Old 11-27-2010, 19:35   #1 (permalink)
Member: 719399
Thanks Meter: 228
Nokia n96
Hi
I've a problem with nokia n96
Phone turns on but the screen remains blank. I flashed the phone with 3 files.
Here's the info from self test:
hone Type: RM-247
SW version: V ICPR72_09w13.3 15-09-09 RM-247 (c) Nokia
ID Test name Startup Result
46 UEM_CBUS_IF Y passed
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
90 PWR_KEY N passed
2 CURRENT_CONS N !no signal
20 BACKUP_BATT N passed
58 CMT_APE_WAKEUP N !no signal
96 HOOKINT N !no signal
101 BTEMP N passed
8 MBUS_RX_TX_LOOP Y passed
108 EXT_DEVICE N passed
56 CDSP_SLEEPCLK_FREQ N passed
128 CDSP_SLEEPCLOCK_FREQ N passed
86 CDSP_RF_BB_IF N passed
83 CDSP_RF_SUPPLY N passed
85 CDSP_TX_IQ N !no signal
74 CDSP_TXC_DATA N passed
82 CDSP_PWR_DETECTOR_BIAS N passed
79 CDSP_RX_PLL_PHASE_LOCK N passed
80 CDSP_TX_PLL_PHASE_LOCK N passed
75 CDSP_WCDMA_TX_POWER N PASSED(00)
81 CDSP_RX_IQ_LOOP_BACK N PASSED(00)
77 CDSP_GSM_TX_POWER N PASSED(00)
Do you know what could this be?
The Following 2 Users Say Thank You to gerdzio For This Useful Post:
Old 11-27-2010, 20:54   #2 (permalink)
Member: 719399
Thanks Meter: 228
Originally Posted by .:::parash:::. View Post
try hardware....
Br,
parash
What Hardware? Particularly? Lcd, flex or ?
Thanks
Old 11-28-2010, 01:09   #3 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
make sure you are using newest firmware available.
latest version of N96_RM-247 is 30.333. press Image DL if you don't have it.
if still the same,
repeat flashing by using ENO firmware, proceed with normal firmware update after eno flashing is done.
this is ENO for N96: click.
put the file on MCU.
The Following 2 Users Say Thank You to gbluez For This Useful Post:
Old 11-28-2010, 12:36   #4 (permalink)
Member: 719399
Thanks Meter: 228
Originally Posted by gbluez View Post
hi,
if still the same,
Hi
Now have dead phone completely
Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010)
Processing MCU file: RM-247_30.033_prd.core.fpsx
[BB5,XSR 1.5,BB5,N8815 ALG STNFMS] size: 97.33 MB
Supported Ids: 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101031103, 400C192101031103, 4003192101021103, 400C192101021103, 4003192101051103, 400C192101051103
Supported Ids: 008815C1, 008815D0, 008815D1, 008815D2, 008815D3
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Pooling for ADL device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2921A433
APE SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x]
APE ASIC MODE ID: 00
APE PUBLIC ID: A43CD0C8DD0551344BA007CBEAA998C057353D14
APE ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35
APE ROM ID: 137A9A3B33259D2C
Bootstrap failed, please remove USB cable try again !
Flashing terminated with error(s) in 11.297 s
RX Buffer: 05010501008815D313020100121501A43CD0C8DD0551344BA0 07CBEAA998C057353D141411010BBC4203E2D3B82504C75CB6 5E906A35150901137A9A3B33259D2C
Old 11-28-2010, 13:18   #5 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
use fbus as interface to handle it.
The Following User Says Thank You to gbluez For This Useful Post:
Old 11-28-2010, 13:20   #6 (permalink)
Member: 758009
Thanks Meter: 15
salut flash ton mobile avec la version 12.043 avec hwk apres tu le regler avec mxkey repair simlock j ai tester ça plusieur fois
Old 11-28-2010, 13:43   #7 (permalink)
Member: 719399
Thanks Meter: 228
hi,
Hi
With fbus can't pool the phone that's because phone died and now doesn't turn on at all.
Old 11-28-2010, 14:08   #8 (permalink)
Member: 719399
Thanks Meter: 228
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Processing MCU file: RM-247_12.043_prd.core.fpsx
[BB5,XSR 1.5,BB5,N8815 ALG STNFMS] size: 88.72 MB
APE Data :
ASIC MODE ID: 00
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1EF00005AC710052AAB9F83CC82C2047EE669950
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0020 8804 - 0000 6B21 [ST 58LR128U,128 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
CMT PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00
Supported Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3
loader not responding (0910000000B172)
Flashing terminated with error(s) in 32.547 s
RX Buffer: 0910000000B172
Old 11-28-2010, 14:24   #9 (permalink)
Member: 719399
Thanks Meter: 228
Still dead phone. Help me please
1ST BOOT : C0,0C [Rm-247] [2.1.0.1]
OMAP ID : 008815D3
OMAP MODE : 00
OMAP PBID : A43CD0C8DD0551344BA007CBEAA998C057353D14
OMAP HASH : 0BBC4203E2D3B82504C75CB65E906A35
OMAP ROID : 137A9A3B33259D2C
RAPx ID : 000000010000022600010006400C192101031103
EM 1 ID : 00000295
EM 2 ID : 00000B22
RAPx PBID : 1EF00005AC710052AAB9F83CC82C2047EE669950
RAPx MODE : 00
RAPx HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE
RAPx ROID : 4B9B75103E691FF8
CMT 1ST Boot OK
CMT 2ND Bt: RAPIDOv11_2nd.fg, Ver: 1.37.1
CMT FLID0 : 00208804-00006B21, St M36L0R7040U
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAPIDOv11_algo.fg, Ver: 1.40.0
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : RM-247_12.043_prd.core.fpsx
ERASE Skipped
Written: 8 Certificate(s)
CMT FLASH WRITE OK, Time: 31:45
OMAP ID : 008815D3
OMAP MODE : 00
EM 1 ID : 00000295
EM 2 ID : 00000B22
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
APE 2ND Bt: nomadik8815_2nd.fg, Ver: 1.43.0
00000090: 00 00 ..
ERR: APE 2ND Boot FLB1_MSG_C2: 00000400000000B172 APE 2ND CONF:
Process Failed, Repowering Mobile
Old 11-28-2010, 14:27   #10 (permalink)
Member: 758009
Thanks Meter: 15
c est un probleme de cable mon ami change un autre cable
The Following User Says Thank You to gsmbouzid For This Useful Post:
Old 11-28-2010, 14:31   #11 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
dear use latest fermware first of all flash only with eno files,,then reflash with latest files post result
The Following User Says Thank You to alkhaleejmobile For This Useful Post:
Old 11-28-2010, 14:31   #12 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
i repeat:
by using fbus: flash eno, if done, flash normal firmware, use market drop down menu.
untick safe flash.
Old 11-28-2010, 15:02   #13 (permalink)
Member: 719399
Thanks Meter: 228
i repeat:
untick safe flash.
Still no good:
Processing MCU file: rm247_ENO_x_2008wk41v0.033.fpsx
[BB5,XSR 1.5] size: 6.40 MB
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Flashing terminated with error(s) in 10.469 s
RX Buffer: 0400000000B172
Old 11-28-2010, 15:26   #14 (permalink)
Member: 758009
Thanks Meter: 15
cher ami vous avez un probleme de cable RX Buffer: 0400000000B172 essayer avec un autre cable
Old 11-28-2010, 15:28   #15 (permalink)
Member: 1441641
thaxxxxxxxxxx dear eno
Page generated in 0.24153 seconds with 9 queries
