02-21-2010, 15:55 | #1 (permalink) |
Insane Poster Join Date: Jan 2010
Member: 1215828 Status: Offline Thanks Meter: 9 | N73 please help Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Processing file: N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx as MCU [BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 48.99 MB Supported RAP Ids: 0103192101003000, 010C192101003000 Supported APE Ids: 17100708 APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: F9E012D16BBD7AC7C1AB65834E3EA6759B8E3937 ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B21 PUBLIC ID: 17400107F9BB00548BA6D1DE3F52B7008074DFB3 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 ExtDEVC: FFFF 0000 - 0000 0000 Flash ID not supported for this loader (RAP3Gv3_algo.fg) Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Warning: No RAP Flash Chip Detected SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS is blank/erased. Partitioning ...OK Total erase size: 91.38 MB CMT NOR area [00080000-00731951] CMT NOR area [00000000-0005FFFF] CMT NOR area [001E0000-001FFFFF] CMT NOR area [00880000-00FEFFFF] APE NAND area [00000000-0007FFFF] APE NAND area [00080000-000FFFFF] APE NAND area [00100000-0025FFFF] APE NAND area [003C0000-04E1FFFF] erased in 0.062 s Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00000400, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 31.593 s RX Buffer: C7012D0103CD00 |
02-21-2010, 16:03 | #3 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | what was the status of phone? did you check phone hardware if has already repaired before? this result below shows that you might had hardware problem.. Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00000400, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 31.593 s RX Buffer: C7012D0103CD00 |
02-21-2010, 16:14 | #8 (permalink) |
Member: 1215828 Status: Offline Thanks Meter: 9 | Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: F9E012D16BBD7AC7C1AB65834E3EA6759B8E3937 ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B21 PUBLIC ID: 17400107F9BB00548BA6D1DE3F52B7008074DFB3 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 ExtDEVC: FFFF 0000 - 0000 0000 Flash ID not supported for this loader (RAP3Gv3_algo.fg) Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Warning: No RAP Flash Chip Detected SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS is blank/erased. Original Imei: 00000000000000 Original Product code: |
02-21-2010, 19:13 | #12 (permalink) |
Banned Join Date: Dec 2006 Location: inside of infinity best tool
Member: 411831 Status: Offline Thanks Meter: 215 | 65% cable, 35% hardware problem check cable properly on harware check APE voltage. |
The Following User Says Thank You to msantar For This Useful Post: |
N73 please help me... | karikari | J.A.F. By Jafsupport.com | 2 | 04-11-2008 21:17 |
need smartmovie for n73 please help me | illyas007 | Nokia Multimedia | 0 | 02-20-2008 17:06 |
N73 Please HELP.. | devilangel | Nokia Base Band 5 ( BB-5 ) | 6 | 07-11-2007 23:11 |
