Old 05-13-2010, 12:55   #1 (permalink)
Member: 790497
Sonork: 87654321
Thanks Meter: 79
N-76 phone startup failed contact retailer problem
phone startup fail contact service provider
here is the log
Phone Type: RM-135 (Nokia N76)
SW Version: V 06wk41v21.4 05-04-07 RM-135 (c) Nokia
Imei plain: 35626201209680-2
Product Code: 0543080
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356262012096802
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
everything seems to b alrite according to my knlwledge
i,v repair sd already
recover certificate also have write PM without 308 already
help me plz what else should i do?
if possible upload for me a good pm plz
thanx
Old 05-13-2010, 13:06   #2 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
set has hardware problem...
Old 05-13-2010, 13:11   #3 (permalink)
Member: 790497
Sonork: 87654321
Thanks Meter: 79
no it dosnt have hardware problem im a hardware technition i,v test it on hadware already i think it need to write good pm ....which i dont have
Old 05-13-2010, 13:13   #4 (permalink)
Member: 1138285
Thanks Meter: 14
bro.you need good pm.
Old 05-13-2010, 13:16   #5 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
N-76 Pm
Hello,
try this pm .
if still same flash it to latest version !
Old 05-13-2010, 13:16   #6 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
ur PM is not tampered
it has no problem
Old 05-13-2010, 13:18   #7 (permalink)
MOURAD™'s Avatar
Member: 468587
Sonork: 100.1612429
Thanks Meter: 681
post selftest log........................
The Following User Says Thank You to MOURAD™ For This Useful Post:
Old 06-28-2010, 14:10   #8 (permalink)
Member: 1178099
Sonork: 143
Thanks Meter: 3
SW Version: V 06wk41v46 06-11-07 RM-135 (c) Nokia
Imei plain: 35626201113967-8
Product Code: 0543059
ApeCoreSw: 31.0.014
ApeVariant: 31.0.014, Language Pack:
- not available.
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 356262011139678
Counter: 0/3, 0/10
BLOCK 1: 1=CORRUPTED (00) 2=CORRUPTED (00) 3=CORRUPTED (00) 4=CORRUPTED (00) 5=CORRUPTED (00), DATA=
BLOCK 2: 1=CORRUPTED (00) 2=CORRUPTED (00) 3=CORRUPTED (00) 4=CORRUPTED (00) 5=CORRUPTED (00), DATA=
BLOCK 3: 1=CORRUPTED (00) 2=CORRUPTED (00) 3=CORRUPTED (00) 4=CORRUPTED (00) 5=CORRUPTED (00), DATA=
BLOCK 4: 1=CORRUPTED (00) 2=CORRUPTED (00) 3=CORRUPTED (00) 4=CORRUPTED (00) 5=CORRUPTED (00), DATA=
BLOCK 5: 1=CORRUPTED (00) 2=CORRUPTED (00) 3=CORRUPTED (00) 4=CORRUPTED (00) 5=CORRUPTED (00), DATA=
Old 06-28-2010, 14:16   #9 (permalink)
Member: 1178099
Sonork: 143
Thanks Meter: 3
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 5, size 4 bytes written.
- Key: 6, size 98 bytes written.
Warning: failed to write 1 - 8 (110 bytes)
- Key: 13, size 98 bytes written.
- Key: 15, size 4 bytes written.
- Key: 16, size 98 bytes written.
- Key: 18, size 98 bytes written.
- Key: 20, size 98 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 4 bytes written.
- Key: 26, size 110 bytes written.
- Key: 27, size 4 bytes written.
- Key: 28, size 98 bytes written.
- Key: 29, size 10 bytes written.
- Key: 31, size 98 bytes written.
- Key: 33, size 36 bytes written.
- Key: 34, size 80 bytes written.
- Key: 44, size 182 bytes written.
Section: 2
- Key: 0, size 440 bytes written.
Section: 4
- Key: 3, size 10 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 9, size 5 bytes written.
