03-16-2012, 14:35 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: bhilai(chatisghar)
Member: 900306 Status: Offline Thanks Meter: 36 | N73 security test faild plz help SW version: V 05wk47v61 09-07-08 RM-133 (c) Nokia. Imei plain: 35354802141121-1 Product code: 0543843 Battery voltage: 4713 mV, current: 65 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353548021411211 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN DOING EVERY THING BUT WHEN RECOVER CRT IT SAYS [InternalErrorFault] CERT [0543843] data not available for this phone (case id=0xCE01) |
03-16-2012, 16:45 | #2 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | 1. back up rpl 2. get address, dont tick safe erase, then click erase add 3. flash with latest version 4. restore imei 5. repair sd 6. write full pm 7. unlock/repair simlock 8. upload camera dcc if needed 9. do buscheck n pray good luck bro br Sent from my iPhone using Tapatalk |
03-17-2012, 02:25 | #7 (permalink) |
Freak Poster Join Date: May 2006
Member: 272137 Status: Offline Thanks Meter: 75 | After upload pm and repair sd self test still shows security failed just downgrade or upgrade firmware ,full factory reset job done I done few phones this way specially n70 ,6680 |
06-04-2012, 16:48 | #8 (permalink) |
Junior Member Join Date: Apr 2012
Member: 1748161 Status: Offline Thanks Meter: 0 | SAME PROBLEM CANT ABLE TO REPAIR Phone type: RM-133 (Nokia N73) SW version: V 05wk47v61 09-07-08 RM-133 (c) Nokia. Imei plain: 35571802780887-0 Product code: 0539691 Battery voltage: 4647 mV, current: 129 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355718027808870 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
06-04-2012, 19:50 | #10 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh
Member: 1220933 Status: Offline Sonork: 100.1590184 Thanks Meter: 471 | just try this 100% tested for all any problem contact me only write pm 1,309 some time can't solve your problem you must need erase old pm fully after reset or erase rpl from phone u must need erase full pm at least 3 times ( must need backup rpl) than do all process 1. backup rpl 2. erase rpl 3. erase full pm 3 times 4. restore rpl 5.repair all data 6. pm auth and write good pm (new) with pm 1,309 u will must success more here http://forum.gsmhosting.com/vbb/f550...wered-1031277/ thanks any problem contact me |
06-04-2012, 20:01 | #11 (permalink) | |
Junior Member Join Date: May 2012
Member: 1756544 Status: Offline Thanks Meter: 0 | Quote:
try use mxbox 1st repair sd 2nd write pm 1-309 than check 100% ok | |
06-05-2012, 19:21 | #12 (permalink) |
Banned Join Date: May 2012 Location: in ur heart Age: 32
Member: 1761678 Status: Offline Sonork: 100.1615439 Thanks Meter: 370 | y u disabled recover cert option only for n73 gluez brother |
The Following User Says Thank You to tauheed9 For This Useful Post: |
06-07-2012, 14:24 | #13 (permalink) | |
Member: 900306 Status: Offline Thanks Meter: 36 | Security test faild Quote:
done your soluation but no soluation not only in this set i have 4 pic off n 73 same problem every one of them .................................................. ........................... .......................... Cant able to make crt recover........ In any n73 mobile plz check.............. | |
06-07-2012, 15:02 | #14 (permalink) | |
Member: 900306 Status: Offline Thanks Meter: 36 | Quote:
PLZ make this option working................. DOING EVERY THING BUT WHEN RECOVER CRT IT SAYS [InternalErrorFault] CERT [0543843] data not available for this phone (case id=0xCE01) not only in this set in working set this opption is not working | |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
