03-27-2010, 13:47 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 452892 Status: Offline Thanks Meter: 104 | N95 8Gb dead after flash, error boot cmt loader i unlocked it successfull by mxkey, but want to change its langpack, jaf and N-box+HWK cant flash, they only show "error cmt boot loader", i try to flash with Mxkey, and i flashed it successfully.but phone cant start, phone only show ligh keypad and black screen... now i can check or get info ok.but phone cant turn on.... this is my log... SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359542017778166 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
03-27-2010, 14:18 | #2 (permalink) |
Freak Poster Join Date: Aug 2006 Location: BHOPAL INDIA
Member: 326603 Status: Offline Thanks Meter: 25 | try to flash with dead usb flashing using jaf, if still same problem then its sdram problem |
The Following User Says Thank You to tsavofather For This Useful Post: |
03-27-2010, 14:31 | #4 (permalink) |
Member: 452892 Status: Offline Thanks Meter: 104 | my phone cant connect to pc via USB mode bro. i dont know, maybe usb line has problem...so if my phone could connect via usb, i think i could flash it and phone is ok...because it cant connect via usb, so i used FBUS Cable, and now my phone cant turn on... |
03-28-2010, 03:11 | #6 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: love me if you can
Member: 1150088 Status: Offline Sonork: ============ Thanks Meter: 254 | Quote:
If you sure usb mode problem can you resolder or maybe driver usb flasher not installed ??? Full flash with Fbush cabel and with charger . Good luck | |
03-28-2010, 03:49 | #7 (permalink) |
Member: 452892 Status: Offline Thanks Meter: 104 | first i unlocked it successfully by Mxkey, i can make call ok...but i cant flash it by JAF or N-box, i try to flash it by Mxkey successfully, but i cant turn it on, it only shows me light keypad and no display on screen.......HELP |
03-28-2010, 04:44 | #9 (permalink) |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | cmt error sometime problem in hardware but most of the time in n95 it was the problem of cable check cable( battery pins) and flash it with higher version with potato |
03-28-2010, 05:04 | #10 (permalink) |
Member: 452892 Status: Offline Thanks Meter: 104 | i tried bro.my cable has 7pins, now i can check and read info of phone...but phone cant turn on...when i plug fbus cable phone show local mode...PLZ what is my phone's problem??? |
03-28-2010, 05:07 | #11 (permalink) | |
Member: 452892 Status: Offline Thanks Meter: 104 | Quote:
nó ko kết nối wa usb đc anh, chắc bị lổi usb rùi, vì thế em mới cáp fbus. thằng jaf nó báo error loading cmt boot, còn HWK thì chạy đc 1 dòng xóa 1 dòng write là progress fail...HELP em với... | |
03-28-2010, 05:12 | #13 (permalink) |
Member: 452892 Status: Offline Thanks Meter: 104 | i tried: -erase with bb5 unirapido file -full flash with v35 firmware -Write backup rpl -Repair SD -Write pm with Super Auth -Write ENO file Format phone with JAF, Mxkey, format is ok but phone still DIE...pLZ help |
nokia n95 8gb dead after flashing rm 421 | sunshinelin | Cyclonebox | 11 | 06-10-2010 09:43 |
n95 8gb dead after flash | gorgans | Infinity-Box | 4 | 08-04-2009 16:06 |
