11-26-2010, 17:41 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Basirhat
Member: 1134419 Status: Offline Sonork: 100.1621725 Thanks Meter: 452 | MXKEY ver 3.4 rev 1.6 Showing error. How to solv I am Using 3.4 rev 1.6. When I click to BUS CHECK in BB5 it allays showing error. But in MXKEY 3.4 rev 1.5 it is OK. 1.5 is nor showing any error. I want to use 3.4 rev 1.6 , how it will be possible . |
11-26-2010, 18:17 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | first uninstall your mobileEx. open registry Editor start-run-type regedit hit enter. HKEY_LOCAL_MACHINE-SOFTWARE-mobileEx click mouse right button and delete. remove ROCKEY200 DRIVER,go-C drive and delete mobileEx folder reboot your pc. install mobileEx,install ROCKEY200 driver,open mobileEx and sing application. Tested by me |
The Following 3 Users Say Thank You to net.tarik For This Useful Post: |
11-26-2010, 19:04 | #3 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: INDIA
Member: 665989 Status: Offline Sonork: 100.1597348 Thanks Meter: 552 | Just do this. Quote:
1.Start->Control panel-> Windows Firewall -> Turn off. 2. Turn smart firewall or resident shield in antivirus Your problem will be solved. | |
The Following User Says Thank You to ABDUL RAJA For This Useful Post: |
11-27-2010, 03:40 | #4 (permalink) |
Member: 1134419 Status: Offline Sonork: 100.1621725 Thanks Meter: 452 | I have tested all of two memebers post 1. net.tarik Freak Poster 2. ABDUL RAJA Freak Poster But same problem. When I install 1.5 it is OK. Then why 1.6 giving error in bb5. in dc4 section it is OK. |
The Following User Says Thank You to mridulnandy For This Useful Post: |
11-27-2010, 07:04 | #8 (permalink) |
No Life Poster Join Date: Nov 2010
Member: 1439406 Status: Offline Thanks Meter: 88 | remove from CP than reinstall both mail soft and driver if not work u can change to try with ur interface hope u will done |
The Following User Says Thank You to Oxegen For This Useful Post: |
11-27-2010, 08:20 | #10 (permalink) |
No Life Poster Join Date: Nov 2008 Location: U.S.A.
Member: 893209 Status: Offline Thanks Meter: 274 | UN-INSTALL the 1.6,,, DELETE the FOLDER MOBILE EX,,, INSTALL agin the 1.6,,, SIGN-APP,,, DONE,, Br,. Rhyan |
The Following User Says Thank You to Rhyan777 For This Useful Post: |
11-27-2010, 11:09 | #11 (permalink) |
No Life Poster Join Date: May 2006 Location: in gsm world
Member: 269885 Status: Offline Thanks Meter: 50 | i also have same problem,uninstall 1.6 install 1.5 but same error.any solution from monale |
The Following User Says Thank You to burraq For This Useful Post: |
11-27-2010, 11:25 | #12 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Man here is your solution, reinstall 3.4 v1.5 & restart pc then install 3.4 v1.6 but when installing this version untick nokia cable driver in the setup & after installation process finishes again restart your pc. please look carefully what i have marked in blue font. |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
11-28-2010, 02:40 | #14 (permalink) |
Member: 1134419 Status: Offline Sonork: 100.1621725 Thanks Meter: 452 | I have gone through all the steps. But no sucess. In my case i.5 is 100% working. I need some advice from product supporter to solv my problem. Thanks in advance |
11-28-2010, 11:52 | #15 (permalink) |
Member: 1134419 Status: Offline Sonork: 100.1621725 Thanks Meter: 452 | Thank you All to senior members. I just overcome from my problem. I just change flash loader pack 10.32.000.1 to 09.50.25.2 Now I can use BUS CHECK option clearly like 3.4 rev 1.5. MX KEY team you are rocking. We all love MX KEY . Wish more BOMB update like BB5 RPL service from you. Thanks |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
