04-18-2009, 05:48 | #1 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | MXkey Tips and Tricks - HOT SOLUTION ONLY HERE
Run on first time, choose which module to execute ----------------------- Customizing Your Suite ----------------------- Configure Nokia Tool Open Nokia Service Tool, and click on this corner > * Enabled Imei changes -> if checked Imei/Esn changes will visible. Kindly check for your local law for this operation. * Auto backup ... -> Backup RPL on BUS check ( for DCT4) * Auto Create DP folder if not exist This is for directory creation specialy for .nfp extraction. Inside those directory, mcu, ppm, and cnt will be placed. * Default FBUS timeout This will set FBUS timeout (higher value = low speed but more accurate) * Highlight market item This will highlight the character you choosed. For example on picture, it highlighted on Indo, APAC, MD, and -X. You will see like this when you selecting files from product code Server : this is for your ask>rpl service. choose which one is fastest from your location. And this is the setting for your firmware directory thats for now, will add more info Best Regards Last edited by gbluez; 09-20-2010 at 12:33. |
The Following 236 Users Say Thank You to gbluez For This Useful Post: |
04-26-2009, 17:31 | #2 (permalink) |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | [Tips] What you should know about mobileEx - MXKEY in practice Here i will explain in step to save your time and optimize the job when using mobileEx, specially with 'Nokia Tool'. - Always select correct 'Generation' first before any operation. - Always Use "Scan" if you're working with non dead phone, this will help mobileEx to use 'correct' spesific setting for any phones attached to box. - Make sure phone is in correct mode for any FBUS/NON flashing operation, example: in Tuning & Testing page phone should be in TEST MODE, else will be best if the phone is in LOCAL MODE.Do phone mode change manually if needed. - For any operation, specially newly released phones, its better to save its security data (RPL + full pm) first before you do anything else. - if you noticed, there was a differences of flashing speed between FlashID/Manufacturer the option 'Fast flash' should not be enabled for flash chip "INTEL" - if you need only to change the language, select file setting as NORMAL. then check 'Language Only" should do the job - "Safe Flash" will save RPL backup from flash mode(even a DEAD one except ASIC11 phones). - Use "Restart" button every time you need to refresh the connection or restart the phone. - Use "..."(Read Phone Mode) button at the right of the phone mode combo to check if the phone if connected and synchronized. - mobileEx loads your selected "Products" folder to the phone model list, so make sure you have set the correct folder ("Options"). - to be continued. |
The Following 59 Users Say Thank You to Alim Hape For This Useful Post: |
04-29-2009, 04:37 | #3 (permalink) |
Member: 43548 Status: Offline Thanks Meter: 2,192 | First Drive: Nokia Service Tool Configuration: - Open mobileEx.exe - Choose interface(UFS/JAF/MTBOX/..), Push "Connect" - Click on the "star" logo, this is "Appl Modules Loader", Choose "Nokia Service Tool". - Wait for few second, until Nokia window is loaded. - Click on "quote" logo (at the right side of the star logo), Choose "Config". this is the Main Configuration Settings for Nokia. ~General Settings - Imei Changes Tick this if you want to use the Imei changes features (check you country law first !!!) - Auto Backup important data on "BUS Check" (for DCT4 only) When doing BUS check, RPL will be back up. - Save as <IMEI>_<TIMESTAMP>_back.RPL if you check this, the backup will be generated with timestamp every time you "BUS check", else will only save first time. - Show Detailed Info Recommended for Advance User, This will allow to display information log in detail. - Automaticaly select Generation on "Scan" Correct Generation will be automaticaly selected when you Scan the phone, for example: if you have DCT4 phone connected but active generation is BB5, after you scan product generation will be set to "DCT4"(Not applicable for DEAD phone') - Auto create DP folder if not exist New Folder in "Products\<PHONE_TYPE>" will be made, if not exists. - Default FBUS Timeout Default is 5000 ms= 5 second. Less=Faster respond but might have problem with phone which has longer booting time(WD2/BB5) - Highlight Market items. Usefull for fast select product code for spesific market. Enter whatever keyword you want, for example if you choose "EURO,UK" then 'Market Name' which contain word: EURO or UK will be highlighted. ~ Server You could change here the MXKEY server host, someday when we need to change them. Default is: nkrpl.biz ~ Directory Select "Products" folder in "Data Package 1"(Default=C:\Program Files\Nokia\Phoenix\Products). Select "Data Package 2" folder in "Data Package 2"(Default=C:\Program Files\Common Files\Nokia)/(Optional) Select "Wintesla" Directory(Default=C:\Wintesla). BR. |
The Following 42 Users Say Thank You to Alim Hape For This Useful Post: |
05-08-2009, 05:40 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Explain how to deal with the mx-key this tutorial by hamada-almasry thanks for supporting us Now explain how the flash more video check here br, Last edited by Andra; 05-08-2009 at 14:26. |
The Following 41 Users Say Thank You to Andra For This Useful Post: |
