01-16-2013, 07:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: India
Member: 1152038 Status: Offline Thanks Meter: 257 | N73 SECURITY_TEST failed! SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Imei plain: 35354802152xxxx Product code: 0539354 Battery voltage: 5069 mV, current: 19 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35354802152xxxx Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN 1.I repair SD 2.super SD auth 3.pmm auth 4.write pm but same problem SECURITY_TEST failed! any solution plz |
01-16-2013, 09:08 | #6 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 812422 Status: Offline Thanks Meter: 18 | I try to repair by this solution 100% work 1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) |
01-16-2013, 09:44 | #7 (permalink) | |
Member: 1152038 Status: Offline Thanks Meter: 257 | Quote:
plz need help | |
