Old 04-04-2010, 12:17   #1 (permalink)
billa2008's Avatar
Member: 687128
Thanks Meter: 261
7250i problem
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010)
ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
Performing Flash Authentication ...OK
UEM ID: 00D47467:2984DA60
ASIC type: 2
UEM Imei: 37295500931296
Flash Imei: 35295500931296
MasterCode: 0051414607
Invalid imei checksum !
Phone Type: NHL-4JX (Nokia 7250i)
SW Version: V 5.41 09-02-05 NHL-4JX (c) Nokia.
Imei plain: ??????????????-?
Imei OTP: 37295500931296
Product Code: 0510760
Cellular System: GSM
ASIC ID: 0x1120, type: 2
Ppm Id: A
Language Pack:
English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic
Imei plain is invalid !!!
Imei net: FFFFFFFFFFFFFF
Version: SIMLOCKLIB VERSION 2.28 -fix task:Extended number of TDS-6 boxes
Counter: 0/3, 0/10
CONFIG_DATA: E588A8C976047478
PROFILE_BITS: 10DDF22CDF25D1DD
SIMLOCK_DATA corrupted!
Old 04-04-2010, 13:03   #2 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
ASIC type: 2
Ppm Id: A
Language Pack:
Counter: 0/3, 0/10
Youre IMEI is not valid, if it support, then you have to use online logger for RPL.You can serch the forum to check if it support or not and the procedure.
jar jad game files 7250i problem fender62 Nokia Multimedia 3 01-09-2005 07:42
7250i problem TITO Nokia Digital Core Technology 4 ( DCT-4 ) 2 05-30-2004 07:31
7250i problem prasse Nokia Digital Core Technology 4 ( DCT-4 ) 5 05-04-2004 05:58
nokia 7250i problem blueyesdude Nokia Digital Core Technology 4 ( DCT-4 ) 4 02-22-2004 15:30
Page generated in 0.13244 seconds with 9 queries
