04-05-2012, 10:13 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: FENI,BANGLADESH Age: 38
Member: 537829 Status: Offline Thanks Meter: 96 | nokia 6303 rm-443 nokia then white lcd. button press sound is ok. also show battery low on start & charger not supported with charger. i have flashed with higher version. here is log;- MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085F7C0 Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000C540 Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.73 Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012) Processing MCU file: rm443__10.12.mcusw [BB5,BB5 ALGORITHM] size: 24.67 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 9EF9DDC CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 28200109B2348E56ACDDE9E0864A78B8B17CB1B8 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x69180 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x77780 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2162F4C9 Verifying communication to device OK. Erase size: 28.25 MB CMT FLASH,NOR area [00000000-0001FFFF] erased in 0.781 s CMT FLASH,NOR area [00040000-0005FFFF] erased in 0.656 s CMT FLASH,NOR area [00060000-0007FFFF] erased in 0.688 s CMT FLASH,NOR area [00080000-0015FFFF] erased in 4.906 s CMT FLASH,NOR area [00160000-0023FFFF] erased in 4.282 s CMT FLASH,NOR area [01740000-0191FFFF] erased in 10.218 s CMT FLASH,NOR area [00240000-0173FFFF] erased in 1 min 54.406 s CMT FLASH,NOR area [022E0000-0261FFFF] erased in 17.828 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: E8E6E2AB [RAP Certificate 140 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT ISA+DYNSW block sent Programming completed in 1 min 44.031 s Processing PPM file: rm443__10.12.ppm_i [BB5,BB5 ALGORITHM] size: 6.70 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 9.75 MB CMT FLASH,NOR area [01920000-022DFFFF] erased in 52.062 s Flash programming ... Programming completed in 29.422 s Processing CNT file: rm443__10.12.image_i_ru_steel [BB5,BB5 ALGORITHM] page size: 128 K size: 10.26 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 25.62 MB CMT FLASH,NOR area [02620000-029BFFFF] erased in 25.468 s CMT FLASH,NOR area [029C0000-03FBFFFF] erased in 2 min 43.234 s Flash programming ... Programming completed in 44.359 s Total time for flashing process(boot+erase+write) was 10 min 17.250 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 6303 classic USB Phonet, PORT_ID: 2FD1B321 Verifying communication to device OK. Phone type: RM-443 (Nokia 6303 classic) SW version: V 10.12 08-04-10 RM-443 (c) Nokia Imei plain: 35150504746949-2 Product code: 0569495 Battery voltage: 3808 mV, current: 73 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 351505047469492 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN self test log:- Phone Type: RM-443 SW version: V 10.12 08-04-10 RM-443 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 43 LCD N passed 21 LPRF_IF N !no signal 44 LPRF_AUDIO_LINES N !no signal 2 CURRENT_CONS N passed 42 RADIO Y !no signal 69 BACKLIGHT Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 71 BT_WAKEUP N !no signal 96 HOOKINT N passed 88 TAHVOINT Y passed 101 BTEMP N passed 32 AMB_LIGHT_SENSOR N !no signal 119 IIC N passed 222 LED_CONTROLLER N passed 56 CDSP_SLEEPCLK_FREQ N passed 128 CDSP_SLEEPCLOCK_FREQ N passed 86 CDSP_RF_BB_IF N !no signal 77 CDSP_GSM_TX_POWER N !no signal 83 CDSP_RF_SUPPLY N !no signal 80 CDSP_TX_PLL_PHASE_LOCK N !no signal 82 CDSP_PWR_DETECTOR_BIAS N !no signal 81 CDSP_RX_IQ N !no signal need eargent solution......... |
04-05-2012, 11:02 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. your problem is AVILMA & BETTY IC'S. 1st change BETTY & if not works than AVILMA. see this image, have a good day. |
