06-06-2009, 09:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: OrbitGsm.Com
Member: 650840 Status: Offline Thanks Meter: 622 | Nokia 2680 unlocked by mx-key Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3162 [UPP8M_v6.x] u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_amd.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001DE354:3B8ADA60 Area [01000000-0101FFFF] erased in 0.672 s Area [01080000-0109FFFF] erased in 0.703 s Programming ... Programming completed. Completed in 1 min 12.063 s Reading Simlock info ... Imei net: 358965******** Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN THANKS TO MX-KEY TEAM BR, P@lash_c6 |
The Following User Says Thank You to palash_c6 For This Useful Post: |
Nokia E71x rm-462 Successfully Unlocked By MX Key. | sanjoychy | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 03-16-2010 15:42 |
NOKIA 5800 rm-428 v4.0 can be unlocked by mx-key? | gsmseeeker | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 01-31-2010 23:52 |
>>> Nokia 6120c Unlocked By MX Key <<< | zeel_zeel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 06-11-2009 13:03 |
Nokia 6500c rm-265 v 04.80 31-10-07 rm-265 unlocked by mx-key in no time:)- | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 06-10-2009 15:36 |
