Old 04-18-2013, 07:12   #1 (permalink)
Member: 459032
Exclamation Nokia N95 8Gb Dead After Flash Erase
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C08***** Using device: HTI, FW ver: 00.50, SN: 0100**** Connection status: IUSB3XHC:IUSB3HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 3E005B486865C6E30491328A68AAE509640B79E1 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1AA000082E8000582BAB1E31FC90EF73E1753B0B ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 Storage0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,NAND, asic:APE Suggested algorithm: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248 Supported Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Selected firmware certificate matched. Original Imei: 35698301514*** Original Product code: 0558164 Bluetooth ID: 001C9AF2CEE5 WLAN ID: 001CD407DAB5 SIMLOCK PA identifier: [0] PA_SL2 No file system defined
Old 04-18-2013, 07:23   #2 (permalink)
Member: 365076
Thanks Meter: 29
now flash latest version ,insha,,, your phone alive
Old 04-18-2013, 13:41   #3 (permalink)
Member: 459032
Exclamation
see pic for detail
Imei: 35698301514741
Restoring RF/BB DATA from backup ...
Error unable to detect product !
Updating WARRANTY ...error 0x0
Updating PROD ...error 0x0
Updating BT ...error 0x0
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C087***
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
CMT PAPUBKEYS is blank/erased.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating APE NPC ...OK
Updating APE HWC ...OK
Updating APE CCC ...OK
Prog.status for Asic APE ...
NAND: Status reported bad blocks.
NAND: OK
Old 04-19-2013, 08:16   #4 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Have you Backup RPL before Erase ?
If backed-up, then Download & Flash it with Latest Firmware of your Phone Product Code,
Try Quick Fix:
Go to Quick Fix Tab > Tick BB5 Rap3NAND Erase > Click Do Selected Job, must solve it,
Post full Buscheck Logs if not solve.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 04-19-2013, 11:59   #5 (permalink)
Member: 459032
Originally Posted by .::ZUBER::. View Post
Bro.
Try Quick Fix:
BR,
ZUBER
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C087*** Using device: HTI, FW ver: 00.50, SN: 01006*** Connection status: IUSB3XHC:IUSB3HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 3E005B486865C6E30491328A68AAE509640B79E1 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1AA000082E8000582BAB1E31FC90EF73E1753B0B ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 Storage0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,NAND, asic:APE Suggested algorithm: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248 Supported Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Selected firmware certificate matched. Original Imei: 35698301514741 Original Product code: 0558164 Bluetooth ID: 001C9AF2CEE5 WLAN ID: 001CD407DAB5 SIMLOCK PA identifier: [0] PA_SL2
Old 04-20-2013, 07:01   #6 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Try to Downgrade Phone to lower Version after Erase & don't Restore Backup RPL,
Check whether Phone appears in Test Mode with Buscheck,
If appears, then Post Buscheck & Selftest Logs,
If not, then possibility of Hardware,
P.S. But what was the Phone condition before Flashing or Erasing ?
Post reply in details.
BR,
ZUBER
Old 04-20-2013, 18:58   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
1. Flash this ENO file as MCU
RM-320_ENO_engine_software_v3.0 - Download - 4shared
2. Flash normal firmware.
Old tips worth to read: CLICK HERE
The Following User Says Thank You to gbluez For This Useful Post:
Old 04-21-2013, 15:09   #8 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,336
No more upgrades and surprises Mr.Manole???? Zuber???? Gbluez???
Old 04-21-2013, 20:09   #9 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
It's coming. Rev26 is on the way.
Old 05-02-2013, 05:48   #10 (permalink)
Member: 459032
Question Thank's Alot
Sorry To Say May HTI Have Dead Some unkown reason when i buy new one
I Well Post Result
Thank All Supporter
Page generated in 0.22868 seconds with 9 queries
