03-17-2010, 11:43 | #16 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2008 Location: California USA
Member: 743601 Status: Offline Sonork: 83392409 Thanks Meter: 138 | |
03-17-2010, 16:06 | #18 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Saudi Arabia
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35643801780703-5 Product Code: 0539354 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356438017807035 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF after repair sd security test failed..........???????????????? |
03-17-2010, 16:58 | #19 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | 1 back rpl 2 full erase on mxkey 3 flash phone 4 writ rpl thenwrit this rpl http://www.4shared.com/file/23918971..._made_by_.html 5 mxkey>serves>imei&securty>imei rebuild>repair sd 6 go to pm >click sd auth writ pm (wait 2mnt) 7 full factory |
03-17-2010, 17:58 | #20 (permalink) | |
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | Quote:
03-17-2010, 18:17 | #21 (permalink) |
Member: 231153 Status: Offline Thanks Meter: 313 | pls bro, try to do my styps but flash phon on ufx 1 back rpl 2 full erase on mxkey 3 flash phone 4 writ rpl thenwrit this rpl 4shared.com - free file sharing and storage 5 mxkey>serves>imei&securty>imei rebuild>repair sd 6 go to pm >click sd auth writ pm (wait 2mnt) 7 full factory and format im tested |
03-17-2010, 19:46 | #22 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: Tarlac City PHILIPPINE'S
Member: 138913 Status: Offline Sonork: 100.1658792 Thanks Meter: 2,675 | just add me on your ym dr.aljawal i will help you. Quote:
03-17-2010, 21:28 | #23 (permalink) | |
03-17-2010, 21:32 | #24 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | Imei net: 356438017807035 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED SL1 JAF_Nokia_BB5_and_BB5Plus_201_FREE_by_Zulea raparier 100%okey |
03-17-2010, 21:54 | #25 (permalink) |
Member: 231153 Status: Offline Thanks Meter: 313 | ok bro, click rest npc and go to pm clcik erase then writ rpl repair sd>auth writ this pm 4shared.com - online file sharing and storage - download n73-rm-133-mt-full.pm and (wait 2mnt) |
03-18-2010, 10:21 | #26 (permalink) |
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | Master i do the step by step.when i write the pm last time displayd like massg"you are about to write simlock settings. you wand to skip?"................? |
03-18-2010, 11:22 | #27 (permalink) |
No Life Poster Join Date: Dec 2005 Location: syria
Member: 205475 Status: Offline Thanks Meter: 179 | man i faced same problem and solving it by following steps: 1-after repair sd and write pm 1+309 now the SECURITY_TEST failed! so go to service+imie rebuild+ recover cert if that not solve ur bp try second solution 2-go to service + quick fix + bb5 sw downgrade fix +do select job now should sd need repair so just make sd repair and write good pm if all of that not solve ur bp go to service + phone tests + bb5 certificate validation and but her the info |
03-18-2010, 13:01 | #28 (permalink) |
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35643801780703-5 Product Code: 0529607 ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 ApeVariant: V 4.0839.42.2.1-08 27-09-2008 RM-133 Language Pack: English,02 Uk SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356438017807035 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: E89925DF504F3BA80020CBCC3D2918FD7CEEF1CA ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0B300213CF8E01546A7014C4F06CE93D4BAF43DC ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Reading RAP NPC (0x168 bytes) Original Product Code: 0529785 Reading RAP VARIANT (0xB8 bytes) Product Code: Product Code missmatch ! Reading RAP CCC (0x0 bytes) Reading RAP HWC (0x0 bytes) the product code missmatch................how can solve this pro ? my frd am very teared with tis mobile pls................ |
03-18-2010, 13:59 | #29 (permalink) | ||
Freak Poster Join Date: Jun 2005
Member: 151576 Status: Offline Sonork: 100.1602537 Thanks Meter: 58 | Quote:
N73 RM-132 dead with mx key | parihar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 02-12-2012 19:50 |
n73 problem after flash with mx key !!!!!!! | ahmad yousif | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 18 | 07-09-2010 04:24 |
n73 startup filer error with cyclone.....? | alavukt | Cyclonebox | 11 | 03-18-2010 15:19 |
n73 startup filer ........? | alavukt | Cyclonebox | 5 | 03-15-2010 12:43 |
DCT4 and WD2 always errors with mx key flasing | ghalambuay | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 01-30-2010 08:10 |
