01-03-2010, 15:51 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | NOKIA 6700c NOT ABLE TO CHECK BUS:) Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11472, Date: 27-11-2009 Boot error: FF 0F 72 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. READED INFO Code: Version Info: MCU SW version: V 07.60 20-05-09 RM-470 (c) Nokia HW version: 2001 RFIC version: Vapaus_5.1 ??? DSP version: ICPR81_09w19_2 LCD version: TPO PPM version: V 07.60 20-05-09 RM-470 (c) Nokia MR BT MCM version: 410B-v142 Retu version: 34 Tahvo version: 00 Content Pack version: Content: mr_in_black V 07.60 20-05-09 RM-470 (c) Nokia Product Info: Production serial number: CAN823580 Product code: 0571137 Module code: 0204199 Basic production code: 0590482 Long production SN: 0 Serial Numbers: IMEI plain: 353181037938694 IMEI spare to net: 3A 35 81 01 73 39 68 09 IMEI SV to net: 33 35 81 01 73 39 68 19 F9 Other Info: Model : Nokia 6700 classic (Connect Phone) CS type : GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA II/WCDMA VIII BSI: 5.1 KOhm Imei net: 353181037938694 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000002 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF I WANT TO FLASH IT TO LATEST VERSION 10.50. I HAVE ALSO CHECK THE LATEST PHOENIX LODERS BUT STILL NOT ABLE TO FLASH WBR sahil2000ind |
01-04-2010, 00:21 | #5 (permalink) |
No Life Poster Join Date: Oct 2005 Location: egypt
Member: 194207 Status: Offline Sonork: 100.1602647 Thanks Meter: 167 | u cant flash 6700 wih mx-key throw fbus cable or usb cable 6700 have 2 kind of prossesors one u can read full check & full info & u need loaders to read that one the other u can read half check & full info thats by using fbus cable cause its needing a modifyed cable u can try to flash the phone which have a full check (its just a try just to be sure that mx-key cant flash 6700) & post result thanks mony_valley |
The Following User Says Thank You to mony_valley For This Useful Post: |
Not able to check lifetimer on 7610 | smartfone | HWK | 0 | 03-04-2007 16:26 |
Nokia 1600 not able to UNLOCK and clear SECURITY CODE | zakiyyboss | powerflasher | 2 | 09-07-2006 19:03 |
Nokia 1600 not able to UNLOCK and clear SECURITY CODE | zakiyyboss | UFS2 + UFS3-Tornadoflasher | 2 | 08-28-2006 14:42 |
