Old 01-27-2013, 14:11   #1 (permalink)
Member: 551619
Thanks Meter: 136
X6-00 Mass Memory in Use
Nokia X6-00 16GB [RM-559]
After Format by "Format File System" Phone Shows "Mass Memory in Use"
Mass Memory was Working Correctly Before Format
but Now not Not Found in "Format File System"
I Tried to Flash but :
Flash programming ...
Error while programming [00] at 0x00000000, Result: 0000
Warning: programming MMC failed, please check if MicroSD exist !
ERROR: Packet Error(0xAA), code 0xA3000003
Total time for flashing process(boot+erase+write) was 28.210 s
How to Solve This..???
Old 01-27-2013, 14:44   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Post Full Buscheck Logs for assistance.
BR,
ZUBER
Old 01-27-2013, 14:51   #3 (permalink)
Member: 551619
Thanks Meter: 136
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 14300101BAA0005254594E50104F0DF1367D9DCB
ASIC MODE ID: 00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0058 - 0000 0121 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 9.50.0 revision: 2.0 size: 0x70C62
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: E00DA77BF32983F864BC7671FE7709A29D8E2C08
Selected firmware certificate matched.
Original Imei: 354316
Original Product code: 0598934
Bluetooth ID: 303855AA0E09
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Phone type: RM-559 (Nokia X6-00)
SW version: V ICPR72_11w16.1 28-07-11 RM-559 (c) Nokia
Imei plain: 354316
Battery voltage: 4722 mV, current: 0 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354316
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 01-28-2013, 06:50   #4 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Make all necessary Backup, means RPL, PM & Simlock,
Try to Erase Phone from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/
Flash it with Latest Firmware of you Phone Code & Restore all Backup.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 01-28-2013, 14:28   #5 (permalink)
Member: 551619
Thanks Meter: 136
Problem Solved by :
1. Heat MMC IC [Memory Chip / HDD]
2. Back All DATA [RPL, PM etc...]
3. Erase Phone with Erase File
4. Full Flash Phone with MMC File
5. Restore IMEI and Other DATA
Old 01-28-2013, 14:58   #6 (permalink)
Member: 1435528
Sonork: 100.1603713
Thanks Meter: 217
Dear brother flash your phone with EMMC file your 100000% problem is soulved
Old 01-28-2013, 17:03   #7 (permalink)
Member: 551619
Thanks Meter: 136
X6-00 Security Test Failed
Facing New Problem with Same Set
By Mistake I Erase Phone with Wrong File
After Full Flash & Restore IMEI Phone Shows "Security Test Failed"
Bus Check :
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
 [0] PA_SIMLOC30
ApeCoreSw: V 40.0.002
Imei plain: 354316
Battery voltage: 4536 mV, current: 0 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 354316
Counter: 0/3, 0/10
Write PM :
Using cached productData.
PRIVATE ID: F8922610F6FE9217A31E0F0E6E24EBBDE456B66E
Updating SUPERDONGLE_KEY ...OK
Authenticating to SUPERDONGLE ...
SUPERDONGLE authorized :)!
Now you can write RFBB/PM data to the phone.
Done.
Writing PM from Node ...
Section: 1
 - Key: 0, size 114 bytes written.
 - Key: 2, size 10 bytes written.
 - Key: 4, size 110 bytes written.
 - Key: 6, size 10 bytes written.
 - Key: 7, size 214 bytes written.
 - Key: 8, size 110 bytes written.
 - Key: 13, size 10 bytes written.
 - Key: 16, size 208 bytes written.
 - Key: 18, size 208 bytes written.
 - Key: 20, size 208 bytes written.
 - Key: 22, size 16 bytes written.
 - Key: 23, size 4 bytes written.
 - Key: 24, size 84 bytes written.
 - Key: 26, size 110 bytes written.
 - Key: 28, size 10 bytes written.
 - Key: 29, size 10 bytes written.
 - Key: 31, size 208 bytes written.
 - Key: 33, size 36 bytes written.
 - Key: 34, size 376 bytes written.
 - Key: 35, size 16 bytes written.
