09-06-2012, 11:35 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: saudiarabia/india
Member: 185396 Status: Offline Sonork: 100.1618832 Thanks Meter: 33 | nokia 200 flashing done !!!!!!!!!!!!!!!!!!!!!! Using device: USB ROM and HTI, FW ver: 00.50, SN: 000071F5 Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Processing file: rm761__11.56.mcusw Downloading item CODE:rm761__11.56.mcusw_ebl_psi.fls, num block: 4, size: 25.25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.406 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.359 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.563 s Erasing area 0x40280000-0x41A7FFFE ...OK Programming completed in 34.765 s Checksum verified (0xC6C7) Processing file: rm761__11.56.ppm_mec Downloading item CUSTackage_mec.ppm_ebl_psi.fls, num block: 1, size: 6.36 MB Erasing area 0x41A80000-0x420DB47E ...OK Programming completed in 9.266 s Checksum verified (0xA9D8) Processing file: rm761__11.56.image_mec_059J4X4_003 Downloading item CUSTackage_mec_059J4X4.image.fls, num block: 1, size: 14.50 MB Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 21.547 s Checksum verified (0x9681) Total time for flashing process(boot+erase+write) was 3 min 13.109 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 17DE1F29 Verifying communication to device OK. Phone type: RM-761 (Nokia 200) SW version: V 11.56 26-03-12 RM-761 (c) Nokia Imei plain: 35365505697208-0 Product code: 059J4K5 Language Pack: - not available. Imei net: 35365505697208 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN thanks mxkey team !!!!!!!!!!!!!!!!!! |
The Following User Says Thank You to najegsm For This Useful Post: |
