Old 05-18-2011, 07:12   #1 (permalink)
Misbahullah's Avatar
Member: 938983
Sonork: 100.1585802
Thanks Meter: 102
N73 Phone Start up failed Contact Retailer (ANSWERED)
I have done every possible thing but could not successful here is the log
before operation
Phone Type: RM-133 (Nokia N73)
SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia.
Imei plain: 35765201625578-5
Product Code: 0539295
Battery voltage: 4791 mV, current: 95 mA
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
Imei net: 357652016255785
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
after operation
Battery voltage: 4415 mV, current: 258 mA
ApeCoreSw: V 4.0839.42.2.1
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 05-18-2011, 07:23   #2 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
Thanks Meter: 95
repair sim lock with ms key. its simple
Old 05-18-2011, 07:36   #3 (permalink)
Member: 462076
Sonork: 100.1586314
Thanks Meter: 307
contact me on [email protected].
i will help u bro
Old 05-18-2011, 07:58   #4 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 4,307
Bro...... its a simple repair or update "sim lock"
your poblem 10000000000% solved...................................
Br,
Aniaxn
Old 05-18-2011, 08:19   #5 (permalink)
r-jcomm's Avatar
Member: 601913
Sonork: 100.1597350
Thanks Meter: 658
before operation
Language Pack:
- not available.
SIMLOCK invalid!
Counter: 0/3, 0/10
after operation
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
just format file system with mx key or join me at [email protected]
The Following User Says Thank You to r-jcomm For This Useful Post:
Old 05-18-2011, 10:53   #6 (permalink)
Member: 231600
Thanks Meter: 44
Repair simlock is Ok
The Following User Says Thank You to Dung Yaiba For This Useful Post:
Old 05-18-2011, 11:34   #7 (permalink)
AniAxn's Avatar
Member: 1045758
Thanks Meter: 4,307
Bro........just do...... your phone is off...... press together.....*+ call +3 key and on the phone...............your problem will be 1000000000% solved.............
Br,
Aniaxn
The Following 2 Users Say Thank You to AniAxn For This Useful Post:
Old 03-11-2012, 10:09   #8 (permalink)
Registered User
Member: 1151975
Sonork: 100.1615809
Thanks Meter: 6
i have n73 in problem phone start fail contect retailar log is here Phone type: RM-133 (Nokia N73)
SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia.
ApeCoreSw: V 4.0850.43.0.1
Imei plain: 35765201142605-0
Product code: 0539295
Battery voltage: 4119 mV, current: 249 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK_TEST passed
Phone version(4.0850.43.0.1) outdated, latest version on server is: 4.0839.42.0.1
Imei net: 357652011426050
Counter: 0/3, 0/10
SW version 4.0839.42.0.1 released for Nokia N73
Old 03-11-2012, 10:11   #9 (permalink)
Registered User
Member: 1151975
Sonork: 100.1615809
Thanks Meter: 6
when sim lock repair log here Imei net: 357652011426050
Counter: 0/3, 0/10
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C085406A
Using device: HTI, FW ver: 00.50, SN: 00002D7E
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012)
Using cached productData.
PUBLIC ID: 0850020800D2675094C008343955E203FD9BABA3
PRIVATE ID: 0FCBDC68DDBA24E58AC2054A4FE33543102464B1
Updating SIMLOCK ...error 0x1
Reading Simlock info ...
SIMLOCK_DATA corrupted!
Old 03-11-2012, 10:28   #10 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
Counter: 0/3, 0/10
format manually by turning off the phone, then pres and hold CALL+*+3 button at the same time until its done.
then there 2 options u can try to solve simlock:
go to tab service>imei&security> tick on Init simlock, click update splock
or
go to tab service>imei&security> tick on unlock by code, click calc nck
good luck bro
br
Old 03-11-2012, 15:01   #11 (permalink)
biswajit74's Avatar
Member: 900306
Thanks Meter: 36
TRYING TO RECOVER CERT BUT
[InternalErrorFault] CERT [0543843] data not available for this phone (case id=0xCE01)
PROBLEM IS
Imei plain: 35354802141121-1
Product code: 0539692
Battery voltage: 4693 mV, current: 0 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 353548021411211
Counter: 0/3, 0/10
Old 03-11-2012, 17:51   #12 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
Thanks Meter: 95
@ biswajit74
>load pm 1 & 309
>click "repair sd"
>now dont allow software to write pm from its local cache. press "write" to write ur uploaded pm.
thats all
Old 03-11-2012, 21:50   #13 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
recover cert should only performed if certificate is corrupted. else, wasting time.
on most case, one click repair SD should be done.
Old 03-12-2012, 07:27   #14 (permalink)
biswajit74's Avatar
Member: 900306
Thanks Meter: 36
Originally Posted by rabirabi View Post
@ biswajit74
>load pm 1 & 309
>click "repair sd"
thats all
done everything but no soluation
Old 03-12-2012, 07:34   #15 (permalink)
biswajit74's Avatar
Member: 900306
Thanks Meter: 36
Imei plain: 35640601211798-1
Product code: 0539354
Battery voltage: 4698 mV, current: 0 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 356406012117981
Counter: 0/3, 0/10
after sd repiar
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C0802E17
Using device: HTI, FW ver: 00.50, SN: 0000D080
Connection status: EHCI:HUB:HUB:HUB:USB 2.00 (Full-speed)
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011)
ApeCoreSw:
V 4.0850.43.0.1
PUBLIC ID: 1AF001183DCF0154E9AAE9FFB9538920F2051CFB
PRIVATE ID: BC54684469B37720CF61A71E68E143F88DDB2608
Updating SUPERDONGLE_KEY ...OK
Authenticating to SUPERDONGLE ...
SUPERDONGLE authorized !
Writing RFBB data: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb\N73_RM-133.txt ...
Writing RF settings to phone ...OK, finished. 20 Records found.
Writing BB settings to phone ...OK, finished. 9 Records found.
Done.
but... same problem.....
i have 2 handset in my hand but having same problem
any soluation.............
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Page generated in 0.31589 seconds with 9 queries