06-17-2009, 21:24 | #8 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | BB5 SL2 Unlocking step Backup IMEI + PM308 before Unlock big thanks to mr.sahil2000ind for info. |
The Following 89 Users Say Thank You to Andra For This Useful Post: |
07-12-2009, 21:36 | #10 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | flashing error in v3.2 revision 3.0, Public-Release flashing error in v3.2 revision 3.0, Public-Release Code: Error while erasing, Result: 00000000000000 , 0 Flashing terminated with error(s) RX Buffer: Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 BootLoader not responding, mostly RAM problem ! Code: Sorry, Unable to find flashloader for this FlashID ! Flashing terminated with error(s) RX Buffer: F7F372 try set fia flash br, Last edited by Andra; 03-24-2010 at 09:58. Reason: update pic |
The Following 112 Users Say Thank You to Andra For This Useful Post: |
07-13-2009, 19:18 | #11 (permalink) | |
Freak Poster Join Date: Jan 2009
Member: 946569 Status: Offline Thanks Meter: 326 | Quote:
bus check for nokia 5700 with fia files 8.49.19... give this error: Code: SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM1 ID: 00000295 EM2 ID: 00000B22 PUBLIC ID: 0AB00008E87D005847B3379EE82E876AE421EBC5 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg: [BB5] version: 8.36.0 revision: 2.0 size: 0x3A80 Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 Error sending loader (0200000000F172) Code: RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM1 ID: 00000295 EM2 ID: 00000B22 PUBLIC ID: 0AB00008E87D005847B3379EE82E876AE421EBC5 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0030 - 0040 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: ONENAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAPIDOv11_algo.fg: [XSR 1.5] version: 1.35.0 revision: 0.0 size: 0x272B0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS ID: 3D66090E94F3701646DA91CCD35BBAC22E5CBF73 Original Imei: 35396401500381 Original Product code: 0557255 Bluetooth ID: 001A16A62DDD Phone Type: RM-230 (Nokia 5700) SW Version: V 03.83.1 21-06-07 RM-230 (c) Nokia Imei plain: 35396401500381-7 Product Code: 0557255 Language Pack: - not available. Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF | |
The Following 24 Users Say Thank You to 1NOKIA1 For This Useful Post: |
07-14-2009, 01:19 | #12 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | @1NOKIA1 thanks for corrected, maybe need manual configuration for this flash update, will info coder for easy use,doesnt need manually change folder before flashing br, |
The Following 14 Users Say Thank You to Andra For This Useful Post: |
08-13-2009, 20:02 | #13 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | 1.Option 2.Server 3.Server List 4.Pick Server 5.Go Support - Credit lost - Reset Password - Change Email br, |
The Following 25 Users Say Thank You to Andra For This Useful Post: |
09-13-2009, 02:47 | #14 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | since update v3.2 revision 5.0, Public-Release we introducing new feature part of Erase Flash . Code: ............... ~ SAFE Erase will Protect PM Data from erase specially when doing 'Erase WHOLE flash'. ~ Usefull for recovering a DEAD phone without loosing SIMLOCK DATA Mean is Erase Flash area "WithOut" PM Data Area ( include Simlock ). lets me give some sample this case i have 5300 RM-146 can local mode so i backup first RPL anf PM if can't local mode,with this metods we can backup RAP NPC ( by selecting RAP ) this operation doesn't need local mode. Go Erase Flash. Dont forget tick Safe Erase Flash .. after finishing erase , go tab flashing . and flash by your phone market. here phone info after flashing .. if before not damage , then you have lucky. doesnt need RPL to repair last restore your IMEI , PM auth , Write PM without 308 area lets do some good work br, Last edited by Andra; 09-13-2009 at 16:59. Reason: add info .. |
The Following 38 Users Say Thank You to Andra For This Useful Post: |
11-06-2009, 16:57 | #15 (permalink) |
No Life Poster Join Date: May 2002 Location: dont ask!
Member: 12411 Status: Offline Sonork: 100.113572 Thanks Meter: 813 | [MXKEY - TIPS] MXKEY in practice - What you should know about mobileEx - here is a simple hint how to solve IMEI changes not appearing on newly installed v5.6 1. uninstall the old mxkey software. 2. delete everything inside C:\mobileEx\3.2\ NOTE: do not delete the folder 3.2 just the files inside it. 3. click start menu => RUN => regedit => HKEY_CURRENT_USER\Software\mobileEx right click on the mobileEx then delete. look below: 4. click start menu => RUN => regedit => HKEY_LOCAL_MACHINE\SOFTWARE\mobileEx right click on the mobileEx then delete. look below: 5. Now install the latest version of your MXkey.. below you can see BEFORE and AFTER the guide was made. Before: After: hopes this helps other having a problem about a clean installing of their MXkey. BR freddy www.gsmph.com |
The Following 39 Users Say Thank You to fred For This Useful Post: |
Cell Phone Tips and Tricks - Students and Cell Phones | murtaza_nns | Off Topic Zone | 3 | 10-05-2009 21:59 |
My tips and tricks and questions for N73 6280 etc | pearsonjohnboy | BB5BOX | 7 | 03-06-2008 14:58 |
Ah no, its dummy S40 phone and unfortunately S60 tip and trick doesn’t works on that | apocalypso | Nokia Base Band 5 ( BB-5 ) | 0 | 06-25-2007 14:05 |
D500 tips and trick over here!!!!!! | austinchan | SWIFT Platform | 4 | 06-07-2005 14:40 |
9210 Tips and Trick #1 and #2 | X-Shadow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-26-2001 02:26 |
