Member: 929782
Sonork: 100.1641069 Thanks Meter: 617 | NOKIA C6-RM-612 successfully flash with mx-box NOKIA C6-RM-612 successfully flash with mx-box
log: Quote: Version from phone: v
Version from file: 41.0.010
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085F620
Using device: HTI, FW ver: 00.50, SN: 0000DA67
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012)
Reading RPL backup ...
Reading Phone IDs ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 089001111B3A025225F979F2E68B79045294B366
ASIC MODE ID: 00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 505A5C85580A6322C103BFE4E67B73EF478E791C
PRIVATE ID: 76E855F7064F808B71CBF708251DD12275435A07
E-FUSE: E6E6914D
SEC ROM CRC: 3E691FF8
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Flash Imei: 35150304879470
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35150304879470_BA CK.rpl"
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Processing MCU file: RM-612_41.0.010_prd.core.C00
[BB5,XSR 1.6] size: 111.93 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 207.44 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-0D39FFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: Status reported bad blocks.
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 505A5C85 [RAP Certificate v1 228] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
NAND: OK
Programming completed in 5 min 2.062 s
Processing PPM file: RM-612_41.0.010_prd.rofs2.V26
[BB5,XSR 1.6] size: 26.22 MB
Erase size: 48 MB
CMT FLASH,MuxOneNAND area [094A0000-0C49FFFF]
NAND: OK
CMT SOS+ROFS2 block sent
NAND: OK
Programming completed in 1 min 12.687 s
Processing PPM file: RM-612_41.0.010_C01_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 7.96 KB
Erase size: 15 MB
CMT FLASH,MuxOneNAND area [0C4A0000-0D39FFFF]
NAND: OK
CMT SOS+ROFS3 block sent
NAND: OK
Programming completed in 0.219 s
Processing CNT file: RM612_APE_ONLY_ENO_11w17_v0.019.01.fpsx
[BB5,XSR 1.6] size: 2.68 MB
Erase size: 4 MB
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
NAND: OK
CMT SOS*ENO block sent
NAND: OK
Programming completed in 7.609 s
Processing CNT file: RM-612_41.0.010_uda_2_001.uda.fpsx
[BB5,XSR 1.6] size: 59.08 MB
Erase size: 283.75 MB
CMT FLASH,MuxOneNAND area [0D3C0000-1EF7FFFF]
NAND: OK
NAND: OK
Programming completed in 2 min 48.094 s
Total time for flashing process(boot+erase+write) was 9 min 25.125 s
Phone type: RM-612 (Nokia C6-00)
SW version: V ICPR72_11w04.2 09-08-11 RM-612 (c) Nokia
ApeCoreSw: v 41.0.010
Imei plain: 35150304879470-3
Product code: 059D0Z8
Battery voltage: 4263 mV, current: 48 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351503048794703
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN | |
