05-07-2011, 08:56 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Balochistan
Member: 952072 Status: Offline Sonork: 100.159775 Thanks Meter: 107 | Nokia 3110c set Restart in 10sec (ANSWERED) Reading Important data ... Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35685202867949_BA CK.rpl).CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]EM0 ID: 00000232EM1 ID: 00000353PUBLIC ID: 0930010BC19D7D56B282748CE6394908582732F1ASIC MODE ID: 00ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1ROM ID: 191EC665DFAAF68FSecondaryBoot: rap3gv3_2nd.fg [BB5] version: 10.42.0 revision: 0.0 size: 0x3C40 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0020 881C - 0000 6A21 [ST M58LR256JU,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16BitAlgorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.40.0 revision: 0.0 size: 0x23550 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668DTransmissi onMode: DDR&TX2 Processing MCU file: rm237__07.30.mcusw [BB5,BB5 ALGORITHM] size: 14.49 MBSupported Ids: 0103192101001101, 010C192101001101 Storing certificate [NPC, VARIANT, R&D] ...OK Erase size: 16.37 MBCMT NOR area [00000000-000006BF]CMT NOR area [000006C0-0001FFFF]CMT NOR area [00020000-0007FFFF]CMT NOR area [00080000-000DFFFF]CMT NOR area [00100000-001FFFFF]CMT NOR area [00200000-0031FFFF]CMT NOR area [00320000-0105FFFF]CMT NOR area [01060000-01067FFF]CMT NOR area [01068000-0107FFFF]erased in 57.125 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT PMM_CONF block sent CMT SBIF_CONF block sent Programming completed in 2 min 49.156 s Processing PPM file: rm237__07.30.ppm_b [BB5,BB5 ALGORITHM] size: 3.20 MBSupported Ids: 0103192101001101, 010C192101001101 Erase size: 4.62 MBCMT NOR area [01080000-0151FFFF]erased in 13.812 s Flash programming ... Programming completed in 36.688 s Processing CNT file: rm237__07.30.image_ora_pl [BB5,BB5 ALGORITHM] page size: 64 K size: 4.13 MBSupported Ids: 0103192101001101, 010C192101001101 Erase size: 10.75 MBCMT NOR area [01520000-01FDFFFF]erased in 47.843 s Flash programming ... Programming completed in 47.390 s Total time for flashing process(boot+erase+write) was 6 min 27.500 s Phone Type: RM-237 (Nokia 3110c)SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35685202867949-0Product Code: 0514950Battery voltage: 4706 mV, current: 59 mA Language Pack:- not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356852028679490 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN set is bilink i check hardwere and also erase full flash but problem is same |
05-07-2011, 08:58 | #2 (permalink) |
Member: 952072 Status: Offline Sonork: 100.159775 Thanks Meter: 107 | CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0930010BC19D7D56B282748CE6394908582732F1 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 10.42.0 revision: 0.0 size: 0x3C40 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0020 881C - 0000 6A21 [ST M58LR256JU,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.40.0 revision: 0.0 size: 0x23550 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Begin Certificate Request ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.7 Updating PRODUCTCODE (0514950)... OK Updating CMLA_KEY...OK Updating WMDRM_PD...OK CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0930010BC19D7D56B282748CE6394908582732F1 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 10.42.0 revision: 0.0 size: 0x3C40 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0020 881C - 0000 6A21 [ST M58LR256JU,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.40.0 revision: 0.0 size: 0x23550 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK |
05-07-2011, 12:07 | #7 (permalink) |
Freak Poster Join Date: Jan 2010 Location: india
Member: 1210415 Status: Offline Thanks Meter: 27 | 1- full BB5 modified PM 2- SX4 Server * click load file and chouse your modifid PM then make this step: uncheck the resource 42,62 entries * check your SX4 server * then click : write selected then all problem solved tested by me many time 3110c tested 7210c tested all ok check by me 100% solution nasir |
