12-21-2012, 08:20 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Sweden
Member: 503620 Status: Offline Sonork: 1621694 Thanks Meter: 46 | nokia 603 turn on nokia logo still then off i flashed latest version but problem stil |
12-21-2012, 09:45 | #4 (permalink) | |
Member: 503620 Status: Offline Sonork: 1621694 Thanks Meter: 46 | Quote:
MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: C087376D Using device: USB ROM and HTI, FW ver: 00.50, SN: 010080CE Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.81 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001040 CMT EM1 ID: 00001060 CMT PUBLIC ID: 4C460000FFFB3C4011EE150B840BCE32D682818E CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0060 - 0000 0032 [Samsung LH28F800BG] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 10A0A0C2 FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: BC8F5330DDAE68D572ADF62FA254EB9EA2EEF364 Selected firmware certificate matched. Original Imei: 35864704319868 Original Product code: 059K2S8 Bluetooth ID: 6CE90762F5FE SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x1D8 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 603 USB Phonet, PORT_ID: 33CCE77D Verifying communication to device OK. Phone type: RM-779 (Nokia 603) SW version: V 79u_sr2_12w20.8 20-08-12 RM-779 (c) Nokia ApeCoreSw: 113.010.1506 Imei plain: 35864704319868-4 Product code: 059M074 Battery voltage: 3684 mV, current: 215 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358647043198684 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN self test Phone Type: RM-779 SW version: V 79u_sr2_12w20.8 20-08-12 RM-779 (c) Nokia ID Test name Startup Result 15 SLEEP_X_LOOP Y PASSED(00) 46 UEM_CBUS_IF N PASSED(00) 3 EAR_DATA_LOOP N PASSED(00) 12 SIM_CLK_LOOP Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N PASSED(00) 90 PWR_KEY N PASSED(00) 2 CURRENT_CONS N PASSED(00) 20 BACKUP_BATT N PASSED(00) 96 HOOKINT N PASSED(00) 101 BTEMP N PASSED(00) 8 MBUS_RX_TX_LOOP Y PASSED(00) 23 KELVIN_BATVOLTAGE N PASSED(00) 19 KELVIN_VIBRA N PASSED(00) 26 KELVIN_CAPACITOR N PASSED(00) 29 KELVIN_MISC N PASSED(00) 31 KELVIN_CHARGING N PASSED(00) 27 KELVIN_AUDIO N PASSED(00) 116 KELVIN_XEAR N PASSED(00) 34 USB_CHARGING N PASSED(00) 117 DIGIMIC N PASSED(00) 209 HEADSET_AMPLIFIER N PASSED(00) 222 LED_CONTROLLER N PASSED(00) 233 AUDIO_PLL N PASSED(00) 239 RAM_IF N PASSED(00) 128 CDSP_SLEEPCLOCK_FREQ N PASSED(00) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 124 CDSP_STROBE N !NOT EXECUTED(03) 125 CDSP_DIGI_RXTX_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 127 CDSP_PA_ID_PIN N !NOT EXECUTED(03) 75 CDSP_WCDMA_TX_POWER N !NOT EXECUTED(03) | |
12-21-2012, 10:03 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, Try Quick Fix: Go to Service Tab > Quick Fix Tab > Tick RAP3 NAND Erase & Click Do Selected Job, If not solve, then check LCD Connector, Clean PCB for Waterloggs, Buscheck & Selftest Logs seems to be OK. BR, ZUBER |
12-21-2012, 10:17 | #6 (permalink) | |
Battery voltage: 3688 mV Warning battery voltage is less, phone might not detected after flash ! Waiting for USB device removal ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001040 CMT EM1 ID: 00001060 CMT PUBLIC ID: 4C460000FFFB3C4011EE150B840BCE32D682818E CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 400C192103042108, 0003192103042108, 4003192103042108 eBB5ProtocolType: NEW NewProtocol is not supported for current interface (). Please select correct loader version from 'Config' menu ! | |
