Old 03-01-2011, 10:02   #1 (permalink)
Member: 713374
Sonork: 100.1597179
Thanks Meter: 223
SECURITY_TEST failed!
6500c contact service..
i made so many pm even from server still same condition
i repaired SP lock data.. but remain in same condition.. kindly lead me..
Phone Type: RM-265 (Nokia 6500c)
SW Version: V 10.50 26-06-09 RM-265 (c) Nokia
Imei plain: 35638102196338-8
Product Code: 0555589
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
Imei net: 356381021963388
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 03-01-2011, 10:09   #2 (permalink)
Member: 18642
Thanks Meter: 44
Hi,
show us (paste log) : Phone test - Various - BB5 certyficate validation
Regards,
Zaworek
Old 03-01-2011, 10:38   #3 (permalink)
Member: 1181203
Thanks Meter: 6
[QUOTE=xim360;7016672]6500c contact service..
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
[/QU
brother see first vedio
then outhriz sd then write pm with 1, 309
Old 03-01-2011, 10:47   #4 (permalink)
mr_loverman's Avatar
Member: 87722
Thanks Meter: 112
save rpl. reset npc data.
copy all text from attached manole's rpl txt file
to your rpl under (after) NPC_data.
write rpl. post results
File Type: txt 6500c_without_NPC_DATA__made_by_MxKey.txt (1.8 KB, 16 views)
Old 03-01-2011, 10:50   #5 (permalink)
Member: 87722
Thanks Meter: 112
or attach RPL here and i'll modify for you.
use button for thanks
Old 03-01-2011, 11:40   #6 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
have u used SEARCH button bro???
try these steps
http://forum.gsmhosting.com/vbb/f550...ailed-1214364/
good luck bro
br
The Following User Says Thank You to specta For This Useful Post:
Old 03-01-2011, 11:48   #7 (permalink)
abidottupara35's Avatar
Member: 1178222
Sonork: 100.1602620
Thanks Meter: 467
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
1st writ authorized pm 1and 309 then writ completed but problem still then writ this rpl ur problem solved tested many many set 6500c_without_NPC_DATA.html
3330 v 412 fail with dfs 211 denn Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 09-19-2001 22:06
In wintesla 3310, what does cobba parrarel failed means brittnee Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 05-18-2001 16:05
MCU EEPROM contents: failed phr3ak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-12-2001 15:58
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-28-2000 15:35
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-22-1999 01:28
Page generated in 0.18403 seconds with 10 queries
