10-23-2011, 17:25 | #1 (permalink) |
Registered User Join Date: Apr 2010 Location: madurai thirumangalam
Member: 1286002 Status: Offline Sonork: who are you Thanks Meter: 22 | nokia c7-00 flashing success for mx box team.......... Using device: HTI, FW ver: 00.24, SN: 00003BF1 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 06E00113E5A4034458232217E27B46FAC801634B ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.24.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0068 - 0000 0131 [Samsung LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.24.0 revision: 3.0 size: 0xC6B13 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Processing MCU file: RM-675_014.002_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 129.12 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 489.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF] CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 95A68E9F [RAP Certificate v1 263] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 6 min 15.218 s Processing PPM file: RM-675_014.002_04.01_Russian_79.92_prd.rofs2.fpsx [BB5,XSR 1.6] size: 39.30 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 59.25 MB CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 53.859 s Processing CNT file: RM-675_014.002_U01.01_79.92_prd.uda.fpsx [BB5,XSR 1.6] size: 86.92 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Converting UCP blocks to 128 K. Erase size: 503.50 MB CMT FLASH,MuxOneNAND area [0E980000-2E0FFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 4 min 14.813 s Total time for flashing process(boot+erase+write) was 13 min 35.453 s Phone type: RM-675 (Nokia C7-00) SW version: V 92PS1_10w46.9 01-03-11 RM-675 (c) Nokia Imei plain: 35375504215051-8 Product code: 059B7V7 Battery voltage: 4843 mV, current: 74 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353755042150518 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 6.656 s ............. by reegam team |
10-23-2011, 18:57 | #2 (permalink) |
Freak Poster Join Date: Jan 2007 Location: in gsmhosting Age: 36
Member: 426321 Status: Offline Sonork: 100.1602578 Thanks Meter: 91 | good workl but is beter the poste your loge in http://forum.gsmhosting.com/vbb/f550...-mxkey-767051/ |
