View Poll Results: Is this free update useful for you ? | |||
YES | 1,241 | 92.13% | |
I do not have MXBOX | 106 | 7.87% | |
Voters: 1347. You may not vote on this poll |
07-06-2012, 12:24 | #217 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | e5 flashing error?????? this set flashing ok with 3.5 rev 2.1 & i install 2.2 than show this error i reinstall 2.2 setup 2 , 3 time MXKEY [FT SCR2000 0], SN: ********** Using device: HTI, FW ver: 00.50, SN: *********** Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 12000106CEA40344358F7F0510D3F69209E0C0C7 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.2.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.2.0 revision: 3.0 size: 0xD44E9 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS is blank/erased. Processing MCU file: rm632_091.001_prd.core.fpsx [BB5,XSR 1.6] size: 103 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning ...OK Erase size: 227.31 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0E77FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: CCD9F805 [RAP Certificate v1 238] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent ERROR: Packet Error(0xAA), code 0xA4000002 Error while programming [00] at 0x01100400, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: 02 00 00 A4 |
07-06-2012, 12:42 | #218 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | flashing pause 29% ppm ERROR: Packet Error(0xAA), code 0xA4000002 Error while programming [00] at 0x096C0400, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: 02 00 00 A4 |
07-07-2012, 05:01 | #220 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1353660 Status: Offline Thanks Meter: 1 | help.............................................. . Imei net: 353382045149312 Version: SIMLOCK SERVER Counter: 1/3, 1/10 CONFIG_DATA: 4500000088401881 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=450FFF [Korea (Rep. of) - All] Backup already exist. MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: Using device: HTI, FW ver: 00.50, SN: Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012) Phone type: RM-356 (Nokia 5800 XpressMusic) SW version: V ICPR72_09w20.18 12-05-10 RM-356 (c) Nokia ApeCoreSw: V 20.7.006 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 14C00015F6A10052721375A763C536BE81A84A1A ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 PUBLIC ID: 14C00015F6A10052721375A763C536BE81A84A1A PRIVATE ID: 99AD0D72F1A57CE52E2DEDD8CC7A8D2B235EA4EC E-FUSE: E6E6914D SEC ROM CRC: 3E691FF8 #pw+ 059557919877791 +1 # #pw+ 641214960169634 +2 # #pw+ 909380563990599 +3 # #pw+ 789076646917063 +4 # #pw+ 482200044114559 +5 # #pw+ 502193358487262 +6 # #pw+ 235058807665606 +7 # Sending NCK code ... Trying mode: FBUS, NCK lock 7(ALL) ...FAILED: wrong code Trying mode: FBUS, NCK lock 6(MCCMNC+GID1+GID2) ...FAILED: not ready Trying mode: FBUS, NCK lock 5(MCCMNC+GID1) ...FAILED: wrong code Trying mode: FBUS, NCK lock 4(IMSI) ...FAILED: not ready Trying mode: FBUS, NCK lock 3(GID2) ...FAILED: wrong code Trying mode: FBUS, NCK lock 2(GID1) ...FAILED: not ready Trying mode: FBUS, NCK lock 1(MCCMNC) ...FAILED: wrong code Reading Simlock info ... Imei net: 353382045149312 Version: SIMLOCK SERVER Counter: 1/3, 5/10 CONFIG_DATA: 4500000088401881 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=450FFF [Korea (Rep. of) - All] CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 14C00015F6A10052721375A763C536BE81A84A1A ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.2.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.2.0 revision: 2.0 size: 0x8B45D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Reading PASUBTOC ... SIMLOCK PA identifier: [0] PA_SL2 [1] PA_SL3 help me |
