Old 03-20-2011, 08:34   #1 (permalink)
rezwan_jack's Avatar
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
Nokia 2700 Classic White Screen, Camera On Stand By (ANSWERED)
Nokia 2700 Classic
Problem
1. White Screen Maximum Time
2. Hang
3. Camera On Stand By
4. Camera Some Time Works
5. Handsfree Some Time Works
6. Cant use any Aplication Soft ( nimbuzz, e-buddy ect)
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 2720010B76326850C37FBC14B9B2C4C4FE9DB7CF
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 10.6.0 revision: 0.0 size: 0x3C40
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.28.0 revision: 0.0 size: 0x23220
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F
TransmissionMode: DDR&TX2
Original Imei: 35826XXXXXXXXX
Original Product code: 0579811
Bluetooth ID: 347E3977EDA4
Phone Type: RM-561 (Nokia 2700 classic)
SW Version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35826XXXXXXXXX-X
Product Code: 0579811
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35826XXXXXXXXX
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Version Info:
MCU SW version: V 09.98 06-09-10 RM-561 (c) Nokia
HW version: 2000
RFIC version: 06540601
DSP version: ICPR72_09w26
LCD version: SEIKO
PPM version: V 09.98 06-09-10 RM-561 (c) Nokia MH
BT MCM version: 2222-302
Retu version: 16
Tahvo version: 22
Content Pack version: Content: CTV IN v2 V 09.98 06-09-10 RM-561 (c) Nokia
Bluetooth ID: 34 7E 39 77 ED A4
DVB-H receiver Bootloader version: w9 4
Product Info:
Production serial number: IAW912480
Module code: 0204245
Basic production code: 0577212
Long production SN: 0
Serial Numbers:
IMEI plain: 35826XXXXXXXXX
IMEI spare to net: 3A 85 62 02 83 46 70 02
IMEI SV to net: 33 85 62 02 83 46 70 52 F5
Other Info:
Model: Nokia 2700 classic (Classic Phone)
CS type: GSM850/GSM900/GSM1800/GSM1900
BSI: 4.4 KOhm
Counter: 0/3, 0/10
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 2.031 s
Camera Test
Self Test
Please Help Me
Thanks in Advance
Rezwan_Jack
Old 03-20-2011, 08:40   #2 (permalink)
r-jcomm's Avatar
Member: 601913
Sonork: 100.1597350
Thanks Meter: 658
possibility alvima or uem ic problem ............... try cnahge melody ic
Old 03-20-2011, 08:43   #3 (permalink)
Member: 226457
Sonork: No more used
Thanks Meter: 14,934
Remove Camera and try again.
Old 03-20-2011, 08:45   #4 (permalink)
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
Thnx for reply
Checked but same problem
Old 03-20-2011, 08:45   #5 (permalink)
zorgy_1979's Avatar
Member: 1331464
Thanks Meter: 206
Write this pm file. It is for your camera. If problem not solved, check hardware. Thinking you have hardware problem. Deposit Files
Old 03-20-2011, 08:50   #6 (permalink)
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
Checked Not Solved
same problem
Old 03-20-2011, 11:02   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
phone got strange behavior.
possible problem could be rooted on rap chip. try to reflow it properly.
Old 03-20-2011, 11:05   #8 (permalink)
r-jcomm's Avatar
Member: 601913
Sonork: 100.1597350
Thanks Meter: 658
this is hardware problem not software
Old 03-20-2011, 12:02   #9 (permalink)
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
Thumbs up Problem Solved 100000%
Thnx Bro
Problem Solved
Back Up rpl
Erase Hole Flash File
Flash With Latest Version
Write Rpl
Reset All
Done 100000000000%
Imei plain: 12345610654321-?
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Imei: 35826XXXXXXX
Restoring RF/BB DATA from backup ...
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating PRODUCTCODE (0579811)... OK
Updating PSN (IAW912480)... OK
Updating HWID (2000)... OK
Updating SIMLOCK...OK
Updating SUPERDONGLE_KEY ...OK
Updating CMLA_KEY...OK
Updating WMDRM_PD...OK
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 2.375 s
This Video Help Me 1000000000% works
The Following 2 Users Say Thank You to rezwan_jack For This Useful Post:
Old 03-28-2011, 12:16   #10 (permalink)
Member: 1494013
2700 camera problem solution
Old 03-28-2011, 12:18   #11 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
Thanks Meter: 348
what is problem?post details.
The Following User Says Thank You to net.tarik For This Useful Post:
Old 07-09-2011, 12:31   #12 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
whait screen whay
hi to all ,
this type set maximum time problem is ctn file Ur flashing tools have messages warning ......128k page sources so select right ctn file
Page generated in 0.25864 seconds with 9 queries
