11-12-2011, 16:16 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: pakistan hafizabad
Member: 700741 Status: Offline Sonork: 100.1617188 Thanks Meter: 409 | nokia c 7 flash done with mxbox new version (INFO) Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.70 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Processing MCU file: RM-675_024.001_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 123.05 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 6D16A0E CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 26A001186EA20344702663B812F1B0777228687D CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0068 - 0000 0131 [Samsung LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 6D16A0E FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x178 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35375504621071_CE RT.rpl" CMT PAPUBKEYS HASH: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 489.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF] CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 95A68E9F [RAP Certificate v1 263] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 21.969 s Processing PPM file: RM-675_024.001_14.01_MEA_C_79.92_prd.rofs2.fpsx [BB5,XSR 1.6] size: 38.54 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 59.25 MB CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 6.484 s Processing PPM file: RM-675_024.001_C15.01_MEA_1_UAE_79.92_prd.rofs3.fpsx [BB5,XSR 1.6] size: 7.30 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 15 MB CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.109 s Processing CNT file: rm675_ENO_v_0.0491_APEONLY.fpsx [BB5,XSR 1.6] size: 4.34 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.813 s Processing CNT file: RM-675_024.001_U06.01_79.92.uda.fpsx [BB5,XSR 1.6] size: 152.74 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 503.50 MB CMT FLASH,MuxOneNAND area [0E980000-2E0FFFFF] Flash programming ... Programming completed in 29.594 s Total time for flashing process(boot+erase+write) was 1 min 24.218 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia C7-00 USB Phonet, PORT_ID: 19FC56D6 Verifying communication to device OK. Phone type: RM-675 (Nokia C7-00) SW version: V 92_11w29 20-07-11 RM-675 (c) Nokia Imei plain: 35375504621071-4 Product code: 059D046 Battery voltage: 4030 mV, current: 206 mA ApeCoreSw: 024.001 Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! FULL FACTORY... OK USER DATA... Failed! (0000) Completed in 0.890 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... Failed! Completed in 1.406 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... Failed! Completed in 1.656 s |
11-13-2011, 06:59 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | good job friend. thank you for sharing. there is place for success story http://forum.gsmhosting.com/vbb/f550...mxbox-1253878/ |
