10-13-2011, 09:03 | #1 (permalink) |
Registered User Join Date: Aug 2010 Location: EVERY WHERE Age: 38
Member: 1372393 Status: Offline Sonork: I.M.STORE Thanks Meter: 90 | phone restricted undo here is full logs.... MXKEY [FT SCR2000 0], SN: C0xxxxxx Connection status: OHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.67 Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 6D1EE55 CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 123002189F091049B45720C1AA9E07785A4D867C CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT ROM ID: 67E82268F29CEA60 Loading CMT secondary boot code SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0098 0030 - 0000 0131 [Toshiba NAND-1G] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 6D1EE55 FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 4431C834027BBA0D18A5ED745CAFA04BA679A74A Original Imei: 35536304706461 Original Product code: 0595774 Bluetooth ID: D4C1FC933034 SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 314E23DD Verifying communication to device OK. Phone type: RM-598 (Nokia 7230-1c) SW version: V 10.81 28-02-11 RM-598 (c) Nokia Imei plain: 35536304706461-6 Product code: 0595774 Battery voltage: 3910 mV, current: 136 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3553630xxxxxxxxx Version: SIMLOCK SERVER Provider: Tess , Country: Brazil Counter: 0/3, 0/10 CONFIG_DATA: 7240600086388183 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=72406F [Brazil-Tess ] BLOCK2: 1=CLOSED(MCCMNC), DATA=72410F [Brazil-ATL Algar ] BLOCK3: 1=CLOSED(MCCMNC), DATA=72411F [Brazil-Telems Cel ] BLOCK4: 1=CLOSED(MCCMNC), DATA=21407F [Spain-Telefónica Móviles España, SAU ] BLOCK5: 1=CLOSED(MCCMNC), DATA=26806F [Portugal-TMN - Telecomunicaçôes Movéis Nacionais, S.A. ] BLOCK6: 1=CLOSED(MCCMNC), DATA=72423F [Brazil-Telest Cel ] plzzz any one guide me to solve this problem.......? |
10-13-2011, 09:05 | #3 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Pakistan
Member: 644616 Status: Offline Sonork: 100.1608012 Thanks Meter: 257 | Quote:
10-13-2011, 18:14 | #7 (permalink) |
Member: 1372393 Status: Offline Sonork: I.M.STORE Thanks Meter: 90 | can any one suggess me by which process i will unlock it.....this type of phone i got 1st time in my hand...... plzzzz any one guide me clearly solution............thanx in advance |
10-14-2011, 03:50 | #9 (permalink) |
Freak Poster Join Date: Jun 2011 Location: North Korea
Member: 1589313 Status: Offline Sonork: .. Thanks Meter: 34 | if using mx key How to unlock Nokia BB5 SL3 with MXKEY (step by step): 1. Identify phones with "Scan Phone" (as usuall) to see if it is SL3 phone. 2. Go to "IMEI & Security" tab and select"Online Logger" 3. Click "Login", and if your card is activated SL3 Unlock panel will be visible. 4. Click "Read Phones IDs" to prepare the data which is needed for bruteforce task (this will also identify is phone is supported or not), new file {IMEI}.sha will be created at folder "{MOBILEEX}\data\SL3\" 5. Click "Start Bruteforcer" and select {IMEI}.sha file. Random Salt is checked by default which mean the task will using random data to make bruteforce instead of using normal sequence. 6. After some time and the bruteforcer task completed, it will create file {IMEI}.cod to the same folder as {IMEI}.sha file 7. Then go back to main exe, and do "Calculate Codes" to get the unlock codes, unlock code will be saved as {IMEI}_SP_CODES.txt. Tick "Send to the phone" to directly send the codes to the phone. 8. Task is done and the phone was unlocked, enjoy ! PS. For Windows 7 Users, Please Run MobileEX.exe as Administrator. Requirement: - an activated MXKEY with SL3 credit(one time activation). - MXKEY suite v3.4 revision 1.7 - PC with supported GPU such as: AMD/ATI HD-4XXX or HD-5XXX, or NVIDIA with CUDA support. - Internet Connection or U can send *.sha file to some BF SERVER, to get ur code ................. its not free |
10-14-2011, 04:00 | #10 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | Quote:
10-14-2011, 09:57 | #11 (permalink) |
Member: 1372393 Status: Offline Sonork: I.M.STORE Thanks Meter: 90 | thanx for guiding me but i dont have super computer it means i have to return back set to the customer............. thanx to ALL............ |
03-09-2013, 08:10 | #12 (permalink) |
Insane Poster Join Date: Feb 2011 Location: BIRGUNJ NEPAL Age: 34
Member: 1511137 Status: Offline Thanks Meter: 7 | somebody help me plzzzzzzzz phone restricated Phone type: RM-604 (Nokia 7230) SW version: V 10.82 08-06-11 RM-604 (c) Nokia Imei plain: 35536504804339-0 Product code: 0590660 Battery voltage: 4854 mV, current: 83 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00IIIIRR0301035420, ver: 003.008 SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355365048043390 Version: SIMLOCK SERVER Provider: Digifone mm02 Ltd. , Country: Ireland Counter: 0/3, 4/10 CONFIG_DATA: 2720200000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=27202F [Ireland-Digifone mm02 Ltd. ] |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
