06-29-2012, 22:24 | #1 (permalink) |
Freak Poster Join Date: Sep 2010 Location: VeneZueLa
Member: 1391333 Status: Offline Sonork: 100.1646233 Thanks Meter: 19 | Nokia 5800d RM-428 in SECURITY_TEST is FAILED! This time I have a Nokia 5800d RM-428 with the problem of SECURITY_TEST is FAILED! I present here the log of "Read info"..... Code: Phone type: RM-428 (Nokia 5800 XpressMusic) SW version: V ICPR72_08w47 24-11-08 RM-428 (c) Nokia Imei plain: 3xxxxxxxxxxxxx Product code: 0577218 Battery voltage: 4677 mV, current: 134 mA Language Pack: - not available. SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359348020124020 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN I've also tried to do by the SX4 server but I think you are off ....... I recommend doing ... thanks |
06-30-2012, 04:58 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: ..::INDIA::.. Andhra Pradesh Age: 41
Member: 1528548 Status: Offline Sonork: 100.1613286(Offline) Thanks Meter: 2,243 | Security Test Failed can be solve easily if follow some steps: Solution 1. Click Repair SD & Load PM from local RFBB when ask will solve. (If PM from local RFBB match) Solution 2. Load any full saved PM, tick section area 1,309 & click write will solve, if not load another one. (Make habit of saving full PM of working phones) Solution 3. Note: Only follow this step when something went wrong in phone & can't be solve by Repair SD from above Solutions. 1. first backup full RPL ( go > Imei and Security tab > Imei Rebuild > backup RPL) 2. erase old PM ( go to PM tab > click Erase ) 3. Reset npc data ( go to IMEI and Security tab> reset NPC data)( must backup RPL before do this) 4. Erase pm again (go to PM tab > Erase ) 5.Write RPL from backup ( go to IMEI and Security tab > IMEI Rebuild > restore IMEI) 6. go PM tab > Super SD Auth & Repair SD > than write good or modified pm ( must need pm 1 & 309) 7. erase PM again. 8. Recover CERT ( go to IMEI and Security tab> IMEI Rebuild > Recover Certificate) 9. apply full Factory Reset. this log copy from Juber chowdary post try this 100% solve problem |