 - Key: 37, size 4 bytes written.
 - Key: 39, size 36 bytes written.
 - Key: 40, size 16 bytes written.
 - Key: 41, size 182 bytes written.
 - Key: 42, size 4 bytes written.
 - Key: 43, size 36 bytes written.
 - Key: 44, size 182 bytes written.
 - Key: 45, size 182 bytes written.
Section: 2
 - Key: 0, size 448 bytes written.
Section: 4
 - Key: 3, size 10 bytes written.
 - Key: 4, size 8 bytes written.
 - Key: 5, size 8 bytes written.
 - Key: 6, size 8 bytes written.
 - Key: 9, size 5 bytes written.
Section: 8
 - Key: 0, size 2 bytes written.
 - Key: 1, size 16 bytes written.
 - Key: 2, size 16 bytes written.
 - Key: 3, size 128 bytes written.
 - Key: 4, size 128 bytes written.
 - Key: 7, size 4 bytes written.
 - Key: 8, size 8 bytes written.
 - Key: 9, size 8 bytes written.
 - Key: 10, size 24 bytes written.
Section: 11
 - Key: 0, size 4 bytes written.
 - Key: 1, size 4 bytes written.
 - Key: 2, size 4 bytes written.
 - Key: 3, size 4 bytes written.
 - Key: 4, size 1062 bytes written.
Section: 12
 - Key: 0, size 102 bytes written.
Section: 26
 - Key: 0, size 16 bytes written.
 - Key: 1, size 68 bytes written.
Section: 31
Section: 44
 - Key: 0, size 1 byte written.
Section: 50
Section: 54
 - Key: 2, size 24 bytes written.
Section: 88
 - Key: 0, size 36 bytes written.
Section: 96
 - Key: 1, size 20 bytes written.
Section: 107
 - Key: 0, size 21 bytes written.
 - Key: 1, size 79 bytes written.
 - Key: 2, size 79 bytes written.
 - Key: 3, size 70 bytes written.
 - Key: 25, size 132 bytes written.
 - Key: 26, size 12 bytes written.
Section: 117
 - Key: 1, size 3 bytes written.
 - Key: 2, size 6 bytes written.
 - Key: 3, size 1 byte written.
 - Key: 4, size 9 bytes written.
 - Key: 5, size 10 bytes written.
 - Key: 8, size 42 bytes written.
 - Key: 13, size 3 bytes written.
 - Key: 14, size 3 bytes written.
 - Key: 16, size 40 bytes written.
Section: 120
 - Key: 0, size 944 bytes written.
 - Key: 1, size 160 bytes written.
 - Key: 2, size 130 bytes written.
 - Key: 3, size 112 bytes written.
Section: 122
Section: 193
 - Key: 2, size 8 bytes written.
 - Key: 3, size 32 bytes written.
 - Key: 4, size 32 bytes written.
 - Key: 9, size 64 bytes written.
Section: 208
Section: 217
 - Key: 0, size 32 bytes written.
- 239 skipped
Section: 291
 - Key: 0, size 92 bytes written.
Section: 308
Warning: failed to write 308 - 0 (1 bytes)
Warning: failed to write 308 - 1 (8192 bytes)
Warning: failed to write 308 - 3 (1 bytes)
Warning: failed to write 308 - 4 (1 bytes)
Warning: failed to write 308 - 6 (1 bytes)
Warning: failed to write 308 - 7 (1 bytes)
Warning: failed to write 308 - 9 (40 bytes)
Section: 309
 - Key: 1, size 2 bytes written.
 - Key: 2, size 12 bytes written.
 - Key: 4, size 12 bytes written.
 - Key: 5, size 12 bytes written.
 - Key: 7, size 12 bytes written.
 - Key: 8, size 12 bytes written.
 - Key: 17, size 12 bytes written.
Section: 313
 - Key: 0, size 173 bytes written.
Section: 322
Section: 329
 - Key: 0, size 8392 bytes written.
Section: 334
Section: 341
 - Key: 4, size 4518 bytes written.
Section: 354
 - Key: 0, size 15 bytes written.
Section: 356
 - Key: 1, size 8 bytes written.
