFFF 3=LOCKED (GID2): FFFFF02FFFFFFFFF, DATA=24201F BLOCK 2: 1=LOCKED (MCC+MNC): 24201F 2=LOCKED (GID1): FFFFF3FFFFFFFFFF, DATA=24201F BLOCK 3: 1=LOCKED (MCC+MNC): 24201F 2=LOCKED (GID1): FFFFF01FFFFFFFFF 3=LOCKED (GID2): FFFFF02FFFFFFFFF, DATA=24201F BLOCK 4: 1=LOCKED (MCC+MNC): 24201F 2=LOCKED (GID1): FFFFF3FFFFFFFFFF, DATA=24201F Backup saved to "BB5_35318403648507_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V ICPR72_09w02.3 26-01-09 RM-356 (c) Nokia ApeCoreSw: V 20.0.012 Using cached productData[02200106BE750052913856637D7F5B1EA0E6D289] ... Calculating NCK using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1 #pw+ 070467698537223 +1 # #pw+ 814778696904890 +2 # #pw+ 062201834980442 +3 # #pw+ 739514212991135 +4 # #pw+ 638632751882668 +5 # #pw+ 370342064815035 +6 # #pw+ 248188303101317 +7 # Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Completed in 13.453 s Restarting phone ... Reading Simlock info ... Imei net: 353184036485071 Version: SIMLOCK SERVER Provider: hello, Country: Norway Counter: 0/3, 0/10 CONFIG_DATA: 2420100000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN, DATA=24201F BLOCK 2: 1=OPEN 2=OPEN, DATA=24201F BLOCK 3: 1=OPEN 2=OPEN 3=OPEN, DATA=24201F BLOCK 4: 1=OPEN 2=OPEN, DATA=24201F |
06-16-2010, 16:13 | #1828 (permalink) |
Member: 598395 Status: Offline Thanks Meter: 664 | Nokia E71 Unlocking Done. Imei net: 359357030649470 Version: SIMLOCK SERVER Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 2: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F BLOCK 3: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 4: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F Backup saved to "BB5_35935703064947_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Product: V ICPR71_09w22 29-05-09 RM-346 (c) Nokia ApeCoreSw: 300.21.012 Using cached productData[1AD00114998C0052E03482736445C772B1748063] ... Calculating NCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 #pw+ 481479910968957 +1 # #pw+ 081356932481492 +2 # #pw+ 754842494446096 +3 # #pw+ 187349812026513 +4 # #pw+ 785899383311530 +5 # #pw+ 734064146194075 +6 # #pw+ 801195755536153 +7 # Sending NCK code ... Trying NCK lock 7 ... OK: code accepted. Completed in 13.078 s Restarting phone ... Reading Simlock info ... Imei net: 359357030649470 Version: SIMLOCK SERVER Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN, DATA=23420F BLOCK 2: 1=OPEN, DATA=23594F BLOCK 3: 1=OPEN, DATA=23420F BLOCK 4: 1=OPEN, DATA=23594F |
06-17-2010, 01:30 | #1829 (permalink) |
Crazy Poster Join Date: Apr 2009 Location: ENGLAND
Member: 1015559 Status: Offline Sonork: IT-Specialist Thanks Meter: 2 | MX Key is best tool for repairing because i had 6300 and i tryed with UB Box but Local mode problem, and i did tryed JAF but There was Also Local mode problem, and i was looking for Local Mode solution and I read someone post he said we needs to change resister on circuit but my phone was working good so i deside i did not want to distubed Circuit bord because phone working ok..suddnly i deside lets try MX Key and MX Key did this unlock whithin few seconds so we can say MX key is a good for some Aspect. |
06-17-2010, 07:34 | #1830 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | 5030 unlock done Imei net: 35603203406118 Version: SIMLOCK SERVER Provider: Symfonika AS, Country: Norway Counter: 0/3, 0/10 CONFIG_DATA: 2420200081019030 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 24202F BLOCK 2: 1.LOCKED (MCC+MNC): FFFFFF0FFFFFFFFF 2.LOCKED (GID1): FFFFFF3FFFFFFFFF BLOCK 3: 1.LOCKED (MCC+MNC): FFFFF56FFFFFFFFF BLOCK 4: 1.LOCKED (MCC+MNC): FFFFF59FFFFFFFFF BLOCK 5: 1.LOCKED (MCC+MNC): FFFFF86FFFFFFFFF Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-524_35603203406118_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35603203406118 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
