03-15-2010, 13:16 | #2 (permalink) |
Product Supporter Join Date: Mar 2008 Location: Thailand Age: 46
Member: 716581 Status: Offline Thanks Meter: 767 | SD and security test failed Repair by MXkey Take it easy!!! http://www.fileden.com/files/2008/8/.../SD_Repair.swf |
The Following 2 Users Say Thank You to nongmobile For This Useful Post: |
03-15-2010, 16:17 | #5 (permalink) |
Banned Join Date: Oct 2009 Location: Inside Digital GSM Age: 35
Member: 1149774 Status: Offline Sonork: 0313-9541047 Thanks Meter: 1,163 | already posted many times................ any way thanks must visit here \SD Repair\Security Repair\SimLock Invalid\All Solution By MX-KEY 6120c \SD Repair\Security Repair\SimLock Invalid\All Solution By MX-KEY - GSM-Forum Regard: GSM_3GN |
The Following 2 Users Say Thank You to gsm_3gn For This Useful Post: |
3110 not charging problem solved by sd repair thanks mxkey | SanjanMobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-16-2010 16:55 |
100% ok SD Repair with Mxkey | ashik123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-06-2010 10:20 |
Post here sd repair from mxkey | azad4u | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-03-2010 16:00 |
n96 successfully sd repair by mxkey | azad4u | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-03-2010 15:24 |
Take it easy, using more easily ! | Mcnbox | Main Sales Section | 0 | 03-15-2009 19:55 |
