04-03-2010, 09:55 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: TrustUnlocking™ Age: 34
Member: 753117 Status: Offline Sonork: 100.1611207 Thanks Meter: 136 | n76 problem[SOLVED] Phone Type: RM-135 (Nokia N76) SW Version: V 06wk41v34.2 24-08-07 RM-135 (c) Nokia Imei plain: 35626201821967-1 Product Code: 0550409 ApeCoreSw: 30.0.015 ApeVariant: 30.0.015, ApeTest: rm135_ENO_x_2007wk07v0.090 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356262018219671 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
04-03-2010, 10:03 | #3 (permalink) |
Member: 753117 Status: Offline Sonork: 100.1611207 Thanks Meter: 136 | bro write pm see full info sing device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 06wk41v34.2 24-08-07 RM-135 (c) Nokia ApeCoreSw: 30.0.015 SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: A8C1D6713E691FF8 Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 1, size 4 bytes written. Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 5 (4 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 15 (4 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 27 (4 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (80 bytes) - 308 skipped Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 40.656 s |
04-03-2010, 10:27 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | SIMLOCK & Superdongle repair 1. backup NPC RPL. ( Service - IMEI& Security - IMEI Rebuilt - selct option as NPC - backup RPL ) 2. erase EEPROM only ( Flash - Advanced - Get address - tick eeprom - erase flash ) 3. Repair SUPERDONGLE 4. Full Factory ( Service - Actions - tick "Full Factory" - reset selected ) 5. SUPER SD Auth + Write PM1,309 br, |
04-04-2010, 13:32 | #8 (permalink) |
Member: 753117 Status: Offline Sonork: 100.1611207 Thanks Meter: 136 | hasan not solve my problem but umair rashid only need 10 minute this problem solve thanks umair rashid Phone Type: RM-135 (Nokia N76) SW Version: V 06wk41v34.2 24-08-07 RM-135 (c) Nokia Imei plain: 35626201821967-1 Product Code: 0543059 ApeCoreSw: 30.0.015 ApeVariant: 30.0.015, Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356262018219671 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
n76 problem | TrustUnlocking™ | Universalbox | 7 | 04-04-2010 12:50 |
N76 problem | ForestGriffin | Nokia Hardware & Hardware Repair | 5 | 01-10-2010 00:10 |
n76 problem | jasir_kp | Nokia Hardware & Hardware Repair | 0 | 08-20-2009 07:14 |
N76 problem, Info check fails, won't enter local mode | ManWolf | HWK | 1 | 11-06-2007 22:57 |
n76 problem with flash!!!!! | eyal28 | Universalbox | 12 | 11-03-2007 22:33 |
