Old 07-05-2012, 22:26   #1 (permalink)
Crazy Poster
Member: 1775616
nokia c1-01 Contacr service
Hi,
I can resolve the problem "Contact Service" for a Nokia c1-01 whith HTI Plus ?
Old 07-06-2012, 00:24   #2 (permalink)
Member: 1406357
Sonork: 100.1654421
Thanks Meter: 45
Write full flash,And next time POST LOG
The Following User Says Thank You to kiki49 For This Useful Post:
Old 07-06-2012, 02:53   #3 (permalink)
Mirtelecom's Avatar
Member: 1754881
Sonork: 100.1644926
Thanks Meter: 146
Yes dear you should give us log then it is easy to reactfy the problem
Old 07-06-2012, 11:38   #4 (permalink)
Crazy Poster
Member: 1775616
I connect the nokia c1-01 via USB and it is not recognized.
I don't have the FBUS cable.
I am forced to use FBUS cable ?
thanks.
Old 07-06-2012, 11:44   #5 (permalink)
.::Gsm_Srilanka::.'s Avatar
Member: 1133072
Thanks Meter: 505
thanks.
bro c1-01 not supported f-bus oparation,
try clean and change usb connector and try phone detect by usb.
and show hardware id missing... it not problem.
B,R-chamisrilanka
The Following User Says Thank You to .::Gsm_Srilanka::. For This Useful Post:
Old 07-07-2012, 15:47   #6 (permalink)
Crazy Poster
Member: 1775616
Hi,
this is the message :
Waiting for USB ROM device ...
Device connected: nmwcdnsucx64\Nokia USB Flashing Generic, PORT_ID: 19F4845C
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Old 07-07-2012, 20:23   #7 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Hi,
Bro. Check Generation Tab, if you selected DCT4 with XGold tick.
BR,
Zuber
Old 07-15-2012, 22:04   #8 (permalink)
Crazy Poster
Member: 1775616
hi,
i flash thr nokia c1-01 with Nokia Phoenix (with the usb dead option).
And survives until the problem.
At a moment after the 100% flash the phone go to test mode and return to "Contact Service".
Help me Please !!
Thanks.
Old 07-15-2012, 23:13   #9 (permalink)
Crazy Poster
Member: 1775616
hi do a local mode and the code is :
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0******
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0******
Connection status: OHCI:HUB::USB 1.10 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012)
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.37
EBL version: Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Waiting for USB device removal ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C1-01 USB Phonet, PORT_ID: 45F652
Verifying communication to device OK.
Phone type: RM-607 (C1-01)
SW version: V 06.15a 13-01-12 RM-607 (c) Nokia
Imei plain: 35195705055400-1
Product code: 059K1D8
Detected as DCT4 phone, check Generation selection !
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NI00CS00000401022E07, ver: 001.002
SIMLOCK_DATA corrupted!
and
Version Info:
MCU SW version: V 06.15a 13-01-12 RM-607 (c) Nokia
HW version: 3000
RFIC version: 96
LCD version: TPO
PPM version: V 06.15a 13-01-12 RM-607 (c) Nokia OC
BT MCM version: 19b5-22012
Content Pack version: Content: Orange FR v3 sl V 06.15a 13-01-12 RM-607 (c) Nokia
Bluetooth ID: F4 8E 09 64 51 70
Product Info:
Production serial number: 77F6B06AH
Module code: 0204430
Basic production code: 0585582
Product specific data: 000000000000000000000000000000000000
Long production SN: 0
Serial Numbers:
IMEI plain: 351957050554001
IMEI spare to net: 3A 15 59 07 05 55 04
IMEI SV to net: 33 15 59 07 05 55 04 20 F3
Other Info:
Model: C1-01 (Entry Phone)
CS type: GSM900/GSM1800
Battery voltage: 3773 mV
Battery current: 107 mA
Old 07-16-2012, 10:48   #10 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
and
Bro. Download & Run Latest Mxkey Setup V3.5 Rev2.3, Go to Service Tab>Quick Fix>Tick XGOLD2 Fix CS/Recover SIMLOCK & Click Do Selected Job, will solve it. Have a nice day
- added: Quick Fix for XGOLD2 Fix CS/Recover SIMLOCK
(This will recover SIMLOCK table caused by Reset LOCK counter)
BR,
Zuber
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 07-16-2012, 12:11   #11 (permalink)
Crazy Poster
Member: 1775616
ok.
it's done !!!
thank you VERY MUCH !!!!!
MXKEY is the best !
Old 07-16-2012, 12:25   #12 (permalink)
Crazy Poster
Member: 1775616
hi,
the contact service problem has resolved.
And i have a simlock code by Orange france and the phone says "Impossible to remove simlock"
why ?
code to remove simlock : 954636833224154 (for c1-01 351957050554001)
thanks !!!
Old 07-16-2012, 12:39   #13 (permalink)
Member: 1324451
Sonork: 100.1666711
Thanks Meter: 15
C1-01 infenion you can't remove via code.....
brutforce by superpc and mxkey...
Old 07-16-2012, 14:50   #14 (permalink)
Crazy Poster
Member: 1775616
ok.
i'm going to send to Orange service special.
thank you !
bye.
Old 07-18-2012, 08:04   #15 (permalink)
IM8
Member: 694535
Thanks Meter: 70
can i Quick Fix for XGOLD2 Fix CS/Recover SIMLOCK ? by usb connection ? if not can someone give me the testpoint for c1-01 ?
Page generated in 0.27567 seconds with 10 queries