Completed in 21.000 s
Please Help Me to Solve This...
Old 01-28-2013, 19:42   #8 (permalink)
Member: 551619
Thanks Meter: 136
Tried This but Same :
http://forum.gsmhosting.com/vbb/f550...wered-1444890/
Old 01-28-2013, 19:43   #9 (permalink)
Member: 551619
Thanks Meter: 136
Section: 308
Old 01-28-2013, 21:18   #10 (permalink)
Member: 551619
Thanks Meter: 136
Flash Log [After Full Erase] :
Processing MCU file: RM-559_40.0.002_prd.core.C00
[BB5,XSR 1.6] size: 112.91 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Storage2: FFFF FFFF - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Algorithm: RAPIDOv11_XSR17_alg.fg [XSR 1.6] version: 9.50.0 revision: 2.0 size: 0x78C48
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 182.94 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-0B71FFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: OK
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: E00DA77B [RAP Certificate 191 v.1] sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
NAND: OK
Programming completed in 5 min 6.837 s
Processing PPM file: RM-559_40.0.002_prd.rofs2.V21
[BB5,XSR 1.6] size: 12.14 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 41.87 MB
CMT FLASH,MuxOneNAND area [07920000-0A2FFFFF]
NAND: OK
CMT SOS+ROFS2 block sent
NAND: OK
Programming completed in 34.086 s
Processing PPM file: RM-559_40.0.002.312.02_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 5.30 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 20.12 MB
CMT FLASH,MuxOneNAND area [0A300000-0B71FFFF]
NAND: OK
CMT SOS+ROFS3 block sent
NAND: OK
Programming completed in 17.831 s
Processing CNT file: RM-559_32.0.002_001_000_U001.uda.fpsx
[BB5,XSR 1.6] size: 7.81 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 312.37 MB
CMT FLASH,MuxOneNAND area [0B720000-1EF7FFFF]
NAND: OK
NAND: OK
Programming completed in 24.944 s
Total time for flashing process(boot+erase+write) was 6 min 51.919 s
Old 01-28-2013, 21:19   #11 (permalink)
Member: 551619
Thanks Meter: 136
Scan :
Imei plain: 12345610654321-?
Battery voltage: 4640 mV, current: 0 mA
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
Old 01-28-2013, 21:28   #12 (permalink)
Member: 551619
Thanks Meter: 136
Write PM without IMEI [but Same] :
Done.
Section: 1
Section: 2
Section: 4
Section: 8
Section: 11
Section: 12
Section: 26
Section: 31
Section: 44
Section: 50
Section: 54
Section: 88
Section: 96
Section: 107
Section: 117
Section: 120
Section: 122
Section: 193
Section: 208
Section: 217
- 239 skipped
Section: 291
Section: 308
Section: 309
Section: 313
Section: 322
Section: 329
Section: 334
Section: 341
Section: 354
Section: 356
Completed in 22.120 s
Old 01-28-2013, 21:49   #13 (permalink)
Member: 551619
Thanks Meter: 136
Restore IMEI :
Imei plain: 354316
Battery voltage: 4646 mV, current: 0 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 354316
Counter: 0/3, 0/10
Please Help....
Old 01-29-2013, 12:20   #14 (permalink)
Member: 551619
Thanks Meter: 136
Thumbs up Problem Solved
Finally Problem Solved [but by Other Box ]
Imei plain: 354316
Battery voltage: 4618 mV, current: 0 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 354316
Counter: 0/3, 0/10
Please MxTeam do Something about this so We don't Need to Use Other Box for Problem Like This...
Old 01-30-2013, 08:43   #15 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Imei plain: 354316
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 354316
Counter: 0/3, 0/10
Bro.
You not followed this Steps: http://forum.gsmhosting.com/vbb/f550...9/#post9143748 & my suggestion,
You went for Hardware, Erased with wrong File,
Then Flashed MMC File which was not needed for the same,
Then problem started creating,
So you not got resolve with Mxkey,
BTW am Happy, you Resolved it.
BR,
ZUBER
Page generated in 0.36414 seconds with 8 queries