Section: 8
- Key: 0, size 12 bytes written.
- Key: 1, size 12 bytes written.
- Key: 2, size 128 bytes written.
- Key: 3, size 128 bytes written.
- Key: 6, size 4 bytes written.
- Key: 7, size 8 bytes written.
- Key: 8, size 8 bytes written.
- Key: 9, size 16 bytes written.
Section: 11
- Key: 0, size 4 bytes written.
- Key: 2, size 4 bytes written.
- Key: 3, size 4 bytes written.
- Key: 4, size 1 bytes written.
- Key: 5, size 6 bytes written.
- Key: 6, size 1 bytes written.
- Key: 7, size 2 bytes written.
- Key: 8, size 2 bytes written.
- Key: 9, size 2 bytes written.
- Key: 10, size 2 bytes written.
- Key: 11, size 2 bytes written.
- Key: 12, size 1 bytes written.
- Key: 13, size 1 bytes written.
- Key: 14, size 1 bytes written.
- Key: 15, size 1 bytes written.
- Key: 16, size 1 bytes written.
- Key: 17, size 1 bytes written.
- Key: 18, size 1 bytes written.
- Key: 19, size 2 bytes written.
- Key: 20, size 2 bytes written.
- Key: 21, size 1 bytes written.
- Key: 22, size 1 bytes written.
- Key: 24, size 4 bytes written.
- Key: 25, size 2 bytes written.
- Key: 26, size 2 bytes written.
- Key: 27, size 2 bytes written.
- Key: 28, size 2 bytes written.
- Key: 29, size 1 bytes written.
- Key: 30, size 1 bytes written.
- Key: 31, size 1 bytes written.
- Key: 32, size 1 bytes written.
- Key: 33, size 1 bytes written.
- Key: 34, size 1 bytes written.
- Key: 35, size 1 bytes written.
- Key: 36, size 1 bytes written.
- Key: 37, size 1 bytes written.
- Key: 38, size 2 bytes written.
- Key: 39, size 2 bytes written.
- Key: 40, size 2 bytes written.
- Key: 41, size 2 bytes written.
- Key: 42, size 2 bytes written.
- Key: 43, size 4 bytes written.
- Key: 44, size 4 bytes written.
- Key: 45, size 4 bytes written.
- Key: 46, size 1 bytes written.
- Key: 47, size 16 bytes written.
- Key: 48, size 2 bytes written.
- Key: 49, size 2 bytes written.
- Key: 50, size 20 bytes written.
- Key: 51, size 10 bytes written.
- Key: 52, size 2 bytes written.
- Key: 53, size 20 bytes written.
- Key: 54, size 10 bytes written.
- Key: 55, size 1 bytes written.
- Key: 56, size 1 bytes written.
- Key: 57, size 1 bytes written.
- Key: 58, size 1 bytes written.
- Key: 59, size 1 bytes written.
- Key: 60, size 1 bytes written.
- Key: 61, size 1 bytes written.
- Key: 62, size 1 bytes written.
- Key: 63, size 1 bytes written.
- Key: 64, size 1 bytes written.
- Key: 65, size 1 bytes written.
- Key: 66, size 32 bytes written.
- Key: 67, size 32 bytes written.
- Key: 68, size 2 bytes written.
- Key: 69, size 2 bytes written.
- Key: 70, size 2 bytes written.
- Key: 71, size 2 bytes written.
- Key: 72, size 2 bytes written.
- Key: 73, size 2 bytes written.
- Key: 74, size 2 bytes written.
- Key: 75, size 2 bytes written.
- Key: 76, size 2 bytes written.
- Key: 77, size 2 bytes written.
- Key: 78, size 2 bytes written.
- Key: 79, size 2 bytes written.
- Key: 80, size 2 bytes written.
- Key: 81, size 2 bytes written.
- Key: 82, size 2 bytes written.
- Key: 83, size 2 bytes written.
- Key: 84, size 2 bytes written.
- Key: 85, size 2 bytes written.
