Old 05-22-2010, 15:06   #1 (permalink)
Member: 867442
Sonork: 100.1602740
Thanks Meter: 143
3110c security test fail i tried everything
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.30 07-05-09 RM-237 (c) Nokia.
Imei plain: 35683302770486-9
Product Code: 0514950
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 35683302*************
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following User Says Thank You to sanjayvikas For This Useful Post:
Old 05-22-2010, 15:11   #2 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
Write pm field 1 to 308
Old 05-22-2010, 15:24   #3 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
Super SD Auth .............and write pm in 1 & 309..........
Old 05-22-2010, 15:39   #4 (permalink)
Member: 515388
Thanks Meter: 15
U want Mx key 4 this !
Old 05-22-2010, 15:42   #5 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
open this pm file.do super sd auth. and write this pm file.
Old 05-22-2010, 15:44   #6 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Contact me by sonork.
Old 05-22-2010, 16:01   #7 (permalink)
LIKI's Avatar
Member: 1641
Thanks Meter: 54
GOTO Service , IMEI & Security, Repair SD.
GOTO PM , TICK Load RFBB from Server, SUPER SD Auth and Write.
b.r.
LIKI>
Old 05-22-2010, 18:15   #8 (permalink)
Thanks Meter: 4,071
try this way:
1: http://forum.gsmhosting.com/vbb/f299...1000-a-965626/
2: http://forum.gsmhosting.com/vbb/f299...-files-915468/
3: http://forum.gsmhosting.com/vbb/f299...e-here-962316/
Old 05-22-2010, 18:28   #9 (permalink)
bilalzaink's Avatar
Member: 774744
Thanks Meter: 774
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
its a not a big problem...write RPL file without NCP data with same ok phone.(you can download this file from mxkey section..
if not solve write pm with using super sd auth...
your problem is 100% solved....
Old 05-22-2010, 19:20   #10 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
backup rpl
rest npc
go to pm click erase pm
writ rpl then click recover cert
simlock> click splock info then tick make simlock rpl then click update simlock
repair sd
go to pm >tick load rfbb from server then click SUPER SD AUTH and writ pm
The Following User Says Thank You to alasmmar For This Useful Post:
Old 05-24-2010, 07:14   #11 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
in this case no need to full erase than flash
just in few steps u can do this
a. first of super sd then go to pm tap do sd auth then select pm write once into phone
if no success
b. replace CCC and HWC cert of RPL from same model and write it back to ur phone than repeat the SX4 + pm process
Old 05-24-2010, 09:37   #12 (permalink)
Member: 631452
Thanks Meter: 6
check this
Original Imei: 35322503241125
Original Product code: 0581437
Bluetooth ID: 002547A986F4
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35322503241125-4
Product Code: 0550691
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 353225032411254
Counter: 0/3, 0/10
step two
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 222001115E967E5631B000A65C6158095A6BD1A0
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Certificate programmed successfully !
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
what to do now ? tell me everyone ... its not for a single 3110c but every set .... we need an answer from u team
Old 05-24-2010, 09:44   #13 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
first make back up then write this rpl........
after that write pm 1 to 309 section.....
File Type: rar 3110c rpl.rar (661 Bytes, 20 views)
Security Code dESiRE! Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 05-13-2011 22:17
5110 Security Code Help! cahrisma Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 07-05-2010 09:04
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-28-2000 15:35
SECURITY CODE AWLABA Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 02-22-2000 23:38
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-22-1999 01:28
Page generated in 0.22925 seconds with 10 queries
