Member: 1537172
Thanks Meter: 65 | Nothing yet Ok friends, made all suggests, phone is in the same state... here goes some logs....
BUS CHECK Quote:
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C081XXXX
Using device: HTI, FW ver: 00.50, SN: 0000XXXX
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0C300205DC7A545042A04DBD486AC73D9960F495
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: B778DFBE4C5F277CE2DE8A38AF46E5D6803E4A79
TransmissionMode: DDR&TX2
Original Imei: 35310202675077
Original Product code: 0561598
Bluetooth ID: 0021AAF76D75
SIMLOCK PA identifier:
[0] PA_SL2
| Here mobileex tells me, phone not responding, reset manually, bla bla bla....(In status bar of program i can see many times... Phone entering Charging mode(this one too many times....))
Repair user files: Quote:
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Not Supported, reason: this is not RAP3NAND phone !
| Fix BB5 Downgrade Quote:
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Reading CMT NPC (0x168 bytes).
NPC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35310202675077_NP C.rpl"
Erasing CMT NPC ... OK
Prog.status for Asic CMT ...
Applying BB5 SW Downgrade patch ...
ERROR: Phone not responding !
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Updating CMT NPC ...OK
NOR: OK
| Here comes again error ERROR: Phone not responding !, please reset manually bla bla bla.... Flash by FBUS Quote:
Processing MCU file: rm364__07.16.mcusw
[BB5,XSR 1.5] size: 20.59 MB
Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Algorithm: RAP3Gv3_algo_xsr15.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x26CB8
Erase size: 21.87 MB
CMT FLASH,NOR area [00000000-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [01480000-015FFFFF]
CMT FLASH,NOR area [00140000-0147FFFF]
erased in 19.438 s
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: B778DFBE [RAP Certificate 114 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 20.657 s
Processing PPM file: rm364__07.16.ppm_c
[BB5,XSR 1.5] size: 6.07 MB
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 6.75 MB
CMT FLASH,NOR area [01600000-01CBFFFF]
erased in 20.422 s
NOR: OK
NOR: OK
Programming completed in 26.203 s
Processing CNT file: rm364__07.16_ISM_007.image_movi_es_graph
[BB5,BB5 ALGORITHM] page size: 128 K size: 12.13 MB
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 34.87 MB
CMT FLASH,NOR area [01FC0000-03F9FFFF]
CMT FLASH,NOR area [01CC0000-01FBFFFF]
erased in 1 min 11.391 s
NOR: OK
NOR: OK
Programming completed in 50.078 s
Total time for flashing process(boot+erase+write) was 5 min 29.968 s | Flash ENO File Quote:
Processing MCU file: rm364_at07.10_eno_v0.0630.mcusw
[BB5,XSR 1.5] size: 3.47 MB
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
CMT PAPUBKEYS is blank/erased.
erased in 5.032 s
NOR: OK
CMT NOLO block sent
CMT KEYS block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT DSP0 block sent
NOR: OK
Programming completed in 15.516 s
Total time for flashing process(boot+erase+write) was 28.797 s
| After flash ENO, i flashed with latest firm, 12.35, and still same problem
After one more nigth fighting with this handset, im in same situation...im desperate.......please some advice? |
