02-12-2010, 07:42 | #1 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 424066 Status: Offline Thanks Meter: 43 | Nokia 6630 unlock ok but contact retailer SW Version: V 3.0436v32 04-01-05 RM-1 (c) NOKIA. Imei plain: 35567700982521-3 Product Code: 0529311 ApeCoreSw: V 3.45.113 04-01-05 RM-1 (c) NOKIA. ApeVariant: V 3.45.113-Euro1 04-01-05 RM-1 (c) NOKIA. Language Pack: SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 355677009825213 Version: SIMLOCK SERVER VERSION 53 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED {then} Tick "make simlock rpl" and "repair simlock" Press "update Sp lock"- -Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 3.0436v32 04-01-05 RM-1 (c) NOKIA. ApeCoreSw: V 3.45.113 04-01-05 RM-1 (c) NOKIA. SYSTEM ASIC ID: 000000010000022600010006000C192101002100 [RAP3G ver: PA 2.0] ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FAC901AEE Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SIMLOCK using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 10.188 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-1_355677009825213_SIM.RPL" Updating SIMLOCK...OK {again scan} Reading Simlock info ... Imei net: 355677009825213Phone Type: RM-1 (Nokia 6630) SW Version: V 3.0436v32 04-01-05 RM-1 (c) NOKIA. Imei plain: 35567700982521-3 Product Code: 0529311 ApeCoreSw: V 3.45.113 04-01-05 RM-1 (c) NOKIA. ApeVariant: V 3.45.113-Euro1 04-01-05 RM-1 (c) NOKIA. Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355677009825213 Version: SIMLOCK SERVER VERSION 53 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=73C8FC Version: SIMLOCK SERVER VERSION 53 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=000000 BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=000000 BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=000000 BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=000000 BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=000000 {then repair SD} Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 3.0436v32 04-01-05 RM-1 (c) NOKIA. SYSTEM ASIC ID: 000000010000022600010006000C192101002100 [RAP3G ver: PA 2.0] ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FAC901AEE Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 10.406 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-1_355677009825213_SD.RPL" Updating SUPERDONGLE_KEY ...OK {THEN LOAD PM FILE THEN CLIC SUPER SD AUTH THEN CLICK WRITE PM BUTTON} Product: V 3.0436v32 04-01-05 RM-1 (c) NOKIA. ApeCoreSw: V 3.45.113 04-01-05 RM-1 (c) NOKIA. SYSTEM ASIC ID: 000000010000022600010006000C192101002100 [RAP3G ver: PA 2.0] ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FAC901AEE Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 86 bytes written. - Key: 4, size 110 bytes written. - Key: 5, size 4 bytes written. - Key: 6, size 86 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 86 bytes written. - Key: 15, size 4 bytes written. - Key: 16, size 86 bytes written. - Key: 18, size 86 bytes written. - Key: 20, size 86 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 16 bytes written. - Key: 29, size 6 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. Completed in 3.218 s {SCAN} Phone Type: RM-1 (Nokia 6630) SW Version: V 3.0436v32 04-01-05 RM-1 (c) NOKIA. Imei plain: 35567700982521-3 Product Code: 0529311 ApeCoreSw: V 3.45.113 04-01-05 RM-1 (c) NOKIA. ApeVariant: V 3.45.113-Euro1 04-01-05 RM-1 (c) NOKIA. Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355677009825213 Version: SIMLOCK SERVER VERSION 53 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=73C8FC hello sir but not solve in my problem { SECURITY_TEST failed!} how to fix this problem sir thanks |
02-16-2010, 06:54 | #2 (permalink) | |
Registered User Join Date: Feb 2008
Member: 703967 Status: Offline Thanks Meter: 53 | i have same problem..... here it is: Quote:
02-16-2010, 07:07 | #5 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Bangladesh
Member: 303373 Status: Offline Sonork: 100.1584377 Thanks Meter: 1,241 | Quote:
N95-8g : log ok but contact retailer ??!! | aao1308 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-11-2010 11:59 |
k1s unlock ok but contact service provider | .::Indrojith::. | Smart-Clip | 1 | 06-04-2009 10:42 |
nokia 6630 network ok but no outgoing n incoming...... | saurabh_bhola | Nokia Hardware & Hardware Repair | 3 | 11-18-2008 20:45 |
