07-30-2012, 10:06 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2007 Location: In the web Age: 37
Member: 622382 Status: Offline Thanks Meter: 201 | nokia x2-01 set is balinkin MXKEY [FT SCR2000 0], SN: C0833895 Using device: USB ROM Connection status: EHCI:HUB:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012) Processing MCU file: rm709__08.71.mcusw [BB5,XSR 1.6] size: 26.60 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 12E37421 CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000D215586628F8C693DF04687BBD8DED CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 12E37421 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35194605691738_CE RT.rpl). CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09 Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK Partitioning.... Partitioning complete Erase size: 33.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-012FFFFF] CMT FLASH,MuxOneNAND area [01300000-01DFFFFF] CMT FLASH,MuxOneNAND area [02600000-029FFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 37955B6F [] sent CMT UPDAPP block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 8.227 s Processing PPM file: rm709__08.71.ppm_c1 [BB5,XSR 1.6] size: 5.99 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT FLASH,MuxOneNAND area [01E00000-025FFFFF] Flash programming ... Programming completed in 1.977 s Processing CNT file: rm709__08.71_001.image_c1_tesco_uk_9k5r8 [BB5,XSR 1.6] size: 24.59 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 75.31 MB CMT FLASH,MuxOneNAND area [02A00000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 8.281 s Total time for flashing process(boot+erase+write) was 52.889 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 12E37421 Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 12E37421 i flashead by lateast verson same problem plz help me . thanks in advanced |
07-30-2012, 10:16 | #2 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Quote:
1st, you do not need flash phon for security resion.anyway post self test log bro. | |
07-30-2012, 10:23 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Flash it with Firmware of Same Product Code of Battery Back of your Phone only will solve it. BR, ZUBER |
