09-14-2011, 08:57 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: Madhya Pradesh India
Member: 767783 Status: Offline Thanks Meter: 37 | Nokia 1616 flashing Error mx.. log.... Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921.60 Kbps Flash ID: 00EC 227A [Samsung ] Processing file: rh125_006.510 Downloading item CODE:hw_f11_rh125_r06.510.fls, num block: 3, size: 4.14 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 58.125 s Erasing area 0x00C60000-0x00E72C7E ...OK Programming completed in 58.672 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.187 s Checksum mismatch: Phone calculated 0x41EB, software calculated 0x31F6 Processing file: rh125_006.51mg Downloading item CUST:hw_f11_rh125_006.51mg.fls, num block: 1, size: 1.90 MB Erasing area 0x00210000-0x003F6C3E ...OK Programming completed in 53.765 s Checksum mismatch: Phone calculated 0x0A95, software calculated 0xC44A Processing file: rh1250_nai06.51mg Downloading item CUST:hw_f11_rh1250_nai06.51mg.fls, num block: 1, size: 419.20 KB Erasing area 0x00EB0000-0x00F17FBE ...OK Programming completed in 11.546 s Checksum mismatch: Phone calculated 0x36C7, software calculated 0x550C Total time for flashing process(boot+erase+write) was 4 min 15.234 s plese mx..key team ... help me.... thnxxx... |
09-14-2011, 09:17 | #2 (permalink) |
Registered User Join Date: Sep 2008 Location: HardWare+Software & Unlocking
Member: 865598 Status: Offline Sonork: 100.1609492 Thanks Meter: 465 | Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921.60 Kbps Flash ID: 00EC 227A [Samsung ] Processing file: rh125_006.200 Downloading item CODE:hw_f11_rh125_r06.200.fls, num block: 3, size: 4.10 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 1 min 3.234 s Erasing area 0x00C60000-0x00E6983E ...OK Programming completed in 1 min 2.766 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.203 s Checksum verified (0x02AD) Processing file: rh125_006.20ia Downloading item CUST:hw_f11_rh125_006.20ia.fls, num block: 1, size: 1.98 MB Erasing area 0x00210000-0x0040AC7E ...OK Programming completed in 1 min 3.562 s Checksum verified (0x69E5) Processing file: rh1250_nai06.20ia Downloading item CUST:hw_f11_rh1250_nai06.20ia.fls, num block: 1, size: 358.89 KB Erasing area 0x00EB0000-0x00F08E7E ...OK Programming completed in 10.484 s Checksum verified (0x5A49) Total time for flashing process(boot+erase+write) was 4 min 37.469 s Phone type: RH-125 SW version: V 06.20 01-12-10 RH-125 (c) Nokia Imei plain: 35595204378201-3 Product code: 0588620 Cellular system: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Imei net: 3559xxxxxxxxxxxxx Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Last edited by Naeem123e; 09-14-2011 at 09:23. |
09-14-2011, 13:14 | #4 (permalink) | |
No Life Poster Join Date: May 2010 Location: BaNgLaDeSh
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | Quote:
Check on Hardare It is hardware fault | |
09-15-2011, 17:48 | #5 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: Makum, Assam, India
Member: 1540165 Status: Offline Sonork: 100.1606502 Thanks Meter: 29 | Quote:
Try with avoidng SAFE and FAST flashing option. | |
09-16-2011, 09:23 | #6 (permalink) |
Member: 865598 Status: Offline Sonork: 100.1609492 Thanks Meter: 465 | Bro use letest setup try again Bro link Blue-Nokia.com by Obnoxy try |
09-17-2011, 07:44 | #8 (permalink) |
Member: 865598 Status: Offline Sonork: 100.1609492 Thanks Meter: 465 | Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921.60 Kbps Flash ID: 00EC 227A [Samsung ] Processing file: rh125_006.200 Downloading item CODE:hw_f11_rh125_r06.200.fls, num block: 3, size: 4.10 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 1 min 3.234 s Erasing area 0x00C60000-0x00E6983E ...OK Programming completed in 1 min 2.766 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.203 s Checksum verified (0x02AD) Processing file: rh125_006.20ia Downloading item CUST:hw_f11_rh125_006.20ia.fls, num block: 1, size: 1.98 MB Erasing area 0x00210000-0x0040AC7E ...OK Programming completed in 1 min 3.562 s Checksum verified (0x69E5) Processing file: rh1250_nai06.20ia Downloading item CUST:hw_f11_rh1250_nai06.20ia.fls, num block: 1, size: 358.89 KB Erasing area 0x00EB0000-0x00F08E7E ...OK Programming completed in 10.484 s Checksum verified (0x5A49) Total time for flashing process(boot+erase+write) was 4 min 37.469 s Phone type: RH-125 SW version: V 06.20 01-12-10 RH-125 (c) Nokia Imei plain: 35595204378201-3 Product code: 0588620 Cellular system: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Imei net: 3559xxxxxxxxxxxxx Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
