11-25-2011, 17:52 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: kosovo Age: 45
Member: 621841 Status: Offline Thanks Meter: 37 | oclhashcat-lite v0.7 -> OFFICIALLY THE WORLDS FASTEST HASH CRACKER ENGINE! UPDATE!!! piece of art that can not be repliŠated or competed with - oclhashcat-lite v0.7 by atom is Here! - TASTE THE REAL AWESOMNESS!!! More stability, more performance, more flexibility, more advantage, more RAW power!!! The most advanced SL3 hash-cracking software on the planet SL3 optimizations @ stock speeds 5XXX cards -> + 2.44% 6XXX cards -> + 3.33% oclhashcat-lite 0.7 is super OverClock-friendly so by raising GPU clocks you will achieve before unexperienced speeds! (MAKE SURE YOU OWN EFFICIENT COOLING SYSTEMS PRIOR OVERCLOCKING!!!) All users to use v0.7 oclhashcat-lite must download ATi 11.11 Complete Driver pack with SDK 2.5 runtime built in to it. You will find driver packets for your specific hardware application here: AMD Graphics Drivers & Software official oclhashcat-lite support forum: hashcat Forum info and FAQ's: oclhashcat_lite [hashcat wiki] and cracking_sl3 [hashcat wiki] following links to be constantly updated with fresh and usefull info! New v0.7 version download link will be available from official site here: oclHashcat-lite - advanced password recovery the comprehensive changelog v0.6 -> v0.7 Code: oclHashcat-lite v0.07 Hello Hashcat-Users! I am very proud to present you oclHashcat-lite v0.07. You can download it here. Highlights: * Full support for mixed GPU types due to own thread management. * NVidia kernels has been vectorized - gave nice GPU utilization boost. * Improved DES kernel, more than 20% performance boost on AMD cards. * Broke 20B/s mark on stock clocked hd6990 @ MD4. * Switched to AMD APP SDK v2.5. * Added kernels for nsldap, nsldaps, MSSQL(2000), MSSQL(2005) and Cisco-PIX MD5. * Rewritten --restore code from scratch. It is much more intuitive now. * Parameters for distributed computing simplified. NVidia driver notes: Nothing special here. Everything should work out-of-the-box. AMD driver notes: Starting with this version, Catalyst v11.11 is the new recommended driver version. Nothing to worry, even if oclHashcat-plus has not been updated yet, it will continue to work fine. Linux users benefit from Catalyst v11.11 for two more reasons: * The 100% CPU killer bug problem is fixed. * It finally ships with an embedded OpenCL runtime. In other words: no more need to install the AMD APP SDK. Important: You have to uninstall the AMD APP SDK v2.4. Then, after uninstalling the SDK, make sure the correct libOpenCL.so is loaded (the one which ships with the driver). You can verify this by doing an "ldd oclHashcat-lite64.bin" and check the path. It should link to "/usr/lib/libOpenCL.so.1". If it is not found, you may have to create an symlink from "libOpenCL.so" to "libOpenCL.so.1". For some unknown reason the Catalyst installer did not do this automatically on my box. Performance improvements: AMD hd5970 (Linux Ubuntu 11.10, 64bit, Catalyst v11.11) Code: vBulletin > v3.8.5: 33,50% SHA1: 0.47% sha1($pass.$salt): 0.56% MySQL > v4.1: 1.73% MD4: 1.11% SHA256: 12.58% descrypt, DES(Unix): 23.21% SL3: 2.44% AMD hd6990 (Windows7, 64bit, Catalyst v11.11) Code: MD5: 4.64% md5($pass.$salt): 4.50% md5(md5($pass)): 11.22% vBulletin < v3.8.5: 11.55% vBulletin > v3.8.5: 29.96% SHA1: 3.39% sha1($pass.$salt): 3.14% MySQL > v4.1: 7.65% MD4: 2.22% NTLM: 0.43% DCC: 6.77% MSSQL: 3.19% SHA256: 8.35% descrypt, DES(Unix): 20.44% SL3: 3.33% Oracle 11G: 3.20% NVidia gtx580 (Ubuntu 10.10, 64 bit, ForceWare 280.13) Code: MD5: 1.53% md5($pass.$salt): 1.53% md5(md5($pass)): 2.93% vBulletin < v3.8.5: 2.93% SHA1: 6.21% sha1($pass.$salt): 6.21% MySQL > v4.1: 1.89% MD4: 17.67% NTLM: 18.67% DCC: 16.57% descrypt, DES(Unix): 5.60% SL3: 6.06% Oracle 11G: 6.33% NVidia 560 Ti (Ubuntu 11.10, 64 bit, ForceWare 280.13) Code: MD5: 2.53% md5($pass.$salt): 2.53% MD4: 23.69% NTLM: 14.97% DCC: 0.85% Full changelog: Quote:type: feature file: kernels desc: added support for AMD GPU's "Devastator" and "Scrapper" type: feature file: kernels desc: added -m 600 = nsldap, SHA-1(Base64), Netscape LDAP SHA type: feature file: kernels desc: added -m 700 = nsldaps, SSHA-1(Base64), Netscape LDAP SSHA type: feature file: kernels desc: added -m 1300 = MSSQL(2000) type: feature file: kernels desc: added -m 2300 = MSSQL(2005) type: feature file: kernels desc: added -m 2400 = Cisco-PIX MD5 type: feature file: kernels desc: added support for vector datatypes on NV for better sm_21 utilization type: feature file: host programs desc: added support for mixed GPU types (example: hd5970 and hd6850) type: feature file: host programs desc: simplified --pw-skip and --pw-limit for more intuitive usuage, see hashcat wiki for details type: feature file: host programs desc: added --pw-skip-plain and --pw-limit-plain, user can specify a string instead of a number type: feature file: host programs desc: added support for setting CPU affinity. Defaults: Linux unlocked, Windows locked to CPU #1 cred: MrUltimate type: feature file: host programs desc: added display of the mask in status screen cred: tatgdi type: feature file: host programs desc: added display of the hash in status screen type: feature file: host programs desc: changed restore-timer function. if set to 0, the restore-file is written instantly on progress type: change file: host programs desc: changed restore-timer default value to 0 type: change file: kernels desc: switched to AMD Accelerated Parallel Processing "APP" SDK v2.5 type: change file: host programs desc: changed outfile-formats for more flexibility. default value is 3. see --help for more cred: TheFire type: change file: host programs desc: recalibrated defaults for gpu_accel and gpu_loops that kernels run fast but not to aggressive type: change file: host programs desc: changed speed display compressing threshold from 10000 to 100000 type: change file: kernels desc: removed kernel encryption. thus, archive file became smaller and startup-time reduced type: bug file: host programs desc: fixed some typos in error messages type: bug file: host programs desc: fixed bug in --gpu-async which was not enabled even if specified type: bug file: host programs desc: fixed NVidia issue: cuStreamsynchronize() 700 type: bug file: host programs desc: workarounded AMD issue: "100% CPU killer bug". Linux only, requires Catalyst >= 11.11 type: bug file: host programs desc: workarounded AMD issue: ../../src/xcb_io.c:140: dequeue_pending_request -- atom The Biggest THANKS and CREDIT to atom! |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
Ringtones from the charts and new Links | GM | GSM Mobile Links | 0 | 09-26-1999 13:54 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
