05-04-2009, 12:35 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | N73 after eritting calculated rpl become startup failed this is info log of phone Version Info: MCU SW version: V 05wk47v61 09-07-08 RM-133 (c) Nokia. HW version: 6000 RFIC version: 17211721 DSP version: scarfe_mc.05wk46v50p2 Retu version: 15 Tahvo version: 22 Serial Numbers: IMEI plain: 357651013847867 IMEI spare to net: 3A 75 56 01 31 48 87 06 IMEI SV to net: 33 75 56 01 31 48 87 76 F7 Other Info: Model : Nokia N73 (Imaging Phone) CS type : GSM850/900/1800/1900/WCDMA2100 Project Name: Scarfe(EU) HW Details: RAP: RAP3G v2.11 PA-4396177 OMAP: OMAP 1710-n/a RETU: RETU v3.02-4396177 TAHVO: TAHVO v4.1-n/a RF: HINKU v3.10A + VINKU v3.14A-n/a + n/a Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF i recived N73 which imei was like 1234567654321 therefore i used ask2rpl service and bought rpl from server after writting rpl now phone is phone startup failed when i tried with pm auth than recieve this error Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Error sendAck! this is selftest log Phone Type: RM-133 SW version: V 05wk47v61 09-07-08 RM-133 (c) Nokia. ID Test name Startup Result 88 TAHVOINT Y passed 46 UEM_CBUS_IF Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 33 SIM_LOCK N passed 93 SECURITY N !failed ! 90 PWR_KEY N passed 2 CURRENT_CONS N passed 20 BACKUP_BATT N passed 58 CMT_APE_WAKEUP N passed 56 SLEEPCLK_FREQ N passed 42 RADIO N passed 96 HOOKINT N passed 101 BTEMP N passed 49 VIBRA N passed 8 MBUS_RX_TX_LOOP Y passed 108 EXT_DEVICE N passed 6 IR_LOOP N passed 7 KEYBOARD_STUCK N passed 21 LPRF_IF N passed 22 CAMERA_IF N passed 5 CAMERA_ACCELERATOR N passed 37 SEC_CAMERA_IF N passed 38 CAMERA_AUTOFOCUS N passed 44 LPRF_AUDIO_LINES N passed 59 MAIN_LCD_IF N passed 71 BT_WAKEUP N passed Last edited by Maiwand khan; 05-04-2009 at 12:44. |
05-06-2009, 06:58 | #5 (permalink) |
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | How it can be hardware phone was Ok before. imei was 12345676654321 after writting rpl it become phone start up failed thanx for replay |
05-06-2009, 07:56 | #6 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | try write other pm with full area without 308 sector if still not luck, maybe with litle trik skip sx-4 from here br, |
The Following User Says Thank You to Andra For This Useful Post: |
05-06-2009, 08:23 | #7 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Bangladesh
Member: 252929 Status: Offline Sonork: 1583255 Thanks Meter: 66 | 1.Erase full 2.flash with latest fw. & same product code 3.write rpl again 4.write pm (1 & 309 field) with sx4 hope ur phone will ok |
The Following 2 Users Say Thank You to Mithu For This Useful Post: |
05-06-2009, 08:55 | #8 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Kabul,Afghanistan Age: 35
Member: 496203 Status: Offline Sonork: 100.1583640 Thanks Meter: 232 | @Maiwand khan Try to format ur mobile manually.(Send button+*+3+Power) If still same problem sx4+write modefied pm+sx4. Enjoy |
The Following User Says Thank You to UNIQUEM For This Useful Post: |
05-11-2009, 14:12 | #9 (permalink) |
Junior Member Join Date: Jun 2007
Member: 522899 Status: Offline Thanks Meter: 3 | no now all of rpls for n73 have problem line of variants dont write to phone i dont know why? if any body can solve this problem pls post here |
The Following User Says Thank You to shahram2222 For This Useful Post: |
05-12-2009, 05:26 | #10 (permalink) |
Member: 522899 Status: Offline Thanks Meter: 3 | this is a correct rpl for n73 [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=backup NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303534353033330000000000 NPC_DATA_2=0000000000000000000000009143E094EB528F4 79EDA3300646F7242000000001CF00014839B4650 NPC_DATA_3=7C60753C24A224C961D341BC5E8D0D504A0902E 261268C14FCD8A2C9093523BC6FC0D144443A8575 NPC_DATA_4=53000CFF2482A24D6FD577D2000000000000000 000000000000000000200000047534D0000000000 NPC_DATA_5=3375560281018522FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=865D88D41C00000000000000000000000000000 0000000000000000000000000D8CA78091F1B6333 NPC_DATA_7=E3843CA3ACA964D3A7F5CB68E382BC4D69256E7 B7F70F48AF1DA843E3DDB2679066512CD16DAB5DD NPC_DATA_8=A989246D8F05E3E5D3D0235D18B27EC966461B3 9FC241AF752009FB8B42FA0D7331C3B0B95324CAC NPC_DATA_9=C9CE494E8CD6E503CA7F5E131B3647485139D65 CA73C2F6FC01AC4FC53B81FC5CD509DE5B2D5834E NPC_DATA_10=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF NPC_DATA_11=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF NPC_DATA_12=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF NPC_DATA_13=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF VARIANT_DATA_1=357043A5020041500100000030353435303 333430033E093ED6448456D54080074A89A0000000000 VARIANT_DATA_2=08000000220000000000000000000000821 5ECF505D7DA00B59F092B9658AAE6088144D4CB3E111F VARIANT_DATA_3=2ECE2EC39A6B852B18E8D443859D00E3106 F508E1879591E6A785DE585A04FE68F6E11E07687A4FD VARIANT_DATA_4=DFCFD26C5393FF569D5FC0282B64D13F7D6 DE9DD7A1862F3FC3B56E19EE08EA63244739AC39C9D12 VARIANT_DATA_5=FB4DEF19E6A664C6C017DDD8A329110B248 B0E7E98581055FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF VARIANT_DATA_6=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF VARIANT_DATA_7=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF and this is a new rpl for n73 this rpl have not variant codes in it [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=backup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and the way for solving this problem 1 - erase 2 - flash with product code of phone 3 - write rpl 4 - sx4 5 - write pm if u want write rpl with mt , use 1,49 version for write rpl and sx4 |
05-13-2009, 09:02 | #11 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: South Sumatra, Indonesia Age: 42
Member: 95561 Status: Offline Sonork: 1573725 Thanks Meter: 31 | Quote:
You have damaged superdongle key in your "security" section afaik, the only way to solve the problem is by using ask2rpl method. Couse i already try many many time, to use the sx4 bypass method but it cant fix the problem. | |
The Following User Says Thank You to vi element For This Useful Post: |
Contact service after writing calculated RPL | Hitec Wireless | Cyclonebox | 9 | 09-23-2009 18:19 |
N73 phone start up failed also after writting calculated rpl | Maiwand khan | Cyclonebox | 7 | 09-19-2009 15:52 |
Nokia 5220 still contact service after write calculated rpl | kungpaoski | Nokia Base Band 5 ( BB-5 ) | 10 | 05-22-2009 21:35 |
E 71 Rm-346 after flash now is phone startup failed | F@RUK S | HWK | 2 | 05-20-2009 20:13 |
