06-21-2010, 16:28 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: INDIA
Member: 511749 Status: Offline Thanks Meter: 335 | Nokia 3110c security test failed problem not solve MXKEY TEAM BEST ALL TIME MANOLE PLS HELP ME NOKIA 3110C SCURITY_TEST FAILED Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35934302162102-5 Product Code: 0566963 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! I AM TRYE THE FLASH 7.30 SD REPAIR SD PM AUTH WRITE RPL PM FULL PM PROBLEM SAME HELP BR. LOKESH |
06-21-2010, 18:53 | #5 (permalink) |
Junior Member Join Date: Aug 2007
Member: 562635 Status: Offline Thanks Meter: 2 | 3110 100% repaired security test failed use same model pm.then select 1&309 field then pm auth and then write.after it reset all in factory setting.then check phone info.ur set will be 100% ok. |
07-09-2010, 11:16 | #6 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | load full pm and try to sd pm autho 1st its not done but try reapet when its done problem solv nothing false bro i am doing yet 100% solution |
07-09-2010, 12:50 | #8 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2010 Location: gsm hospital
Member: 1294693 Status: Offline Sonork: 100.1591739 Thanks Meter: 483 | 1.write full pm 2.simlock repair,tick make simlock rpl 3.sd repair 4.sd auth 5.write p,1 & 309 6.factory settings done 100% |
07-09-2010, 12:58 | #9 (permalink) |
No Life Poster Join Date: Oct 2009 Location: love me if you can
Member: 1150088 Status: Offline Sonork: ============ Thanks Meter: 254 | Cek phone tes >>> certiofikat validation cek your CCC and HWc if empty you can write rpl with rpl edit mx key IF oke ( not empty ) cek by selt test if st ear data failed or no signal is hardware ( retu ) br |
07-09-2010, 13:07 | #10 (permalink) |
No Life Poster Join Date: Feb 2010 Age: 38
Member: 1225453 Status: Offline Thanks Meter: 501 | Just tick PM Auth -after server accept PM -load full PM File 3110c or Modified Pm,just check 1 and 309 section -write file -Scan -problem solve 100% br.dj alfskie on the mix |
07-09-2010, 13:46 | #11 (permalink) |
No Life Poster Join Date: May 2005 Age: 43
Member: 149032 Status: Offline Thanks Meter: 3,808 | backup ur rpl must.then start ur job i am slove many phone this problem 1st rpl backup 2nd erressss 3rd flash 7.21 4th make superdongal 5th sx4 pm 6th simlock 7 factory settings some time need hwc data rpl alll r ok ur phone backup must 1st then start ur job its 10000000000000000% tested |
The Following User Says Thank You to gopalhot For This Useful Post: |
