06-14-2011, 10:45 | #16 (permalink) | |
No Life Poster Join Date: May 2002 Location: dont ask!
Member: 12411 Status: Offline Sonork: 100.113572 Thanks Meter: 813 | Quote:
br freddy | |
06-14-2011, 10:50 | #18 (permalink) |
No Life Poster Join Date: May 2007 Location: Algerie,Batna
Member: 508860 Status: Offline Sonork: 1613186 Thanks Meter: 224 | I changed 5 cable sam problem problem software or hardware ??????? and with ufs is good Last edited by SkyMobile05; 06-14-2011 at 10:56. |
06-14-2011, 10:51 | #19 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 581888 Status: Offline Thanks Meter: 74 | mr manole please help after i update my mxbox to 3.5.1.1 cant install correct driver please see the attachment and give a solution to me hti error.JPG - 4shared.com - photo sharing - download image |
06-14-2011, 11:03 | #20 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Hi Manole, 5130 flashing error i tried change the cable flashed so many times same error showing , but atf as interface no problem flashing succesfully. Code: MXKEY Serial: [USB Smart Card Reader 4] - ************* Using device: HTI BOX, FW ver: 00.17 Driver: USBUHCI:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.11291(14-06-2011) Processing MCU file: rm495__07.97.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0930020C5F728E563373A0575FC78C754A329CF2 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00040000-000BFFFF] CMT NOR area [000C0000-0013FFFF] CMT NOR area [00140000-0137FFFF] CMT NOR area [01380000-0151FFFF] erased in 1 min 11.203 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 18.078 s Processing PPM file: rm495__07.97.ppm_mk [BB5,BB5 ALGORITHM] size: 7.69 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 ERROR: Phone does not respond flash config request ! Task failed at (08000008)!!! Last RX buffer: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF BR, Srinivas Reddy. |
The Following User Says Thank You to swechacnu For This Useful Post: |
06-14-2011, 11:25 | #22 (permalink) |
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Hi Manole, 3110c Flashing & rpl Saving error, with atf as interface successfully flashed....... Code: MXKEY Serial: [USB Smart Card Reader 4] - ******** Using device: HTI BOX, FW ver: 00.17 Driver: USBUHCI:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.11291(14-06-2011) Processing MCU file: rm237__07.21.mcusw [BB5,BB5 ALGORITHM] size: 14.48 MB Supported Ids: 0103192101001101, 010C192101001101 CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0F70010D95637E56DEA46455F2BB3B30D8780FEA ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D] ...OK Erase size: 16.37 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00020000-0007FFFF] CMT NOR area [00080000-000DFFFF] CMT NOR area [00100000-001FFFFF] CMT NOR area [00200000-0031FFFF] CMT NOR area [00320000-0105FFFF] CMT NOR area [01060000-01067FFF] CMT NOR area [01068000-0107FFFF] erased in 1 min 26.500 s Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00000400, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: C7 01 2D 01 03 CD 00 Flashing... BR, Srinivas Reddy. |
06-14-2011, 11:33 | #23 (permalink) |
Freak Poster Join Date: Dec 2004 Location: South Sumatra, Indonesia Age: 42
Member: 95561 Status: Offline Sonork: 1573725 Thanks Meter: 31 | after update firmware, which driver should i choose for hti smartcard reader? is it "hti smartcard reader" or "hti smartcard reader(winusb)" ? thank you. |
06-14-2011, 11:38 | #25 (permalink) |
No Life Poster Join Date: Feb 2007 Location: India
Member: 449060 Status: Offline Sonork: 100.1670591 Thanks Meter: 260 | i have a problem in ufs not show new update i try to remove and install agin not work when i connect ufs show error and hang & when i remove ufs show no error and work with usb help mx team ans is this bug or now not support usf more ? |
06-14-2011, 11:39 | #26 (permalink) |
No Life Poster Join Date: Jun 2011 Location: manila
Member: 1595088 Status: Offline Thanks Meter: 184 | i have some problem here bro after i update my hti and install the version 3.5. 1.1 any idea bro,. thank you,.. |
The Following User Says Thank You to tartcell18 For This Useful Post: |
06-14-2011, 11:48 | #27 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 560185 Status: Offline Thanks Meter: 101 | Quote:
normally it should be in "C:\mobileEx\3.5\data\drivers\hti" or depending on which you installed it. try to update the hti driver and choose "install from a list or specific location" and pont it to C:\mobileEx\3.5\data\drivers\hti | |
06-14-2011, 11:52 | #28 (permalink) |
No Life Poster Join Date: May 2005
Member: 149305 Status: Offline Sonork: 100.1612778 Thanks Meter: 804 | successfully unlocked 8830 with new exe IMEI: 35429********** MEP: MEP-15326-002 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 MEP2(Network,Active,0,10): 12024592 MEP3(Network Subset): 9712437324204730 MEP4(Service Provider): 5722477970591049 MEP5(Corporate): 9855602253561459 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. |
06-14-2011, 12:10 | #29 (permalink) |
No Life Poster Join Date: Apr 2009 Age: 41
Member: 1015389 Status: Offline Sonork: 19830303 Thanks Meter: 526 | @ Mr. Manole why i cant update my hti firmware? » Begin transaction ... Initializing HTI ... HTI initialized. Boot version: 00.07 Serial: xxxxxxxx Receive firmware from server ... [InternalErrorFault] BLADE-Z [upd.mxkey.biz] update service temporary down (case id=0xAA00) [InternalErrorFault] BLADE-Z [host2.mxkey.biz] update service temporary down (case id=0xAA00) [InternalErrorFault] BLADE-Z [host3.mxkey.biz] update service temporary down (case id=0xAA00) [InternalErrorFault] BLADE-Z [host4.mxkey.biz] update service temporary down (case id=0xAA00) ERROR: Receive buff error no: 0x00 » End transaction (status: 13) |
06-14-2011, 12:11 | #30 (permalink) |
Insane Poster Join Date: Dec 2010 Location: SPEEDTECH Mobile Solution Age: 36
Member: 1467522 Status: Offline Sonork: 100.1596014 Thanks Meter: 32 | server temporary down i can't update my HTI box FW to 00.17 » Begin transaction ... Initializing HTI ... HTI initialized. Boot version: 00.07 Serial: 00000251 Receive firmware from server ... [InternalErrorFault] BLADE-Z [upd.mxkey.biz] update service temporary down (case id=0xAA00) [InternalErrorFault] BLADE-Z [host2.mxkey.biz] update service temporary down (case id=0xAA00) [InternalErrorFault] BLADE-Z [host3.mxkey.biz] update service temporary down (case id=0xAA00) [InternalErrorFault] BLADE-Z [host4.mxkey.biz] update service temporary down (case id=0xAA00) ERROR: Receive buff error no: 0x00 » End transaction (status: 13) |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
