02-07-2010, 15:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: india Age: 36
Member: 690456 Status: Offline Sonork: 1587650 Thanks Meter: 117 | after sd repair securitty test faild in n73 i do repair sd but set is same cudetion but sl data ok but securitty test faild repair sd ok pm auth is ok but i dow lode one pm file that writing time this error CERT_PROG_DATA_OUT_CMT NOT valude integer vlue Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 4ADA4182B5208F1F5504DB14E3EFDF773FFFCD10 ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 2060000841CD01547E04F79EB8A7D8B91F037080 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Original Imei: 35643801671142 Original Product code: 0552007 Bluetooth ID: 001C356CA84C Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35643801671142-8 Product Code: 0539691 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356438016711428 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF PLZ HIVE ME ONE SOLTION |
02-07-2010, 15:45 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | Your phone was OKAY before,after doing Sd it becomes a worst condition. Why don't you people USE What we call a SENSE ? Now, press "bb5 certificate validation"and post logs. Br, Umair |
02-07-2010, 15:48 | #3 (permalink) |
Junior Member Join Date: Oct 2006 Location: alexandria
Member: 367264 Status: Online Thanks Meter: 22 | 1. make Simlock RPL repair 2. make SD RPL repair 3. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model Warning: Before anything You must take a backup copy of ( full pm 1 to 512 & rpl ) |
02-07-2010, 15:52 | #4 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1009679 Status: Offline Thanks Meter: 166 | my 5310 got simlock problem check this RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101013000 EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 11300212FEF30154BB2EA018EF07B41D4EEF9A11 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D Reading RAP NPC (0x168 bytes) Begin Certificate Request ... Connecting to server ...OK, Login ... ERROR: No certificate found in the database ! RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101013000 EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 11300212FEF30154BB2EA018EF07B41D4EEF9A11 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D Reading RAP NPC (0x168 bytes) Original Product Code: 0556852 Reading RAP VARIANT (0x0 bytes) Reading RAP CCC (0x160 bytes) Product Code: 0564465 Product Code missmatch ! Reading RAP HWC (0x0 bytes) HWC empty ! |
02-07-2010, 15:55 | #5 (permalink) |
Member: 1009679 Status: Offline Thanks Meter: 166 | when i write rpl without npc same 5310 it failed in hwc EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 11300212FEF30154BB2EA018EF07B41D4EEF9A11 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D Updating CMT CCC ...OK Updating CMT HWC ...failed, Result: 06A0000000317200 Certificate programmed successfully ! Phone Type: RM-303 (Nokia 5310 XpressMusic) SW Version: V 10.10 23-03-09 RM-303 (c) Nokia Imei plain: 35865301165076-3 Product Code: 0547348 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! |
02-07-2010, 15:58 | #6 (permalink) |
Freak Poster Join Date: Oct 2005 Location: ITALY
Member: 192348 Status: Offline Thanks Meter: 6 | Read this topic could help you, also i have your problem with a N73: http://forum.gsmhosting.com/vbb/showthread.php?t=921020 BR |
02-07-2010, 16:46 | #10 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: pakistan Age: 38
Member: 78884 Status: Offline Sonork: mohsin111 Thanks Meter: 92 | Quote:
02-07-2010, 16:49 | #11 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: anywhere
Member: 548078 Status: Offline Thanks Meter: 80 | Quote:
bro, i have same problem, my phone is WD, reboot after 3 minutes, i have repair using SD and wrting pm, using sx4 auth, my problem is solved. | |
02-07-2010, 16:55 | #12 (permalink) |
Member: 1009679 Status: Offline Thanks Meter: 166 | HWC empty ! RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101013000 EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 11300212FEF30154BB2EA018EF07B41D4EEF9A11 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D PA_SIMLOCK: PA_SL2 |
02-07-2010, 21:08 | #13 (permalink) |
No Life Poster Join Date: Apr 2009 Location: MUSLIMS NOT A TERRIORST Age: 46
Member: 1016083 Status: Offline Thanks Meter: 103 | http://forum.gsmhosting.com/vbb/showthread.php?t=920409 AFTER ANY ACTION SEE HERE |
Successfully Repaired 3110c Security Test failed after SD Repair | romeoluv56 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 05-14-2012 12:37 |
6680 after SD repair security test failed | guljee786 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 19 | 09-17-2010 05:11 |
6086 after sd repair security test fail | denard | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 21 | 03-13-2010 00:33 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
after sd repair SECURITY TEST failed | mobitechnepal | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-04-2010 08:41 |