- Key: 86, size 2 bytes written.
- Key: 87, size 2 bytes written.
- Key: 88, size 2 bytes written.
- Key: 89, size 2 bytes written.
- Key: 90, size 2 bytes written.
- Key: 91, size 2 bytes written.
- Key: 92, size 2 bytes written.
- Key: 93, size 2 bytes written.
- Key: 94, size 2 bytes written.
- Key: 95, size 2 bytes written.
- Key: 96, size 2 bytes written.
- Key: 97, size 2 bytes written.
- Key: 98, size 2 bytes written.
- Key: 99, size 2 bytes written.
- Key: 100, size 2 bytes written.
- Key: 101, size 2 bytes written.
- Key: 102, size 2 bytes written.
- Key: 103, size 2 bytes written.
- Key: 104, size 2 bytes written.
- Key: 105, size 2 bytes written.
- Key: 106, size 2 bytes written.
- Key: 107, size 2 bytes written.
- Key: 108, size 2 bytes written.
- Key: 109, size 2 bytes written.
- Key: 110, size 2 bytes written.
- Key: 111, size 2 bytes written.
- Key: 112, size 2 bytes written.
- Key: 113, size 2 bytes written.
- Key: 114, size 2 bytes written.
- Key: 115, size 2 bytes written.
- Key: 116, size 4 bytes written.
- Key: 117, size 4 bytes written.
- Key: 118, size 1 bytes written.
- Key: 119, size 4 bytes written.
- Key: 120, size 4 bytes written.
- Key: 121, size 4 bytes written.
- Key: 122, size 4 bytes written.
- Key: 123, size 16 bytes written.
- Key: 124, size 4 bytes written.
- Key: 125, size 2 bytes written.
- Key: 126, size 2 bytes written.
- Key: 127, size 1437 bytes written.
Section: 12
- Key: 0, size 102 bytes written.
Section: 31
- Key: 4, size 20 bytes written.
Section: 44
- Key: 0, size 1 bytes written.
Section: 50
- Key: 0, size 2 bytes written.
Section: 54
Section: 96
- Key: 0, size 24 bytes written.
Section: 107
- Key: 0, size 21 bytes written.
- Key: 1, size 79 bytes written.
- Key: 2, size 79 bytes written.
- Key: 3, size 70 bytes written.
- Key: 25, size 132 bytes written.
Section: 117
- Key: 1, size 3 bytes written.
- Key: 2, size 6 bytes written.
- Key: 3, size 1 bytes written.
- Key: 4, size 9 bytes written.
- Key: 5, size 10 bytes written.
- Key: 6, size 8 bytes written.
- Key: 8, size 42 bytes written.
- Key: 13, size 3 bytes written.
- Key: 14, size 3 bytes written.
Section: 193
- Key: 2, size 8 bytes written.
- Key: 3, size 32 bytes written.
- Key: 4, size 32 bytes written.
- Key: 7, size 1 bytes written.
- Key: 9, size 64 bytes written.
Section: 208
Section: 217
- Key: 0, size 32 bytes written.
Section: 309
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Section: 322
Section: 334
Section: 341
- Key: 4, size 4402 bytes written.
Section: 354
- Key: 0, size 23 bytes written.
Section: 356
- Key: 1, size 8 bytes written.
Completed in 14.437 s
Old 06-28-2010, 14:18   #10 (permalink)
Member: 1178099
Sonork: 143
Thanks Meter: 3
ApeCoreSw: 31.0.014
- not available.
SIMLOCK invalid!
Counter: 0/3, 0/10
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=000000
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=000000
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=000000
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=000000
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=000000
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=000000
BLOCK 7: 1=CORRUPTED (00) 2=CORRUPTED (00) 3=CORRUPTED (00) 4=CORRUPTED (00) 5=CORRUPTED (00), DATA=
Last edited by iamsreekanthk; 06-28-2010 at 14:19. Reason: what ican do ples help me
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Page generated in 0.23827 seconds with 10 queries
