03-19-2010, 13:08 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Irvinestown
Member: 719399 Status: Offline Thanks Meter: 228 | Nokia 5000 detecting issue Does anybody know which cable to use to detect the Nokia 5000? I used 2630 which looks the same as 5000 cable but phone doesn't respond. Also used Easy New with no positive result. Can anyone help me? |
03-19-2010, 13:53 | #8 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | - most non-branded fbus cable has bad quality. check for battery pin connector. - using easy cable: if phone is alive: turn it on, press SCAN, insert easy cable. if phone is dead: insert cable, press BUSCHECK, insert battery. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
03-19-2010, 13:59 | #9 (permalink) | |
Member: 719399 Status: Offline Thanks Meter: 228 | Quote:
Seems that phone is dead Using device: J.A.F, FW ver: 01.B4 Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00852385A3BDA66 ASIC type: 11 UEM Imei: 35679702569440 Flash Imei: 35679702569440 MasterCode: 6374724412 RPL saved to "C:\mobileEx\3.3\data\backup\35679702569440_BACK.r pl" Phone not responding ! | |
03-19-2010, 14:09 | #10 (permalink) |
Member: 719399 Status: Offline Thanks Meter: 228 | Now trying to use Nokia Usb Foxconn protocol activated. Phone should Powered ON in any operation. Always "Scan Phone" before any operation. For dead phone use "Emergency Mode". Pooling phone ... Unable to detect bootloader, please retry ... Pooling phone ... Unable to detect bootloader, please retry ... Phone doesn't charge too. |
03-19-2010, 23:23 | #12 (permalink) |
Member: 719399 Status: Offline Thanks Meter: 228 | I'm stuborn. Still fighting with nokia 5000, Cant detect in Jaf interface. Phone is dead, also tried ccs mode but cant detect neither. Please help me with that |
03-20-2010, 03:56 | #13 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, CCS suite is work only for ODM foxconn phone. Use easy cable as your posted above for flashing. Untick "Safe Flash" BR |
03-20-2010, 11:01 | #14 (permalink) | |
Library version: 1.0.0.7920(18-03-2010), 1.0.0.12662(19-03-2010) Boot error: 00 CC CC CC TX line remains low ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone | |
03-20-2010, 12:50 | #15 (permalink) | |
Now I'm getting this: Using device: J.A.F, FW ver: 01.B4 Library version: 1.0.0.7920(18-03-2010), 1.0.0.12662(19-03-2010) Boot error: 00 CC CC CC TX line remains low ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. May that have sth to the battery?? | |
Flash files Nokia 5000 and Nokia 8800 sirrocco? | patronna | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 04-07-2009 17:26 |
01 July 2008 Unlock added for Nokia 5000 ( First in the World ) | NFF Box Team | Service Products News & Updates | 0 | 07-01-2008 10:48 |
