Member: 213681
Thanks Meter: 108 | Here is log from mx: Quote:
Version from phone: 79_sr1_11w42.5
Version from file: 111.030.0609
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C08210C0
Using device: HTI, FW ver: 00.50, SN: 0000F1EF
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012)
Reading RPL backup ...
Reading Phone IDs ...
CMT Data :
SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
EM0 ID: 00000C35
EM1 ID: 00000C30
PUBLIC ID: 1DE00002C0A403445D94D26DCA260F4928FD4617
ASIC MODE ID: 00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 3.0 size: 0xD4029
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231
PRIVATE ID: 8F01305F229EBF8EEF6DA3F50DE7D86975E5D795
E-FUSE: 2DFD5366
SEC ROM CRC: AC22615B
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000C35
EM1 ID: 00000C30
ASIC MODE ID: 00
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x178 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Flash Imei: 35268404454662
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35268404454662_BA CK.rpl"
CMT Data :
EM0 ID: 00000C35
EM1 ID: 00000C30
ASIC MODE ID: 00
Processing MCU file: RM-596_111.030.0609_79u_prd.core.fpsx
[BB5,XSR 1.6] size: 119.69 MB
Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
Partitioning ...OK
Erase size: 228.06 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: OK
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT SOS+DECOMP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent
CMT GENIO_INIT block sent
CMT SOS+IVE3A block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
ERROR: Packet Error(0xAA), code 0xA4000002
Error while programming [00] at 0x05360400, Result: 0000
Task failed at (0800001C)!!!
Last RX buffer: 02 00 00 A4
| Anny idea how to fix this problem??? |
