Old 04-08-2012, 10:34   #1 (permalink)
Member: 976682
Thanks Meter: 5
flash N9 with mx (ANSWERED)
hi . can mx box flash N9.rm-696 with usb?
Old 04-08-2012, 11:16   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
yes, click flash & bring phone to USB mode by turn off your N9 and connect it to the PC via USB hold onoff button until the mxkey detects the boot loader and once it detected then start flashing. once the flashing is completed the first power on will take a long time so be patient, i hope you understand & have a good day.
The Following 2 Users Say Thank You to .::ZUBER::. For This Useful Post:
Old 04-08-2012, 11:31   #3 (permalink)
Member: 199814
Thanks Meter: 1,960
any one tested? flashing of n9 on mxkey? or not yet search as well
Old 04-08-2012, 11:50   #4 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
you try this above procedure & tell me is working or not brother.
Old 04-19-2012, 18:45   #5 (permalink)
Member: 759190
Thanks Meter: 4
doesnt work for me... mine has a security code that i want to remove
MXKEY [FT SCR2000 0], SN: C084B29B
Using device: USB ROM
Connection status: No device connected
Driver: NMWCD, ver: 7.1.32.72
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
Done.
Sleeping for 15 seconds while device boot up ...
Old 04-19-2012, 19:34   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Done.
We have now 3.5rev1.9. Please always use latest version.
http://forum.gsmhosting.com/vbb/f550...hread-1451811/
Follow exactly mobileex direction given on logs
When USB cable gets connected it powers the phone and set's it to flashing mode
Connect a turned off unit to USB. And when it's power up, choose 'Sync and Connect' mode.
Old 04-19-2012, 19:37   #7 (permalink)
Member: 759190
Thanks Meter: 4
i'm already using v3.5 revision 1.9 and i can't chooose 'sync and connect' because it has a security code
Old 04-19-2012, 19:46   #8 (permalink)
Member: 759190
Thanks Meter: 4
something new appears:
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012)
Remove USB cable from device.
Turn off the phone
Press and hold down key 'u'
Connect USB cable between the phone and host PC while still holding down key 'u'
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Waiting for Maemo USB device ...
Done.
The Following User Says Thank You to achidrift For This Useful Post:
Old 04-27-2013, 13:11   #9 (permalink)
Member: 345808
Thanks Meter: 21
MXKEY [USB CCID Smart Card Reader 0], SN: C0803135
Driver: NMWCD, ver: 7.1.32.84
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Waiting for USB interface ...
Found device RM-696, hardware revision 1603
NOLO version 2.3.6
Version of 'sw-release': DFL61_HARMATTAN_40.2012.21-3_PR_005
Sending ape-algo image (7096 kB)...
Waiting for USB phonet ...
Verifying communication to device ...
Server application: 1.7.2
Found product: RM-696 rev. 1603
Server implements softupd protocol version 1.8
Image SW version DFL61_HARMATTAN_40.2012.21-3_PR_005
Image moslo not present
Image tar skipped
Image config skipped
Battery level 78 %, continuing.
cert-sw ( 1 kB) written.
xloader (23 kB) written.
secondary (94 kB) written.
[f] rootfs [pending 0 % 1024 / 1170162 kB NA ]
[-] mmc [pending 0 % 0 / 0 kB NA ]
cmt-2nd (95 kB) written.
cmt-algo ( 789 kB) written.
kernel (2714 kB) written.
cmt-mcusw (6050 kB) written.
Fetching error list:
bb5_rdc_cert_read failed
mmc: sfdisk returned status 1
mmc: Could not exec 'tune2fs -L rootfs /tmp/sudmmcwJEIRs/internal0p2'
mmc: Could not remove mount directory /tmp/sudmmcwJEIRs/mnt: No such file or directory
[Pipe 4] Finishing in error state with status 1
Old 04-29-2013, 08:53   #10 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
What was Phone condition before Flashing & now after ?
Please specify, so we can assist.
BR,
ZUBER
Old 05-01-2013, 08:02   #11 (permalink)
Member: 345808
Thanks Meter: 21
this error from first it self
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.27632 seconds with 10 queries
